Question about Food Mixers
How to remove dough hook from andrew james stand mixer as it is stuck in
SOURCE: viking stand mixer dough hook will not come off
Had the same problem with dough hook not coming off. Sent to a Viking dealer in Rockford and was quoted $600. to replace gear box. Took it back without repairs and call Viking listed in manual and sent it to them on a Monday and by Friday had it back fixed and no charge.DM
Posted on Mar 09, 2008
SOURCE: I need replacement beaters for a dough hook stand mixer
Information from manufacturer stating replacement parts have been exhausted.
Posted on Feb 02, 2009
ricardok45
  • 135 Answers
SOURCE: KitchenAid 600, Stand Mixer -
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
Posted on Feb 13, 2009
clyde2j2
  • 137 Answers
SOURCE: bread dough hook slips when mixing
This is not a solution but I think you have a serious problem you might have sheared some gear teeth whent the mixer jammed and it only manifests itself under a heavy load, I would take it to a repair guy, those mixers are expensive and it would be worth it.
Posted on Mar 28, 2009
SOURCE: The dough hook is stuck in the beater shaft of kitchenaid mixer
It sounds like it got overloaded when you last mixed dough. It will only come off the way it went on. If it has been bent on, it may need a bit of gentle encouragement.
Posted on Jan 24, 2010
Dough hook will not come off
I had the same problem too. There should be maybe 1/4" of loose vertical play of the dough hook (or similar attachment) on the agitator shaft. The hook locks in place rotationally on the shaft until it is pushed up. Before you try to turn the dough hook backwards in an attempt to remove it, push it upwards and hold it up, then rotate.
May 22, 2012 | Hobart A200 Stand Mixer
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
How do i insert dough hooks into stand mixer professional 600??? There are no holes.
Your Flat Beater, Wire Whip and Dough Hook attachement ends should
look the same. They are inserted onto the beater shaft and held in place
by a single pin. The reason you cannot attach the dough hook to the
beater shaft because it is the wrong hook for your particular model.
Jun 11, 2011 | KitchenAid KP2671 Professional 6 Series...
Cannot get dough hook out of slot pin seems stuck
run under hot water over where the dough hook attatches to shaft. this should free it.
Apr 23, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Dough hook stuck immediately after use
I just got my dough hook unstuck! The problem was the bolt at the top of the dough hook. This bolt is used to adjust the height of the dough hook. This bolt came loose while mixing and went up towards the mixer. The force of the spinning actually tightened this bolt against the mixer so when I tried to release the dough hook by lifting and turning, it wouldn't lift. The bolt was in the way! The solution is to loosen this bolt. You'll need a thin wrench that's about 15 mm. You can test loosening this bolt on the other attachments since they loosen in the same manner. You'll have to bend the white shield down slightly to get the wrench in there. It's a tight squeeze even with a thin wrench. Hold on to the lower end of the dough hook and turn the wrench counterclockwise when looking down at it. Once you loosen the bolt, you'll be able to turn the lower portion of the dough hook to lower it. Then you can lower the bolt further. Once you have them low enough, you can remove the dough hook like normal - lift and turn. Sure beats boxing it up, shipping it for repair and paying for shipping both ways!
May 03, 2010 | Cuisinart SM-55 Stand Mixer
Need to know the part number for a dough hook for a hobart a200c stand mixer. What number would be stamped on the hook?
A 20 qt "E" dough arm is S-23467. A 12 qt is S-62886.
A 20 qt "S" sweet dough beater is R-8022.
Jan 05, 2010 | Hobart A200 Stand Mixer
Having a hard time removing the dough hook on the h-600.
make sure the beater shaft is clean. is the dough hook new or old if its new you can deburr inside of dough hook to ease in install and removal of attch. please let me know so i can futher asist
Dec 03, 2009 | Hobart H600 Stand Mixer
Jun 15, 2009 | KitchenAid KSM50PR Professional Series...
The gear is slipping on my Hobart A200
In what speed is it slipping?You only use 1st speed for dough,right?Can you put it in gear and stop the hook from moving with your hand?Let me know.
Jan 13, 2009 | Hobart N50 Stand Mixer
Viking stand mixer dough hook will not come off
Feb 18, 2008 | Viking VSM700 Stand Mixer
Food Mixers Logo
89 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
