Is it possible to set the PIXMA MX474 fax machine to only pick up after a specific amount of rings?
The Pixma MX 434 Menu structure does not seem to have any entry to set the amount of rings before fax machine answers. If someone is home, and the phone rings and the faxmachine is in fax only mode it picks up after two rings. If it is in Telephone Proirity mode, the phone just rings and rings and rings until a person picks it up. We want the phone to ring six times or eight times and the switch over to fax. Is this not something very easy to do? I have done it with other fax machines!
  • 77 Answers
SOURCE: Epson Aculaser CX11NF won't receive faxes
Change your incoming mode from "autoswitching" to "TAM" (TAM is short for telephone answering machine" Press the "Setup" button on the control panel Use down arrow twice to select "FAX SETTINGS" Press the right arrow once The FAX SETTINGS menu appears Press the down arrow twice to select RECEPTION SETTINGS Press the right arrow once Press the down arrow unit INCOMING MODE appears in display Press the right arrow once Press the down arrow until TAM appears in display Press the right arrow once. That should do it for you If I got lost somewhere, it is in your Operator's manual - look in the index for TAM Hope it helped Ed
Posted on May 23, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Incoming Fax Problem
Sounds like phone line issue to me like noise on it at times did your phone provider check it?
Posted on Dec 28, 2007
SOURCE: faxing using voip phone service
We found out that the machine requires a dedicated analog line, so we won't be able to use it on a voip system.
Posted on Jun 17, 2008
  • 25 Answers
SOURCE: Incoming faxes not received, all else works.
It is your phone answering machine that must pick up in three rings or less.
Therefore 4 is too much. I would not limit number for fax machine itself.
On receipt of fax sometimes seems like it will not work when answering machine picks up in the middle. However, leave it and it will work. Sometimes sender will hear your answering machine and cancel as well. So try to ensure they don't give up at other end as well.
Good Luck!
Posted on Feb 28, 2009
  • 1126 Answers
SOURCE: Change number of rings before fax picks up.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=335&modelid=14444
Look in the Advanced Guide for a possible solution on page 1-8 etc.
Posted on Jun 07, 2009
My answering machine (phone line) is picking up when I dial my fax number. How do I set my fax machine up so that it will pick up when I dial the fax number?
Either your fax machine is set to answer on more rings then your answering machine is or you dont have the automatic answer key pushed?
Determine how many rings your answering machine picks up on and then change the number of rings to a lower amount on your fax machine. To change the number of rings before picking up the line, press the "menu" key on the fax machine and use the up and down arrows to scroll until you find the "basic fax set up" or the "advanced set up" areas. I am not sure which one will have the number of rings setting. Try looking in both until you find it.
when you see it press "ok" or "enter" get in and change the amount of rings before answering. call your fax machine to make sure it picks up before your answering machine.
This should solve your problem.
Mar 21, 2011 | Office Equipment & Supplies
I don't use an answering machine. My phone has voice mail but the machine is not even recognizing when a fax comes in. The fax call goes into the voice mail each time. The phone line is working-I get a...
You need to set your phone to pick up later than the fax machine. set it to pick up on the 4th or 5th ring, set the fax to pick up at 2 or 3. Better yet, get a distintive ring # set up by your phone co. then the fax will only recognize that ring.
Dec 30, 2010 | Canon PIXMA MX870 Wireless Office...
Cannot receive faxes on Canon Pixma MX870, but can send faxes
I was searching for an answer to this to make sure my new MX870 is correctly set to receive faxes. Here's one answer I came across:
First set Tel-Priority, turn off incoming ring, turn on manual/auto switch, then check how many seconds it takes for your answering machine to come on, and set it a couple of seconds after that. This should do the trick.
May 13, 2010 | Canon PIXMA MX870 Wireless Office...
Getting to answer phone before fax or message bank cuts in
to stop the pixma from picking up even after the phone line has been picked up you need to ensure the telephone line is connected to the LINE port and not to the PHONE port on the back... the PHONE socket is if you wish to connect a phone line to the same socket Thru the pixma. (passthrough)
not sure how to stop the pixma picking up on the first ring though..... are you sure that you are SAVING the setting change.....?
Sep 28, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Fax machine picking up all calls
You must set the FAX RECEIVE MODE to FAX ONLY. The factory default is FAX/TELEPHONE. You can find the proceedure to change FAX RECEIVE MODE in your owners manual. IIf you don't have an owners manual, try pressing the MENU button, then scroll to one of the following: INITIAL SET-UP, FAX SET-UP, OR FAX RECEIVE MODE. One of these should get you to the FAX ONLY receive mode setting.
Aug 05, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Faxing using voip phone service
Jun 16, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Pixma mx 310 fax auto
enter rx settings and select teleline as fax priority.
Mar 30, 2008 | Canon FAX-JX200
Receiving incoming faxes
# Press the button to enter Fax mode. # Press . # Press the right or left arrow button to select [Receive mode settings], then press the button. # Press the up or down arrow to select the receive mode that best suits your needs(you probably want "FAX ONLY" When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only), then press . # Press repeatedly to return to fax standby mode.
Aug 07, 2007 | Canon PIXMA MP830 All-In-One InkJet...
jasbo
jasbo
