Where can I take A card 10 stack CD DVD duplicator for servicing or repair . I live Ballan vic so who where would be closest
Only 5 of 8 brain burn athena
Hi THERE, This model is now discontinued.
The replacement is DUP-DP-AS3-11B.
*NOTE: Item is not compatible with LG GH22LS30 (Directron part number DVR-GH22LS30)
Now you can easily build a Blu-ray duplicator with the Athena SATA Blu-ray controller. SATA interface simplifies cable management comparing to IDE with narrower cables and smaller connectors. SATA interface supports cables as long as 90cm without sacrificing data integrity and system reliability. Hence Athena SATA controller can be installed on the top drive bay even in an 11-target tower duplicator. Maximize your productivity and efficiency today with Athena SATA Blu-ray controller.
Features:
  • Standalone, no PC required.
  • DDR2 Technology allows up to 8x Blu-ray duplication.
  • SATA Advantages - Thin cables for easy routing and improved cooling inside the duplicator chassis, increasing product reliability.
  • Dynamic Hard Drive Partitioning automatically adjusts hard drive partitions based on the size of your master disc.
  • Master Error Proof prevents duplication failures caused by disc errors. Simply exchange the failed master disc with a working disc without interrupting the duplication process.
  • Dual-Level Security provides separate Startup and Setup passwords for complete restriction and protection against unauthorized users.
  • Advanced Diagnosis Mode troubleshoots and sets adjustment for optimal performance.
BACK TO TOP
Specifications:
  • Operating Type: Controller only
  • Internal Interface: SATA
  • Targets: 11
  • Reading Speed: 18x DVD-ROM
  • Maximum Writing Speed* (*Actual write speed depends upon media and drive specifications) : BD-R SL: 8X BD-R DL: 4X BD-RE SL: 2X BD-RE DL: 2X DVD+RW: 8X DVD-R: 20X DVD-RW: 6X DVD+R: 20X DVD+R DL: 8X DVD-R DL: 8X CD-RW: 32X CD-R: 48X
  • Supported Disc Formats: BD ROM, BD-R, BD-R DL, BD-RE, BD-RE DL, DVD ROM, DVD-R, DVD-RW, DVD+R, DVD+RW, CD-DA, CD ROM, CD-R, CD-RW, Multi-session Photo CD, CD-I, Video CD, CD ROM XA, & CD Extra (CD Plus)
  • Supported Recording Discs: 12cm 25GB BD-R 12cm 25GB BD-RE 12cm 50GB BD-R DL 12cm 50GB BD-RE DL 12cm 4.7GB DVD-R/RW 12cm 4.7GB DVD+R/RW 12cm 8.5GB DVD+R DL 12cm 8.5GB DVD-R DL 12cm 80min / 700MB CD-R 12cm 74min / 650MB CD-RW 8cm 1.47GB mini DVD-R 8cm 24min / 210MB mini CD-R 8cm 50MB Business Card CD-R
  • System Buffer: 128 MB (Optional upgrade to 512 MB)
  • Hard Drive Supported: Up to 1TB (optional)
  • Power Adapter: Input: 100 ~ 240V AC Output: +5V DC, 3.8A
  • Operating Temperature: 40oF ~ 95oF
  • Operating Humidity: 20% ~ 90%
  • Regulation: FCC, CE, RoHS
Aug 27, 2011 | Athena SATA CD/DVD/Blu Ray Duplicator...
Acard duplicator - 'Source drive not ready'
> source drive not ready
When you push the button to open/close the drawer, does it work,
i.e., is there electrical power reaching the drive?
Did you put a disk into the "source" drive?
Is the same disk recognized when you put that disk into any other computer?
If so, then the "source" drive is damaged, and needs to be repaired/replaced.
Jul 18, 2011 | Acard Technology 15 CD DVD Duplicator...
I have a Go-video duplicator P/N S52-3-H how may i obtain a manual
From Google .. Download Tower CD&DVD Duplicator 8 Bays Manual.. But You May Have to ente the Brand and Model good luck
Oct 07, 2010 | Tower CD&DVD Duplicator Cases: 8 Bays...
TEAC DVD Duplicator copies CD but not DVDs
your DVD ROM's lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD ROM clean the dust in it & it will start working agaain but be careful remember that no power should be attached to ROM.
pls rate me
thankyou
Feb 19, 2009 | Teac 1x1 DVD/CD Duplicator, DVW/D11A/KIT...
Wytron 688 won't make copies from dvd
try some other burning application like nero burning rom, alchohol
Oct 21, 2008 | Wytron Technology Wytron-688 DVD...
DVD duplicator
you might be in test mode which is just like burning disk but nothing actually gets written if you cant check this try installing different software nero burning rom works well.
Dec 06, 2007 | Computers & Internet
Telex Spinwise upgrade
I LOVE this question. Too bad no one ever answered it.
Sep 11, 2007 | Telex SpinWise 7-824D (301689000)...
Computers & Internet Logo
143 people viewed this question
David Payne
David Payne
