Question about Cycling
Shifting does not work - Cycling
    Top Expert:
  • Cycling Master
  • 46,272 Answers
OIL it with some good penetrating oil
Posted on Apr 24, 2015
Brake lights 4 ways & blinkers aren't working, also the door locks. Can't get it out of park ?
I'd have to check applicable fuses for brakes and turn signals. Check multifunction switch.
Some makes and models, use a shift interlock, meaning you have to step on the brake to shift. Again, some makes and models have a shift interlock bypass button, push the button, shift into neutral.
Usually with shift interlock, if the brake lamps don't work, you can't shift it.
What is year--make--model??
Apr 27, 2016 | Cars & Trucks
My speedometer isn't working and won't shift gears..? Changed In/Output .. What else could be the problem ?
speed sensor / speedometer drops too zero - Car Forums and ...
www.automotiveforums.com > ... > Ford > Escort
Because the speed sensor isn't working the speedometer isn't working either. ...thinks you are stopped or going very slow and won't shift it out of first gear.
Won't Shift Out of First - BIONICDODGE.COM
www.bionicdodge.com/bionic/index.php?topic=1645.0;wap2
A friend of mine has a Durango, the tranny wont shift out of 1st. ... Tip: If its a speed sensor problem, you may find that the speedo isn't working very well. ... To check and see if 2nd gear is messed up mechanically, manually hold it in low 1, ...
21298304 Tack and speedometer quit working, won't shift ...
dochost.no-ip.org/F/.../t21298304-tack_speedometer_quit_working_shif...
My van won't shift into overdrive, speedometer isn't working, door locks are not ...My speedometer quit workin and my gears are a lil hard shiftin and i have no ...
Speedometer Odometer trans shift issue - Ford Truck Enthusiasts Forums
www.ford-trucks.com > ... > Misc. > Electrical Systems/Wiring
Jan 25, 2016 | Cars & Trucks
HOW MAN HOURS BREAK IN CALIFORNIA AFTER 8 HOUR SHIFT?
Employees must, with two exceptions, receive at least eight hours free from work between shifts, whether they are "split shifts," "on call shifts," "back-to-back" shifts or ordinary daily shifts.
Rest between shifts is not required if:
  • the total time worked during both shifts does not exceed 13 hours; or
  • the employer and employee agree in writing to reduce or forego the eight-hour rest period.
Example
Monica works in a restaurant. She is on split shifts, working from 11:30 am to 2:30 pm and then from 4:00 pm to 7:00 pm. The total time of her two shifts is 6 hours. Monica does not need to have eight hours off between the shifts because her total hours worked on the shifts do not exceed 13 hours.
Note: The requirement for rest between shifts operates simultaneously with the requirement for daily rest; an employee's schedule must satisfy both requirements. For example, an employee might agree in writing to work two eight-hour shifts in a row without any time free from work between them (the employee's agreement means there is no violation of the rest between shifts rule), but if that results in the employee receiving less than 11 consecutive hours off in a day, the employer will be in violation of the daily rest rule* and therefore it is not permitted.
* Unlike the case with the rest between shifts requirement, an employee cannot agree to waive the daily rest requirement.
Oct 13, 2014 | Cars & Trucks
Gear shiftlock no current not working
check brake transmission shift interlock fuse BTSI. check the NSBU fuse.which is the transmission neutral switch.if all is good check brake light switch.make sure brake lights working if not check fuse.when you apply brake that will energize brake transmission shift interlock solenoid.so you can shift out of park.if brake light switch is okay and fuse good.the brake transmission shift shift interlock solenoid could be faulty.
Jul 15, 2013 | Cars & Trucks
1994 chev 4x44l60 trans,np241c tcase,speedo stopped working trans immedeatly stopped shifting past 2 gear
FIX SPEEDO MAY NEED A SPEED SENSOR AND IT WILL NOT SHIFT IF IT DOES NOT SEE THE OUT PUT SPEED
Feb 21, 2013 | Cars & Trucks
2003 explorer wont shift out of park engine starts , gear shift will not move
Your shift lock actuator is not working. This system works off of the brake light circuits. The FIRST thing to check is your brake lamps. If they are not working, that is the reason for your shifter not working. Fix the brake lamps and your shifter will shift. (Possible defective brake lamp switch).
If your brake lamps are working, then the shift lock solenoid or its circuits are defective. In this case, you can work around the problem until you can get it fixed. Turn the ignition switch one click.(Far enough to unlock the steering wheel, but not far enough to make the lights on the instrument cluster illuminate.) The shifter will then shift out of PARK. Place the shifter in NEUTRAL and start the engine. You can then shift to the desired gear to get where you need to go. If you place the shifter back in PARK, you will have to shut the ignition off and repeat the process.
May 04, 2012 | 2003 Ford Explorer
Shift key not working
You have 2 Shift keys on the keyboard. If the other shift key is working then the shift key that is not working is defective. You should consider replacing the keyboard on your laptop. There is no setting on Windows that can disable the shift key.
**Note : If both Shift keys are not working, Try to check if sticky keys feature on windows is on. Sticky keys should be disabled. To disable sticky keys, Click on start and Go into control panel > Accessibility Options, and under keyboard there is sticky keys. Remove the tick and click apply and OK.
**If "Use Sticky Keys" is unchecked, that means sticky keys is disabled.
May 29, 2010 | HP Compaq nc6000 Notebook
Left shift + T, right shift + E doesn't work on an hiper keyboard
Your shift key is broken, if this product was recently purchased, return it for another. If you've had it for a while and it just decided to stop working, your best bet would be to pry the Left Shift key off and clean around that area and properly attach the key back on - its possible it wasn't hitting the sensor when it was pushed down.
If this does not fix your problem please leave a comment and I will assist you further.
Jul 17, 2009 | Microsoft K5100141 Keyboard
1997 ford contour wont shift
a speed sensor will prevent the trans from shifting if the odemeter isn't working because if the speed sensor is bad and the odemeter and speedometer isn't working the trans has no ideal what gear to be in
Apr 12, 2009 | 1997 Ford Contour
Gear shift won't shift.
make sure the brake lights are working the shift interlock works off the brake light switch.
Jan 04, 2009 | 1998 Ford Taurus
Cycling Logo
50 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
