Question about Cell Phones
Phone for listening device - Cell Phones
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Cell Phones Master
  • 1,745 Answers
So what's the question?
Posted on Apr 24, 2015
How to connect motorola h350 bluetooth device for listen the music in our android phone
Go to Settings on your phone turn on device as you start your Bluetooth on your phone. They should find each other and pair automatically but if they don't, turn off the device and then on again then immediately touch "scan" on your Bluetooth setting on your phone. If a new device shows up after scanning under "available devices" touch the new device name and it should pair. Good luck!
Aug 05, 2017 | Motorola Radio Communications
Tip
How to connect Bluetooth GPS using mobile phone
<p>Once I explain how Bluetooth GPS receiver to connect from a mobile phone. Bluetooth GPS Receiver is a device that continuously transmits its position (longitude, latitude and speed) using the Bluetooth protocol. If your phone is Bluetooth-enabled phone, you can connect to a Bluetooth GPS receiver to determine its position. To locate, connect to Bluetooth GPS and mobile phone to get the NMEA sentences for location tracking, you can also program a Java (J2ME) for your phone. Your program should do the following tasks: <br /> <p><br /> <p>1. Bluetooth device within the search area. Each time a Bluetooth device is discovered, discovery listener device Discovered trigger procedure. In the search is completed, the trigger listener discovery process inquiry Completed. <br /> <p><br /> <p>2. Get the name Bluetooth. We have a choice to a group list of Bluetooth-friendly name of the devices found to store. We also need a vector to devices found to store. <br /> <p><br /> <p>3. Select Bluetooth GPS receiver from the list of found devices. <br /> <p>4. Find service by the GPS device. Bluetooth GPS Receiver provides an L2CAP service so that the program needs to find this service for GPS url connection string for. <br /> <p><br /> <p>5. Get connection string from the GPS device. Connection string to the URL will have this format Url = "btspp: Address / bluetooth /:" + + L2CAP_UUID "permission = false; encrypt = false"; <br /> <p><br /> <p>6. Sign up and receive sentences from the GPS device. After plugging in the url in step 5, you can open the connection and extract sentences from the connection string. <br />
on Jun 26, 2011 | Cell Phones
Someone had my phone and I need to know if listen devices and cameras were put on my phone.
take it to a phone repair shop and have it checked out
there are tracking programs that can be put on the phone that enables 3rd parties to listen in as well
Jun 23, 2015 | Cell Phones
Motorola h15 bluetooth listen to music on android phone
This headset only allows for handfree profiles. You need a bluetooth stereo profile or A2DP profile. I'm afraid you can't listen to music using this device.
Dec 18, 2011 | Motorola Cell Phones
How do I pair my phone to my blue tooth
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Jun 21, 2011 | Jabra Bluetooth Headset with Adjustable...
I want to listen to music on my phone with my bluetooth headset
iIn order to listen to music on your blue tooth headset you first must pair them to your phone,To do this you first must turn the power to blue tooth to on in your phone menu,then you will have to put your blue tooth device into discovery mode,most bt manufactures use the power button for this feature,when turning your headset on continue holding down the power button for 6 to 10 seconds and a light should stay on ,thus putting your bt device into discovery mode thenfrom your phone you can search or add new device,it should recognize the device and ask for a pin or pairing code.Most manufactures use a factory 4 digit pin pairing code,they are as follows 0000,1234,9999,or 1111,once your code is entered they should pair,then you will be able to use your blue tooth device to listen to music.glad to be of assistance
Feb 26, 2011 | Radio Communications
Can't listen to my voicmail
Click on a left side link of download manuels. ------------ 40000 series DS4122-4 ------------ 50000 series cs5121-4 ------------ i6785 English Not sure what series you have, but take a look at these manuels. found here :http://www.vtechphones.com/vtechui/support/manual_list.cfm#214 if not anyof these listed- there are many others to view and I know you'll find right instructions here!! Let me know if this helped.--Stevie ----------------------------------- 5.8 GHz Digital four handset cordless phone system with digital answering device and caller ID ------------------------------- 5.8 GHz digital Four Handset Cordless Phone System with Digital Answering System and Caller ID --------------------- 5.8 GHz Digital four handset cordless phone system with digital answering device and caller ID i6785 - Spanish 5.8 GHz Digital four handset telephone system with digital answering system english i6786 5.8 GHz digital four handset cordless phone system with caller ID and digital answering device i6786 - Spanish 5.8 GHz digital four handset cordless phone system with caller ID & digital answering system
Feb 14, 2010 | Vtech 5.8GHz Cordless Phone with Digital...
LG KP500 and Plantronics 260 steroe bluetooth music
want to use a Plantronics pulsar 260 headset to listen to music over bluetooth played on LG KP500 phone. After pairing the devices what settings do I need to change on the phone to make it play stereo music over bluetooth to the headset?
May 16, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
I cant listen to music connecting my bluetooth
check out that is the phone's bluetooth is properly paired with the bluetooth headset if not check it
or
search for the bluetooth devices from the search list of the bluetooth devices in the bluetooth menu of your phone
Mar 09, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
