Question about Dishwashers
Bosch she68t52uc with no lights or reset available. It appears it was interrupted in the middle of a cycle because there is water at the bottom.
I have power at the plug and there is no response with the reset. Does the water need to be drained before I can get a response? It's less than 1 year old.
    Top Expert:
  • 10,875 Answers
Call for repair service under warranty
Posted on Apr 24, 2015
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
E1 code. water is being pumped out dry and start dryer and 3-5 min code comes back. cleaned everything inside checked all hoses and switch. everything looks fine
Cycle is interrupted and ''E1'' appears in display.
Condensate hose is blocked in some way. Turn off dryer and check hose.
Condensed water not pumped out (WTL 54 condensation models only). Pump failed.
25808741-gtkp3url2ghtdqenstp5bokb-1-0.jpg Dado
Aug 04, 2015 | Bosch Axxis WTL 5410 Electric Dryer
WTL 5410 getting E1 error message. Condenser hose seems unblocked. Pool of water behind the heat exchanger
Dado
Jul 02, 2015 | Bosch Dryers
Bosch Diswasher SHE68T52UC
Error code 08 says it's a temperature sensor problem. If the temp sensor is bad, the water heater may not be getting the water up to a hot enough temperature to dissolve the soap block. Also, while you have the unit out for repair, make sure that the drain hose is clear of debris. I have seen a number of dishwashers lately that were replaced simply because they "weren't cleaning" or "draining slowly" where the only problem was a blocked drain hose.
Feb 21, 2014 | Dishwashers
She68t52uc flashing light which says E:15 and watertap
Not sure if this will definitely work, but i do believe this is a flood safety device. Try removing the drain pipe from the waste pipe, into a bucket or bowl, and empty as much water out as you can, then, with the pipe on the floor (will get wet), tip the top of the dishwasher backwards about 45 degrees, and hold for a few seconds. It may be that water/suds are still in the bottom of the machine, or the dishwasher detected this.
Dec 26, 2013 | Bosch Dishwashers
What is E25 on my Bosch super silence dishwasher?
I quote same wrong from other user:
Question: Model dishwasher is Bosch Exxcell SMS50E02
It stopped before the end of a cycle with the error code E:25 and the "check water" light came on
I mopped out all the residual water out of the bottom and then ran a rinse cycle, which after several trials I got to work and then it stopped at the end again with the same error code and water in the bottom as before.
Answer:
I assume by in the bottom you mean inside the dishwasher and not in the base.As long as there is no debris in the sump area and the hoses are clear it appears you have a bad drain pump.
Hope helps.
Apr 03, 2011 | Dishwashers
A key has appeared in the electronic window and a zero for the duration of the programme. This happened after completing a wash cycle which was interupted and changed a short time into the wash cycle.
This is a "child lock" notification. It was probably triggered by the interruption.
See your manual to reset the child lock. If you see the child lock button, press and hold it for 3-5 seconds and it should beep to reset.
Nov 03, 2009 | Bosch Washing Machines
Washer will not start. Lights come on, but nothing else happens.
I have a Bosch Dishwasher, SHU6805UC/U06, During a cycle it was interrupted by opening the door. It was left open for an hour. When the door was closed again the lights came on but the cycle did not continue. The motor did run but no water was rushing. Power interrupted to the machine did not enable it to reset or restart. How do we get it going again?
Mike,Laurie,& Dory
Apr 15, 2009 | KitchenAid Dishwashers
Bosch DLX series didn't drain, now no power
I had a Bosch DLX series dishwasher that had multiple problems.
First, it had greyish water in the bottom and pushing the power button did not turn on any lights. it had mostly finished a cycle, but not quite. my first thought was to clean it out. i sponged out all the water and removed and cleaned out the filters from the bottom which were all quite nasty. i found food, tiny bones, etc. I cleaned it out and that did nothing but was still probably the cause of the problem. I called Bosch tech support and asked about areset switch. There is none. They told me to switch off the circuit breaker for 30 MINUTES to reset everything. I did that which did not fix the problem.
I then examined the connector wires (connecting the electric to my house wiring) which are in the front under the kick plate, and discovered that they had MELTED! The wiring supplied by Bosch was stranded wire, and my home wiring is solid core. i trimmed the burnt stuff and reconnected it with new wire nuts. if this happens again i plan to disassemble the dishwasher's electric and replace the stranded wire with the good stuff.
That restored the electric and the lights and display. i then ran a test cycle and it seemed to just hum. my guess after googling a bit was that the float was stuck in the up position, and it was trying to drain. This site http://www.applianceaid.com/boschDW.html told me how to run the test mode.
"To start test program, press and hold both POWER SCRUB PLUS and REGULAR WASH program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button."
The test mode tested out all functions which I think wound up reseting the float switch which actually fixed the rest of it.
Sep 01, 2008 | Dishwashers
Dishwashers Logo
237 people viewed this question
Top Dishwashers Experts
Owen Barnes
