Question about Radio Communications
My tecno is not producing sound but when i insert the headset it is sounding, what can be the problem then?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,745 Answers
Make sure that your output is set to (external) speakers; make sure that your speakers are connected; make sure that speakers are working (by connecting to the other renderer)
Posted on Apr 24, 2015
When i try to connect my genius hs-03u's to my ps3 it doesnt work is there any way to make them connect
First, examine the connection receptables on the PS 3. For example, inserting the head set pin into wrong PS 3 connection receptable would not produce any sound discussable.
1. The PS3 device has several connection receptacles either for video audio output or video audio in put.
2. Video audio out put only gets sound and movies out of the PS3 device to be projected on to another device, e.g. projector, TV screen or Any out put devices.
Note: You solution is to connect the headset to the out put indication area keeping in mind not to connect to the Video receptable, else would be trying to output video signals to the headset.
Caution: You do not want to connect the headset pin to the Video Audio Input receptacle areas, because, you would be trying to send signals into the PS3 device rather than get sound out.
Important Notes;
Getting signals out of a device like PS3 is inserting the headset in this case, pin connector would be inserted in the INPUT Area; keep in mind your are tryinng to hear sound, SO connect the HeadSet PIN to AUDIO reception area on the PS3 device
The same techniques is achievable for all equipment requirign connection.
REMEMBER TO PHYSOCALLY LOCATE THE INPUT to OUTOUT area on the device.
Give the following proccess a try.
contact the manual of the PS3 device refering to the device connectivity chapters or
Systems diagnostic or malfunction chapters for technical material when required.
Dec 02, 2010 | Genius HS-03U Headset
One headphone is not working. no sound is coming.
pull the plgu of your headset partially from the jack play around it until the other headphone produces sound if this happens it mieans that the Audio port your using is either malfunctioning or you can try youy headset with an MP3 player or any audio device that uses a headset to find out if it is the headset that is damaged
Jun 05, 2010 | Bose QuietComfort 3 Acoustic Noise...
My V3m was dropped yesterday on concrete. It now
I think that the headset pin/port is shorted inside. And your headset is inserted. So it produces now sound.
Or
the ear speaker is damaged for sure.
I hope this helped...
Jan 06, 2010 | Motorola Mobility RAZR V3m Cellular Phone
CD drive clicking sound
Hello my friend please try to insert 2 new CD. and then try to observe the sound if it is still sounds like the weird. Then if you notice that the 2 new CD you insert produce same sound as your old one then i recommend that if you can find computer technician in your place to verify if your DVD/CD Rom is defective or not cause as of now if the 2 new cd inserted produces same sound as your old cd inserted then DVD/CD Rom has something to do its either defective or has a serious problem that needs assistance.
Thank you
Jul 30, 2009 | Computers & Internet
Clear chat mic doent work
in skype go to tools>options>audio setting make sue the microphone is logitech and the green bars should start moving as you talk.
if no logitech appears or the mic is not producing sound. call logitech for warranty info. if the mic is producing sound below is "make a free skype test call" to see if the program is transmitting.
Jul 18, 2009 | Logitech ClearChat Stereo Headset Headset
Well my headset was working now its not
test in another program and see if iit work there if no other program exist try the sound recorder.
if no sound is produced call logitech for warranty info.
Jul 04, 2009 | Logitech ClearChat Stereo Headset Headset
Sound
the potential cause for this is that if you load up IE or FF with the headset plugged in, IE/FF will load up the sound via the USB, but if you remove the headset, IE/FF is still trying to relay your sound though the USB and not the speakers. This is not a design flaw with the headset but rather with windows. This happens to me with every program that uses sound. And also to note that even though you plug the headset back in, it has a good chance of loading onto a different address then what was used by IE/FF initially. You can see how this works also by leaving your headset plugged in, with IE or FF open (so that the sound is through the headset) then go into your control panel > sound options, and under the playback tab select your speakers rather then the headset. you will see that you lose your sound until you restart IE/FF.
May 20, 2009 | Logitech ClearChat Pro USB Headset
Philips SHM3300 Headset
try to unplug your main speakers and replace the head phone, if it still doesn't produce any sound, then you may replace your head phone.
Oct 30, 2008 | Philips SHM3300 Headset
Labtec headphone how to get it to work.
Sometimes you need to "burn in" your headphones. Used headphones usually produce a better sound than new ones. Simply let it play some music continuously. I usually burn in my headphones with some AM/FM static.
After a while, the sound should improve.
Feb 10, 2008 | Labtec 342 Headset
Radio Communications Logo
52 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
