Question about Garden
2E John deer blowing white smoke - Garden
    Top Expert:
  • 10,875 Answers
Blown head gasket
Posted on Apr 24, 2015
  • 60 Answers
White smoke is usually oil getting into the cyl. bring to a service pro.
wadembly
  • 489 Answers
SOURCE: i have a john deere lt160, when starting up it
to much oil or burned valve it sounds like to much oil if i can further help let me know thanks wade
Posted on Jul 04, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
Posted on Nov 08, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere 445 pto will not start Smoke from
If smoke is coming from solenoid on rear top side of trans then internal windings are bad but usually it will blow the fuse.Remove plastic nut from solenoid,slide solenoid off shaft then engage PTO.If solenoid does not smoke slide screwdriver or something like it into solenoid and see if there is any Magnetic force.If smoke comes from deck check idlers and spindles for movement.Be sure to ckeck gearcase oil level on the deck.
Posted on Nov 13, 2009
  • 54 Answers
SOURCE: mower smoking and running rough
Check the gas you put in, it sounds like it had water in it.
Posted on Apr 28, 2010
nova2nv
  • 197 Answers
SOURCE: Hello my name is John. I have a 345 John Deere
345's have a habit of the choke sticking at the carb.Another problem they have is the fuel pump diaphram will crack and allow your engine to fill up with fuel,to much fuel in crankcase will end up past the rings when not running and smoke pretty bad when fired up.
Posted on Jun 25, 2010
John Deere 214 with Kohler K321
Check carby is not to rich,"mixture screw" check for fuel blockage on fuel tap.
Sep 27, 2016 | John Deere Garden
Why is my john deere d140 having white smoke coming out of engine
If white smoke is also coming out of your exhaust oil is leaking past the piston rings into the combustion chamber and is being burned along with the fuel. If its not coming from the exhaust it may have been overfilled and oil could be leaking out and burning when it comes into contact with the engine.
Aug 30, 2014 | Garden
332d john deere skid steer why is it blowing white smoke
i do not know what a skid steer is. If the motor on anything is blowing white smoke there is water getting into the combustion chamber which is bad bad news means head gasket,intake,cracked cylinder those patch jobs in the bottle are exactly what they are patch jobs it will hurt you pocket book a lot but if you want to keep it it is past the point of patching.
May 17, 2014 | John Deere 420,1020,2010,2020,2510,2520...
J power and smokes white
Possibly a head gasket problem (as the head heats up it warps slightly, allowing coolant to seep into the cylinders, which is the source of the white smoke--steam) Is the motor using coolant?
Aug 17, 2012 | John Deere 420,1020,2010,2020,2510,2520...
Kohler CV15S on a John Deere LT155 smokes alot. I pulled the head off to check the cylinder. The cylinder looks perfect but the head gasket looks as if it has had blow by between the exhaust valve and the...
I also have a John Deere LT155 Garden Tractor, and 'I have issues with white smoke and cannot get it started. I have detected gas smell in the oil. Quick call to a JD service centre told me it was likely a head casket. If the smoke is white, then that is likely your problem.
May 02, 2010 | Garden
Mower smoking and running rough
Apr 26, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
