Question about Honda Garden
Troy-Bilt push mower with a Honda #16100-ZOL-852 carburetor on a GCV 160 engine. Would like to know positioning of all gaskets?
    Master:
  • 969 Answers
Google parts replacement for this model, diagram will show gasket placement.
Posted on Jul 04, 2015
3 Suggested Answers
  • 37 Answers
SOURCE: Need to know how to change the oil in my Honda
take out the drain plug under the lawn mower drain it put the plug back fill it with oil then you done
Posted on Jun 06, 2009
harlan301
  • 205 Answers
SOURCE: gcv 160 honda push mower stalls out after running
check your oil. make sure that it don't smells like gas. if so, you'll need to over haul the carburetor and change the oil too. your unit sounds like its over heating. you could also have a coil ,thats going bad too. good luck
Posted on Oct 23, 2009
I have a troy-bilt model 020296 power washer. what type of replacement spark plug does it take?
Tom, NGK BRP6ES ,Champion RN9YC,Torch F6RTC are replacement sparkplugs for Honda GCV 160 pressure washer engine. This info should be in your pressure washer engine manual. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.bsppwebtools.com/data/manuals/020296_0esAw.pdf
Troy Bilt 020296 Pressure Washer Relacement Parts
Spark plug cross reference
Jul 02, 2016 | Troy-Bilt Garden
Honda gcv 160 engine
Does this unit have an electronic fuel shutoff on the bottom of the carburetor?... If so, that is your problem. Otherwise, you will need to remove the carburetor, service it..
If u want test it first... Spray some carburetor cleaner into the plug hole then reinstall the plug. Start the engine, if it runs for a few seconds, u definitely have a fuel issue, carb....
U can buy a rebuild kit for the carburetor.
Also, go to you tube and search, how to service a 4 cycle carburetor..many videos to learn how...
Good curbside find!!
Oct 25, 2015 | Husqvarna HU700FH 22-in Self-Propelled...
I need a carburetor gasket diagram for och gcv160 motor
You need to determine which gasket and heat dams you have but following link should give an idea of how they go. Sorry can't give any better setup as there is too many variations to consider on these engines.
Honda GCV Carburetor Diagram
Mar 30, 2015 | Garden
Can't push troy bilt lawn tractor when it is in neutral
It sounds like the tractor is hydro, if so you need to find the release lever to allow it to move in neutral.
Most hydros have the lever under the seat or at the back of the tractor just behind the back wheels.
if and when you find it, it will need to be slid across and locked in to the operset position or pulled out, depending on what type it is.
Hope this helps
Regards
Micky
Jun 14, 2012 | Troy Bilt 175HP Manual 42" Riding Mower
How much oil does it take to change in a honda 5.5 engine
most push mower hold about one half of a quart put in a half and check it
Apr 26, 2012 | Troy Bilt 5.5hp Self Propelled Mower
I have a Troy-Bilt mower 5.5HP Model #:12A-264u011 While i was mowing it just died and when I pushed the primer it wasn't getting any fuel
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Aug 23, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I have a troy push lawn mower with a Honda engine. I have had it for 4 years now. The problem Im having and been going on for a couple of months, It wont start. Sometimes it will but i need to use carb...
Sometimes you can get by with priming it a few times, and letting it
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
When you clean your carburetor and remove the jet screws, count the
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
May 30, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Gcv 160 honda push mower stalls out after running for 5 min. i changed plug, drained gas and srayed carb. still stalls
Oct 23, 2009 | Troy Garden
Need to know how to change the oil in my Honda w/Troy Bilt motor 11A-542q711 w/overhead cam GCV 160.
Jun 06, 2009 | Garden
6.75 B and S push mower wont start.
Check the kill switch. It may be stuck in the off position.
Apr 26, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
131 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
