Question about Nikon COOLPIX S6800 Digital Camera Black
How to repair my camera giving a lens error - Nikon COOLPIX S6800 Digital Camera Black
    Problem Solver:
  • 9 Answers
Copied from Nikon's Service & Support Page:
Having a "Lens error" message display on the camera's LCD display indicates a problem with the camera lens mechanism. This situation generally requires that the camera be sent to a Nikon Service Department for repair. Before doing this however, be sure to check these situations below:
  1. One possible reason for this error is if the camera is switched on and the lens unit is prevented from extending. The camera will struggle for a second to extend the lens, then report the problem. Inspect the lens for any obvious obstruction, then turn the camera off, then on again. Usually, simply switching the camera Off then On again is enough to correct this problem.
  2. Remove and recharge the battery. Retest.
If this does not help, then we regret the camera must be sent to our Nikon Service department as there are no user serviceable parts on Nikon Coolpix cameras.
To find your local Nikon authorized service agent Click Here.
We apologize for the inconvenience and will do everything we can to repair your Nikon camera as quickly as possible.
Posted on Jun 23, 2015
3 Suggested Answers
  • 11967 Answers
SOURCE: Camera is telling me lens error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 23, 2010
  • 11967 Answers
SOURCE: is lens error frequent problem with nikon cameras.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Posted on May 08, 2010
Lens error restart camera
Most digital cameras, with zoom lenses, will generate an error, when the lens can't move freely. If you manually stop it, it will give the same error. The camera will retract the lens and generate an error. But if a mechanical error causes the lens not to operate as it should, you get the same error. The camera stops to prevent greater damage. If you can see anything that obstructs the movement of the lens, try to remove it. If you can't see anything, you have to fear something inside the camera is defect and only can be repaired by a technician. Just consider if it is worth paying for a repair, when new camera's are becoming cheaper by the day.
Jan 18, 2014 | Canon IXUS 80 IS Digital Camera
Tip
Lens Error fix for Digital Camera
One of the mostcommon digital camera error messages has to do with a lens problem.Some cameras will just beep and not show any error message and otherswill have an error message on the LCD screen. Some camera's will try tostart, the lens will go out and then return back and shut down.Sometimes nothing at all will happen, but the lens is the reason whythe camera will not start up.
Different camera'smay give you different error codes. Some of the error codes will beE-18 for older Cannon camera's, ACCESS error for Sony, Zoom Error forFuji, lens error restart, or just plain lens error. These are themost common camera error messages, but your digital camera may have a different one.
There are manydifferent things that can cause the lens to give an error message.One of the most common causes is keeping the camera in a case or bag.The dust, grit, felt, and lint from the bag gets into the cameralenses and causes it to jam. The static electric from the camerarubbing the side of the case causes the dirt to be attracted to thelens, which makes the problem even worse. Also if your camera is in acase and the button gets pushed to turn the camera on, and the lenscannot extend it can cause the lens pins to come out of the track,causing focus problems and lens errors. Bottom line is that you areoften better off not keeping your camera in a case! It is saferwithout a case then with one.
The next problemthat many people encounter is that they drop or knock the camera withthe lens out. When this happens, the lens pins can come out of thetrack, and/or the lens can be knocked sideways, which will jam thelens as it tries to extend and/or focus and zoom. If you do drop orbang your camera against something, there is about a 50/50 chancethat it can be fixed. Many times with care the lens can be realigned,but in some cases the jarring or the realigning, will break somethinginternally, so there will be no fix for it.
If your digital camera hasa problem, you will have a couple of choices. You can try to fix ityourself, or you can try to find a camera repair shop that will fix it for you.Because of the type of problems that cause lens errors, the digital camerarepair will seldom be covered under the manufacturer warranty. Alsobe careful to get a quote from a digital camera repair shop before youauthorize the repair. Many times the repair price quoted will be morethen the replacement cost of the digital camera. If you do a search on theinternet for a camera repair shop, make sure to include any shipping andhandling costs in the repair price.
If you choose totry and repair the camera yourself then look for my tip - Steps toRepair a Digital Camera Lens.
This gives you thehow and why of your digital camera error message, and/or why your digitalcamera will/may not start up.
Steps to Repair a Digital Camera Lens
How to easily download Pictures from Digital Camera
How to Unlock SD Card
Digital Camera Manuals, Drivers, Downloads, and Support
on Apr 26, 2011 | Cameras
When we turn on our Sanyo VPC E1090 digital camera the lens does not appear to come out completely & we get an "lens error 0x0311" message on the screen then it turns off. WHAT IS WRONG!! ...
If lens does not appear to come out completely and camera gives error that means lens mechanism got broken internally and lens assembly will be replaced to solve the issue.
Lens replacement is not user level repair and local camera repair shop[ will do this job for you if camera is out of warranty.
Thanks.
May 28, 2011 | Sanyo VPCE1090 Digital Camera
Lens won't retract
Lens probably does not extend or retract because of debris or a misaligned gear box. The lens can in about 50% of the cases be repaired without having to replace it. Try to return to manufacturer first. If you're out of warranty, there are third party place that fix them such as camera lens repairs. If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Jul 07, 2010 | Kodak Easyshare M753 Digital Camera
Dropped the camera, getting a lens error 115,0,0,212
Lens probably does not extend or retract because of a misaligned gear box. The lens can in about 50% of the cases be repaired without having to replace it. Try to return to manufacturer first. If you're out of warranty, there are third party place that fix them such as camera lens repairs. If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Jul 05, 2010 | Kodak EasyShare C613 Digital Camera
Lens error.restart camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Apr 06, 2010 | Canon PowerShot A75 Digital Camera
Lens error. Restart camera.
this is very common has the camera been near the ocean??? it does not have to be dropped to give you this error. repair on you lens runs 85.00 for repair. or a new lens for 125.00
Jun 25, 2009 | Canon PowerShot SD1100 IS Digital Camera
Lens Error
well don't play with ur lens on ur own give it to the ppl they will repair ur lens and give them a phtocopy of ur warranty card.
But yes if the problem persists thats is the test they do after repair they might cahe ur camera .....But there are slime chances for an exchange
Jan 05, 2009 | Nikon COOLPIX L18 Digital Camera
Lens Error, Restart
Hi
What you are seeing is a generic stuck lens error message, turning off the camera and turning it on again will not fix the lens unfortunately.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from....
Darntoothysam com
May 01, 2008 | Canon PowerShot SD1000 Digital Camera
Nikon COOLPIX S6800 Digital Camera Black Logo
129 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
