Question about Airaid Air Filter 91-06 Lincoln Town Car
What are part names for rearaxle and brake assemblies
    Top Expert:
  • Airaid Master
  • 10,875 Answers
Rear axle and brake assembly,,,,,brake pads rotors,drums,calipers,lines
Posted on Apr 24, 2015
How to install rearaxle on frame?
I think if you don't know you should not be doing it
Oct 08, 2014 | Cars & Trucks
08ultrarearaxle torque
Rear axle cone nut 95-105 ft-lbs 129-142 Nm
Jul 07, 2014 | 2005 Harley Davidson FLHTCUI Electra Glide...
Where is the break light switch located on a 2003 linciln aviator?
Hi, welcome to FixYa.com my name is Shawn and I will be answering your question.
The brake light switch is located on the brake pedal assembly.
I hope my assistance helped you and resolved your concern, if you need further assistance please ask.
Aug 08, 2011 | Lincoln Aviator Cars & Trucks
Where are the fuel filters located
Location of fuel filter. The fuel filter islocated on the bottom of your car's passenger side just in front of the rearaxle.
Mar 01, 2011 | 1998 Volvo S70
When I removed the four bolts holding the brake pad assembly, the longer bolt pulled the threads out Where do I get a replacement bracket ? Also what is the proper name for it ?
This would be the caliper mount that holds the brake caliper and it holds the brake pads. cheapest salvage yard if not try rockauto.com
Feb 16, 2011 | 1988 Toyota Pickup
Could a rearaxle leak cause my reverse not to work on my 2000 chevey blazer?
reverse is controlled in your transmission, the rear diff is responsible for changing the rotating motion of the drive shaft into directional rotational motion to turn your axles
Apr 07, 2010 | 2002 Chevrolet Blazer
Remove and replace rear brake shoes on 2004 honda accord
Brake Shoes Removal & Installation To Remove:
  1. Raise and safely support rear of vehicle.
  2. Remove rear wheel assemblies.
  3. Release parking brake.
  4. Remove brake drum.
Rear brake shoe assembly
  1. Using an appropriate brake spring tool, unhook upper return spring from rearward brake shoe.
  2. Push retainer springs IN and turn to remove tension pins.
  3. Lower brake shoe assembly and remove lower return spring.
  4. Remove brake shoe assembly from back plate.
  5. Disconnect parking brake cable from lever and remove brake shoe.
  6. Remove parking brake lever from brake shoe.
To Install:
  1. Install parking brake lever to rearward brake shoe.
  2. Secure lever to brake show with a NEW U-clip.
  3. Pinch U-clip closed.
  4. Connect parking brake cable to rearward brake shoe.
  5. Install self-adjuster lever spring on front brake shoe.
  6. Assemble clevises, adjuster bolt and upper and lower return springs.
  7. Apply a light coat of grease (Molykote 44MA or equivalent) to sliding surfaces.
  8. Install brake shoe assembly onto back plate.
  9. Install tension springs.
  10. Using an appropriate brake spring tool, unhook upper return spring to rearward brake shoe.
  11. Install brake drum.
  12. Install rear wheel assembly.
  13. Lower vehicle.
  14. Adjust self-adjusting brakes by pressing brake pedal several times.
Jul 13, 2009 | 2004 Honda Accord
Bulb repair....
Hi my name is Allen!
Here is how to change the brake light bulbs, first pull the carpet down that runs up the back covering where the light assembly is installed, next grab the wing nuts, they are black in color, they are designed so you can turn them with your fingers, remove all of them, then pull straight out with the brake lamp assembly.
After the assembly is removed, grab the socket on the back with the wires coming out of it and turn it counter clockwise and pull it straight out, then grab the bulb and pull it straight out and push the new one back in, that's it.
For further assistance contact me at FixYa!
Jan 01, 2009 | 2001 Chrysler Sebring
Replacing third brake light assembly
I dont think my third light has a bulb it looks like its conected to a black power supply i need to whats the name of it so I can get another one
Sep 09, 2008 | 1997 Ford Explorer AWD
Airaid Air Filter 91-06 Lincoln Town Car Logo
Top Airaid Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you an Airaid Heating and Cooling Expert? Answer questions, earn points and help others
