Question about Nikon D40x Digital Camera
Need driver for this camera for windows 98
I know, i know, old computer - but all i need is the driver to make this work. please, can you tell me where i can download/purchase the driver for the nikon d40x for a windows 98 operating system?
  • 150 Answers
Re: need driver for this camera for windows 98
You'll have to explain what you want to do? If you want to download your images, you don't need a driver, just attach a Windows 98 compatible card reader to your USB port and download your pictures to your favorite photo manager. You should be able to attach your camera via USB, and if the USB drivers detect the camera's disk, then a new drive will appear your My Computer.
If you have Windows 98 Second Edition, you should be set to go, if you have Windows 98 First Edition (where it doesn't say Second Edition in the My Computer properties), you'll have a tougher time with the USB connections. It would be best to upgrade your machine, or find the Windows 98 SE upgrade from a friend.
The CD that came with the camera will have the necessary software for Windows 98 SE.
What have you tried to do? What isn't working? Let me know some details and I'll help you out.
Hope these ideas help. Clarify some things and I can give you a more narrow answer.
Posted on Nov 23, 2007
0 characters
3 Points
Drivers for nikon coolpix L20 cam
I'm sorry there are no drivers for this camera, no one is making them for windows 98, windows xp and newer come with the software build in.
I'll save you some time and fustration, take the camera - memory card to a local camera shop or a photo place where they can print them out or burn them to a CD, then you can view them on your computer from the CD.
Sep 05, 2009 | Nikon COOLPIX L20 Digital Camera
Driver for Pretec DC-300 Digital Camera for Windows Vista
Try this:
Uninstall the driver (if installed). Next, put in the driver CD and browse to the setup.exe file. Right click and select properties. In the box that opens, select compatibilty tab and select the box next to "runthis program in compatibilty mode for" and select XP SP2. and install the program
Should that not work, uninstall and retry the above process, but select Windows 98 or 2000 this time..Hopefully that will work.
If it still does not work, then unfortunately, you will either have to downgrade to XP (I believe the driver works for XP) or buy a new camera altogether..
Jun 04, 2008 | Pretec CompactCamera Digital Camera
COOLPIX S50 Digital Camera connect to My PC (windows 98)
If you are using Win 98 then please make sure that you have USB mass storage device drivers installed or else your computer might not detect the camera thats connected to the USB drive. You can get the USB drivers from the following link:
Please let me know if that works..
Apr 03, 2009 | Nikon COOLPIX S5 Digital Camera
I have not got the Disc to download the software for my Vivitar 5385...any ideas..
Hello Tea22me,
The Driver to will depend on your Operating system.
For XP and above,you should not need any drivers for the camera. If you are still on windows 98, then please download the Mass Storage Device drivers from the following link:
Please let me know if this works for you.
Apr 02, 2009 | Vivitar ViviCam 5385 Digital Camera
Windows 98 driver needed
You'll need the model number of your card reader, then visit the nexxtech site to download your driver:
If you can't your product listed in the product list, email them directly for the driver at:
Jan 29, 2009 | Digital Cameras
Not uploading pictures
I think I know what the problem is, first off the computer must be able to communicate with the
camera/device irregardless of the drivers. The camera is plug and play and so is the computer
unless you are using an older version of windows like 98 or 98 second edition. If you are 98 etc load
the old drivers. But if you are 2000, millineum, or xp then the drivers are automatic for the usb ports.
The panasonic dmc-fz7 is kind of a freak in that it is not a true plug and play device. Sometimes
you have to declare the new hardware. It may have once worked but for what ever reason the hardware may not jive with what the pc thinks it sees if anything at all.
Solution: Go into the Control panel , add hardware wizard, with the camera hooked up to the usb
port and the camera turned on. In the device manager you should get the appropriate message, "new hardware detected" actually it should say dmc-fz7 etc. From there it should be apparent that things are working normally....Good luck. Probably a power glitch or who knows. Mostly its a problem with panasonic plug and play software which they corrected a year or so later with the newer cameras...
Dec 22, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
DX3500 Kodak software will not run in Windows Vista
Use a memory card in the camera, then use a generic USB memory card reader to transfer your pictures off the memory card. Camera USB cord drivers are always a pain to use.
Nov 12, 2008 | Kodak EasyShare DX3500 Digital Camera
Problem with transfering images onto my Windows 98
you might have to remove the driver in safe mode of windows 98.
then reinstall the drivers for the camera after removal.
also look in the control panel for add/remove program and look for your camera drivers
if they are there remove them, and reinstall the drivers.
also there are some computer where the usb port could be failing, try the camera on another computer, but i really would suggest a card reader for camera, since it take away the wear and tear of the camera by hooking it up and turning it on for transferring the files. i just use a card reader, and just used the camera to take pictures.
Jul 14, 2008 | Vivitar ViviCam 8300s Digital Camera
Windows 98 Driver required for sony cyber-shot dsc-w35
Windows 98 is not officially supported by Sony for the DSC-W35. You can find hacked versions on the web but they may not be stable. You can find a list of supported Operating Systems here at the Sony website.
I would suggest trying to use the Windows ME drivers. Windows ME was based on Windows 98 so the drivers for most applications are virtually identical. I have used 8 different drivers from other vendors in situations like this and it worked out fine. However, please be aware that since it is not officially supported it can cause interoperability options with your Windows 98 system.
This is the best suggestion I have. By no means should you get Windows ME, it was one of the worst versions of Windows released. Lots of bugs and there are less drivers for this operating system than your Windows 98.
Dec 20, 2007 | Sony Cyber-shot DSC-W35 Digital Camera
Nikon D40x Digital Camera Logo
171 people viewed this question
Top Nikon Digital Cameras Experts
Are you a Nikon Digital Camera Expert? Answer questions, earn points and help others
