Question about Snapper NXT2346 46" 23HP NXT Lawn Tractor
Why does it just make a clicking sound and won't start?
  • Anonymous Apr 24, 2015
    It's a new battery.
  • ray gallant Apr 25, 2015
    then starter has failed might try oiling the spring and the gear they do seize up sometimes
    Top Expert:
  • Snapper Master
  • 44,451 Answers
Battery needs charged or replaced .
Posted on Apr 24, 2015
    It's a new battery so what else could it be?
    Top Expert:
  • 2,899 Answers
Car Won't Start?
This procedure usually works:
·Check the battery cable connections:
Make sure the positive cable, makes a good connection at the battery and at the starter. Make sure the negative cable makes a good ground connection at the battery and (preferably) at the engine.
·Check the battery the simple way, like this:
Turn on the headlights, then try to start the car.If the headlights do not dim or go out, then the battery is likely ok.
·Check the starter and solenoid:
If the wiring looks ok, then look at the starter solenoid for a good connection, and proper voltage at the starter(10 volts minimum while cranking).
If the starter spins and no crank, the problem is most likely the Solenoid's bendix gear is stuck.
Have someone hit (not too hard) the starter while you try to start the car. This usually works by dislodging a stuck bendix gear.
·Make a simple test of the alternator:
If you can, somehow get the engine running, measure the voltage at the battery. It should be at least 13.6 volts to properly charge the battery.
1986 yamaha xj700 won't start just makes click
sounds like a bad earth if you have jump leads go direct of earth to engine to see if this cures it if so you no where problem is clean replace earth
Jul 12, 2013 | Motorcycles
Clicking won't start
the clicking sounds like the starter cylenoid,if the battery is dead or is going bad that is the sound you will here
Nov 16, 2012 | 2004 Jeep Liberty
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
Car won.t start makes a clicking sound
this is always the starter solenoid that does this, replace the starter solenoid.
Apr 12, 2009 | 1997 Saab 900
Snapper NXT2346 46" 23HP NXT Lawn Tractor Logo
152 people viewed this question
Top Snapper Garden Experts
ray gallant
solver2010
Thomas Perkins
Thomas Perkins
Are you a Snapper Garden Expert? Answer questions, earn points and help others
