Question about Ovens
U it heats up great, stays running about 1-1 1/2 hrs then stops heating, replaced spark box didn't fix it, clean fans in back that cool controls or is it something else???
SOURCE: cleaned oven now won't heat
Probably what happened is during cleaning cycle the oven overheated the tco (thermo cut off). This is a thermo-fuse that is located behind the control board. It will need to be replaced.
Posted on Aug 25, 2007
SOURCE: Microwave stopped heating
I bought one built in Feb 2005, installed July 2005. Magnetron tube failed Feb 2007 - cost $127 labor to replace. Just failed again Feb 2008 - will cost roughly $135 to replace this time. Not good for such a high end machine!
Posted on Feb 20, 2008
SOURCE: My Dacor ECD230 stopped heating???
The high limit switch has tripped on this unit. Remove the vent panel behind the door and there will be a button in there behind the wires. Press this button with the circuit breaker turned off and that will rectify the problem. You still might need a servicer out to take a look at the unit though
Posted on Apr 04, 2008
ginko
  • 19396 Answers
SOURCE: oven won't heat
Unplug the power cord for thirty minutes, this should reset the oven.
If this still does not work do the following:
Press clean and then cancel. This will reset the appliance.
If the error does not clear , then during the self cleaning cycle, the high temperature has probably damaged the temperature sensor probe, and it must be replaced.
Posted on Dec 03, 2008
  • 41 Answers
There is a design problem with certain model Whirlpool ranges where the thermal fuse blows during self-cleaning (auto-clean). This may be because of inadequate insulation, causing the outer panel to overheat. When the thermal fuse is replaced, the range will work, but it will blow the next time auto-clean is done. To safely work around the problem, the thermal fuse may be replaced with a thermostat, which will reset itself once the oven has partially cooled off. If the part number of the thermal fuse is 9759243, it will blow at 120 deg C (248 deg F). This can be replaced to a Selco Part# SES-L250 thermostat. The terminals are perpendicular (90 degress), so they have to be bent to 30 degrees for the wires to fit behind the back panel.
Selco part# SES-L250 specs:
Surface Mount
3/4 in. disc
120/240 VAC
25 A
SPDT
open on-rise (normally closed)
open (cut-out): 250 deg F
close (cut-in): 220 deg F
temperature differential: 40 deg F
Info: http://catalog.selcoproducts.com/item/3-4-disc-thermostats/surface-mount-automatic-reset-open-on-rise/pn-5113?&seo=110
Available: Selco distributors: http://www.selcoproducts.com/distributors.php
and online at
Allied Electronics http://www.alliedelec.com
If the Selco SES-L250 'surface mount' thermostat is not available, an 'airstream type' thermostat can be used with a few differences:
1) I recommend to replace it to a 240 or 230 deg F thermostat. The reason for the lower cut-out temperature is that an 'airstream mount' thermostat will not be flush with the back panel, as is the original 250 deg F 'surface mount' one, so it may cut-out at a higher (unsafe) temperature.
2) I recommend to add Heat-sink compound between the thermostat and the sheet metal. This is used for computer processors and is available at computer and electronic component stores.
3) An 'airstream type' thermostat is thicker than the original 'surface mount' one, so longer screws will have to be obtained. The sheet metal tabs on the thermostat will bend slightly when installing.
4) The terminals are perpendicular (90 degress), so they have to be bent to 30 degrees for the wires to fit behind the back panel.
Recommended 'airstream type' thermostats:
Supco L240
Info: http://www.supco.com/images/pdfs/2009%20HVAC%20Caralog/2009%20Catalog%20for%20Web2.pdf
Available: http://www.appliancefactoryparts.com/applianceshvac/supco/crossref/thermostats2.html
Selco SE-L240
Info: http://catalog.selcoproducts.com/item/3-4-disc-thermostats/ts-3-4-disc-se-series-airstream-mount-open-on-rise/pn-5096?&seo=110
White-Rodgers 3L01-230
Info: http://www.white-rodgers.com/wrdhom/pdfs/06_Cat_pages/Cat_06_pg0092.pdf
General Electric LS2-240
Posted on Nov 03, 2009
Thermador smw 272 not heating via bake or convection. Light and fan work as well as broil and clean (microwave fine too). If I switch from broil and then to bake after heated, it will hit right temp and...
see if there is a bad solder connection on the bottom (underside) of the board just below one or more of the small black relay boxes. re-solder if you can or replace the whole board.
Jan 04, 2015 | Thermador Ovens
Oven heat varies
When you say it goes up and down by itself, what is the neon doing on the front panel. Is this switching off and on in relation to the oven heating and cooling? If it is, then it could be the thermostat sensor is dirty/covered in grease etc and giving false readings and will need a carful clean. With a fan oven, the fan should keep running, it is the element that the thermostat controls. If the neon stays on but the temperature varies, it could be a fault with the wiring. Does the fan keep running?
Jan 07, 2012 | Stoves Ovens
Oven will not stay heated. F1 light on.
Hello there:
on most ge models this code it can be either a (f 0) or the (f 1 ) is telling you that the the thermistor controle circuit is going bad or has failed all together. or there is a short in the erc circuit meaning the electronic controle board. ok
So i would recommend have a repairman check out the thermistor first since this is the most common thing to fail then if this passes have them test the controle board or the ecr circuit
and if the oven is still under warranty you might be able to use the warranty to get it fixed ok
Hope this is very helpful for you
Best regards MIchael
May 14, 2010 | GE JTP20 Electric Single Oven
Oven stopped heating - F34 displayed.
You get F34 error because there is excess heat within the oven.
You need to clean the cooling fan for any debris or dust, if this does not solve the problem replace the cooling fan.
Hope this helps.
Thanks for using Fixya.
Dec 15, 2009 | Thermador C301U Electric Single Oven
Middleby Marshall PS360 pizza oven won't maintain HEAT
sounds like the control cabinet overheated and the controller starts to break down at 140' F I would replace the controller and keep the cooling fans clean
Aug 06, 2009 | Ovens
Oven won't heat
Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
My oven turns off on me after only a minute never heating up fully
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
Jun 19, 2008 | AEG B1180-4 Electric Single Oven
GE: JTP56 F2 Door Locked displayed
I have the the same problem as discribed above. Does you oven fan go on for a long time after you use your oven during regular baking. Mine seems to stay on for 45 minutes after I bake anything. Can this be all tied together with the f2 problem? I am wondering if it is not just a fan circulation problem?
Dec 15, 2007 | GE Profile JTP56 Electric Double Oven
Oven cuts out after ten minutes and comes back after cooling down.
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
Thermador Oven won't heat after running self-cleaning cycle
SOunds like you need to reset the oven high limit switch. It should be located behind the grille obave the oven opening and below the control panel. There should be about 4-6 screws you need to take out to remove the grille to gain access. Turn the power of to the oven at the circuit breaker, then rech in with a screwdriver and push down on the little red button in the center of the hig limit until it clicks. the high limit should be about as big around as a quarter and have a wire going into one side and out the other. If this keeps tripping, you may have a bad cooling fan. When you run a self clean it should also run a fan to cool the components. You should be able to feel a breeze coming out of the bottom of the oven when the cooling fan (not the convection fan ) is running. If this fan doesnt run, it will trip that switch. Hope this helps!
Dec 08, 2006 | Thermador C301U Electric Single Oven
Ovens Logo
82 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
