Question about AEG Ovens
I want to put back my wires to grill element how on AEG E4100 1 OVEN
THERE IS TWO WIRES WAT IS JIONED TWO GETHER GRAY AND BROWN WIRE GREEN WIRE AND PURPEL WIRE WICH GO WERE
    Master:
  • AEG Master
  • 480 Answers
Unfortunately, this isn't a wiring diagram but can also serve.
See the pictures below:
i want to put back my wires to grill element how o - 25662853-wjkdtau3hzetwygkyoujq3j4-2-0.jpg
Dado
Posted on Nov 07, 2015
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: replacing heating element in a built in aeg fan oven
Simply pull the wires off, and replace onto new element, it does not matter which wire goes on the terminals, as they are common.
Plz rate my solution.
Thanks.
Posted on Jan 13, 2009
pride applia
  • 232 Answers
SOURCE: St George wall oven element. which wire to connect
green is always grounded
Posted on Dec 24, 2009
Fitting new top element
I take it you didn't note where they went before? The web is full of handbooks spare part diagrams etc. Various F & P sites as well. Have a dig around for your model. Which you didn't tell us by the way??
Mar 30, 2015 | Fisher and Paykel Ovens
Element for bottom fan forced oven wiring, I have a blue and green wire, should there be a third wire?
You should have 3 wires, the green is the earth. The other two would normally be blue and brown. If you have tried to change the element the missing one may have fallen back in or it could have been burnt off the element terminal and fallen down the back. Anyway you may have to remove the rear of the oven to locate it.
Feb 10, 2011 | Fisher and Paykel OS302SS, Stainless Steel...
HI I have a Beko Electric oven (model SCC 2632). It has a combined oven and grill element which i redently had to replace. Fitted it no probelm, but when it came to attaching the coloured wiring spades...
Have a beko scc 2632 cooker. Need to know the colours of wires fom left to right of grill/oven element as it is different than the old element?
Jan 29, 2011 | Ovens
My AEG oven does not heat up, nor does the grill work. The oven light and fan comes on when selected but the light located with the temperature control dial does not illuminate. This light normally...
DearDavidgale730,
I am supposing this oven/grille is electric, and is plugged in to a power source.
From your description, I'd say you have a serious problem and should no longer consider turning on the oven or the grille.
Having made that decision, take an electric meter and test the socket or wires that connect the stove/oven to the wall.
See if the current is flowing in both legs of the plug.
(Remember, two are "Hot", one or two are grounded.)
If not, correct the problem with the fuses or circuit breakers that are feeling the appliance.
If so, open the appliance up and test all circuits with that electric meter to determine the problem.
Often the problem may be a bad socket for the oven heater element, a bad element itself, or a burnt wire going to the element socket.
God bless your efforts.
Jul 04, 2017 | AEG B8139-4-M Electric Single Oven
Baumatic oven not heating up. Grill and fan fine.
if it is the b180, the answer (having just fixed this) is really simple.
The coily bit is the oven element - it will have gone. A new one from eBay cost me about 6 quid.
[WHEN IT ARRIVES !]
Turn the power off.
Inside the oven use a philips screwdriver to remove the 4 screws (KEEP THEM !)
You will see a coily thing and a fan.
You unscrew 3 more screws (2 on the left and 1 on the right).
(KEEP THESE TOO!)
now ... bit tricky, have the new one inside the oven and take each wire off one at a time and put it on the new element.
Screw it back on but DONT put the last panel back in.
Turn the oven on maximum for about 2 minutes and see it glow red.
Turn the oven off. Make a cup of tea and have a couple of biscuits while admiring how good you are and waiting for the element to cool down!!!
Put the final panel back in place. Whole thing (including a cup of tea) takes about half an hour.
Jan 27, 2010 | Baumatic B180 Electric Single Oven
Aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Thanks
Jan 27, 2009 | AEG B2100-4 Electric Single Oven
Replacing heating element in a built in aeg fan oven
Thanks.
Jan 13, 2009 | Smeg SE399X/5 Stainless Steel Electric...
AEG U7101-4 Top Oven tripping the fuse after a few minutes
It is more than likely the oven element, as it gets
hotter the insulation in the element is breaking down and causing the trip to operate..
Remove the panel at the rear of the oven and you will see the element there, undo the screws and pull the element towards you, carefully, detach the 2 wires and remove the element.
Be careful not to lose the 2 wires behind the oven rear.
Replace with new element.
Cannot give you a part number, you will have to go to aeg web site.
Dec 12, 2008 | AEG U7101-4 Electric Double Oven
What wire goes where for my Westinghouse Freestyle elements?
oven wiring has the same conventions as house wiring.
green = earth, outside coating
brown or white = one of core ends
black = the other end
Jul 13, 2008 | Ovens
Ovens Logo
83 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Samyfam
Samyfam
Are you an AEG Oven Expert? Answer questions, earn points and help others
