Question about Garden
My John deer 2e blower is blowing white smoke out can anyone help. Put new gas in and little less smoke.
    Top Expert:
  • 10,875 Answers
Headgasket
Posted on Apr 24, 2015
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
  • 21 Answers
SOURCE: john deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Posted on Jul 14, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
Posted on Nov 08, 2009
SOURCE: John Deere Gator XUV 2008 oil in gas
I know exactly the problem. I work for a John Deere dealership and have seen this problem before. It is called short-tripping. When a machine is first started, gas does leak into the cylinder and crankcase past the rings--normal--simulates leaving the choke on too long with a carburetor engine.. As the engine temperature rises, the gas in the oil is burned off and there really isn't a problem. When you take short trips or do not let the engine run to get it up to temperature, the gas in the crankcase does not get burned off and will accumulate over time. Make sure the machine is getting up to operating temperature and this could take up to 20 minutes if the ambient air temp is low. Feel free to e-mail at ericf@greensouth.com with further questions
Posted on Dec 16, 2009
  • 394 Answers
SOURCE: Our new to us john deere 345 tractor won't keep running
You may try blowing backwards from behind the fuel filter into the gas line. Not to much air pressure though. Make sure the gas cap is off.
Posted on Mar 13, 2010
332d john deere skid steer why is it blowing white smoke
i do not know what a skid steer is. If the motor on anything is blowing white smoke there is water getting into the combustion chamber which is bad bad news means head gasket,intake,cracked cylinder those patch jobs in the bottle are exactly what they are patch jobs it will hurt you pocket book a lot but if you want to keep it it is past the point of patching.
May 17, 2014 | John Deere 420,1020,2010,2020,2510,2520...
John deere 826 will not go forward or reverse
Can anyone help me with a john deer 826 snow blower that won't engage in forward motion?
Mar 04, 2013 | John Deere Mowers Tillers Snow Blowers...
I bought a John Deere 7.0 Ft-Lbs 22"
its under warranty. let them fix it
Feb 25, 2018 | John Deere Garden
Kohler CV15S on a John Deere LT155 smokes alot. I pulled the head off to check the cylinder. The cylinder looks perfect but the head gasket looks as if it has had blow by between the exhaust valve and the...
I also have a John Deere LT155 Garden Tractor, and 'I have issues with white smoke and cannot get it started. I have detected gas smell in the oil. Quick call to a JD service centre told me it was likely a head casket. If the smoke is white, then that is likely your problem.
May 02, 2010 | Garden
Mower smoking and running rough
Check the gas you put in, it sounds like it had water in it.
Apr 26, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Mar 13, 2010 | John Deere A,b,g Tractor Carburetor Float...
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
