Question about Garden
You need to mix 10 litres of detergent.The correct ratio for the detergent is 1 part chemical to 4 parts of water. How many litres o chemical you need ?
  • 1,169 Answers
2 liters chemical / 8 liters of water = 10 liters of mixed solution.
Posted on Apr 24, 2015
What is the petrol to 2 stroke oil ratio for the 61
really? grade school math.
Divide 1 by the total number of parts (water + solution). For example, if your mixratio is 8:1 or 8 parts water to 1 part solution, there are (8 + 1) or 9 parts. The mixing percentage is 11.1% (1 divided by 9). If your mix ratio is 4:1 or 4 parts water to 1 part solution, there are (4 + 1) or 5 parts.
Sep 07, 2017 | Garden
I need to know 25.1 ratio is it in ounces or ml for a Chinese chain saw model GL5800
If the ratio is 25-1 then that can be worked out in litres or gallons the oil component is 1 25th, you can always use water to do a trial in a container that you know the volume of pour 25 times the measure to get your volume.??
Mar 14, 2017 | Garden
Need gas misture ratio for trimmer SRM2501
pauly46 here
the ratio you should use is 50:1
that is 20 mils of 2 stroke oil for every 1.0 litre of petrol that you mix
so if you want to make 2 litre mix use 40 mils of 2 stroke oil , then add 2 litres of petrol only and give good shake
note use good quality 2 stroke oil , such as sthil or husqvarna oil from your outdoor power shop
but if using general 2 stroke oil from a garage use 40 mils of oil for every 1 litre that you mix
this ratio is 25:1 this mix is on the richer side
cheers hope this helps
May 01, 2011 | Echo Garden
What is the fuel mix for 359
hi there troyandbec
pauly46 here
May 01, 2011 | Husqvarna Chain Saw Maintenance Kit 357xp ...
Fuel mix ratio for Husqvarna 142E?Does it use premium gas?
husqvarna 142 e will use 91 octane fuel is ok and use qood quality 2 stroke oil
at the ratio of 50:1 premix that is 20 mils of 2 stroke oil for 1 litre of petrol that you mix
so if you want to make a 4 ltre mix add 80 mils of 2stroke oil to clean container and add 4 litres of petrol only and give good shake then fill saw
cheers hope it helps
pauly46
Mar 27, 2011 | Husqvarna Garden
What is the correct fuel oil mix for a homelite whipper snipper
I believe Homelite calls for 40:1 (2.6oz. oil to 1gal gas) mixture, but if you are using a good current brand name two cycle oil, 50:1 (3.2 oz. oil to 1 gal gas) would be safe also.
Feb 08, 2011 | Homelite Mighty Lite Lawn Trimmer
What is the ratio pet /oil for 36cc mccullock (it says 40: 1 on the lid is this correct)
yes
if using good quality 2 stroke oil
use 25 mils of oil for every 1 litre of petrol you mix this is 40 :1
or on a 2 litre qty mix you would pour in 50 mils of oil in a clean petrol container 1st then add 2 litres of petrol only and give good shake then fill your saw
cheers paul
hope it helps
Aug 09, 2010 | McCulloch Garden
Instructions for using ortho tree sprayette
The Ortho Tree and Shrub Sprayette has a fixed mixing jet set to a 24:1 ratio. 5.3 ounces of spray concentrate in the jar will mix to produce 1 gallon of diluted spray. The jar has a capacity of 42.7 ounces, so you can spray up to 8 gallons with 1 filling. If you look at the side of the jar, you will see two filling scales. On the left is the diluted spray capacity, and on the right is the concentrate scale. So you will see 8 gallons opposite 32 ounces, for instance.
You must dilute concentrates to the 24:1 mixing concentration. So if your concentrate says 1 ounce/gallon, and you want to spray 6 gallons, put in 6 ounces and add water to the jar to the 32 ounce level.
Mar 16, 2009 | Garden
Garden Logo
105 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
