Question about Blue Chip Sim Free Bluechip Neon Android Smartphone
HOW DO U FIX BLUECHIP FILE ERROR RESTORE DEFAULT?
I can't create a new folder with windows 7
Downloading and merging the .reg files for the listed directory and folder options in the tutorial below should be able to fix this for you. It will restore their default associations and registry entries.
Default File Type Associations - Restore
Jul 30, 2013 | Office Equipment & Supplies
Hi, Dave again - not sure if my problem was visible or not?
you may try to fix it by doing this:
http://www.sevenforums.com/tutorials/19449-default-file-type-associations-restore.html
If it does not help, reply and I will give you further instructions.
Mar 29, 2013 | Lenovo Computers & Internet
Bluechip mobile file error-restore default will not shutdown unless u remove battery
Hi, did you manage to find a solution to this issue? The mobile i got for my grandmother is doing the same thing, can i cannot find anything in the user guide? Thanks
Nov 24, 2012 | Cell Phones
Bluechip mobile phone bc5c user manual
I have a blue chip bc5c mobile,there is an error message ::
File error, restore default,how do I fix this
regards aga
Jul 13, 2012 | Cell Phones
Error code on ps3......will load regular dvds but not games or blu-rays.....code 80010514 pops up
that error is caused by a bad section on your hard drive or a bad installation of firmware, the first problem also causes the later so its usually both. you can fix this problem by formating the hard drive and reinstalling the firmware, but you will lose all your data and saves this way unless you back them up. you can however fix this another way, by accessing the play station's recovery console.
You access it by
1. Start with having the system in standby (redlight is on)
2. Hold the power button down; the system will turn on and turn off once again.
3. Press and hold the power button again and keep holding, it will beep as it turns on and then it will double beep. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
4. You will be prompted to plug in your controller via USB and then hit the PS button
You will now have a screen with these options (I have attached a picture of this screen below)
1. Restart System: Restarts the Playstation System.
2. Restore Default Settings: Reset all system settings back to default.
CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files.
4. Rebuild Database: Rebuilds the OS for the Playstation.
5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
6. System Update: Update the Playstiation System
IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive is option 3: RESTORE FILE SYSTEM
I REPEAT CHOOSE RESTORE FILE SYSTEM
if you chose restore file system just follow the prompts and your blue ray drive should work again.
Jun 12, 2011 | Video Game Consoles & Games
Restarting very often
try restoring settings of you phone. navigate to settings and find restore factory settings, when selected it might ask for your security code, the default is 12345, if you havent changed it yet.
if the problem isnt still solved that way try this
Normal Reset
Using the *#7780# sequence.
It will restore ini files from ROM keeping all your data (themes, 3rd party applications, video, photos, and music files)
Deep Reset
Using the *#7370# sequence.
Completely format phone memory. Default files are cleaned up and rewritten.
Note that data found on memory card will not be altered
Jun 06, 2010 | Nokia E63 Cell Phone
Error 0XC000000C and 0XD000001E and 0XA0000001 how would I fix these errors its on a Aspire 5315-2153 Notebook did have Window Vista as OS I tryed the backup disc I made 1-9 error OXC000000C on disc 7 I...
My 0xc000000c "Restore Failed" prompt seemed to be the result of disk surface damage on the restore disk. After burning the restore disk to a new disk, the restore proceeded normally. Try making a copy of the original restore disk to a known good blank disk.
Jul 20, 2009 | Computers & Internet
I have been getting error code -6000; -83. What
Might I suggest going to the Getsatisfaction website. I have provided a link that will direct you there.
http://bit.ly/7ebRo
You can use OpenID, Windows Live/Bing, or create a new username.
Hope they can help you out.
Jun 05, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Blue Chip Sim Free Bluechip Neon Android Smartphone Logo
42 people viewed this question
Top Blue Chip Luggage & Travel Experts
Dave braun
Dave braun
Tom Chichester
Bobby Lewis
Bobby Lewis
Are you a Blue Chip Luggage and Travel Expert? Answer questions, earn points and help others
