I cant fine where I can buy new the rubber/ plastic rollers that support the seat can you help me. please
    Top Expert:
  • Office Equip... Master
  • 44,422 Answers
Did you try the manufacturer .
Posted on Apr 24, 2015
HV9010P ROLLER BRUSH DOESN'T MOVE
That is probably the belt. Open up the bottom screws and take a look. The cat or dog hair usually gets stuck in the ends of the rollers and stops the belt from effectively pushing the roller. You may find that the belt is still on the drive and the roller. If you do just clean out the roller.
Jan 22, 2013 | Black & Decker AV1200 DustBuster Handheld...
I have cleaned the toilet seat in hot water and the plastic glued stoppers for the seat have fallen off and the glue has become hard. Where do I get new stoppers from.
Hi seacenter30
Why buy new seat stoppers when all they need is just re-glueing.
Get yourself a cheap hot glue gun (HomeDepot,Lowes,WalMart,etc) and a couple of hot glue sticks and apply the hot glue to the rubber/plastic stoppers and hold them into position on the toilet seat lid till the glue sets, just takes about 20 seconds...
Then the toilet seat will be good to go again...pardon my pun...:-)
Please take time to rate me thumbs up
Sep 14, 2011 | Prestige Home
Hello, People I have a Tunturi 202 rowing machine, and love-it. However, the little wheels under the seat have worn-through ... weep! Can anyone help me on locating replacement wheels for the...
Good News! Home Depot sells (on-line only) drawer rollers that work PERFECTLY for the Tunturi Rower machine seat rollers. The only difference is the wheels are nylon instead of rubber. Model Number R7228, Internet Number: 100142874. Item description: ROLLER, W/ 1/4" -20 STUD, 1-1/8" NYLON, BALL BEARING. There are two rollers in a package, $5 for two! http://www.homedepot.com/buy/prime-line-1-1-8-in-nylon-ball-bearing-drawer-rollers-2-pack--r-7228.html
Mar 10, 2011 | Exercise & Fitness
Paper jamming almost before it has fed. Suspect rubber on paper roller.
It is a design fault of these machines - seems to be worse if you print lots of labels.
If you take out the imaging unit and the paper tray (so toner doesnt go everywhere) and turn it on its back you will see a rubber roller in the middle of the printer. This is the cause of the problem.
Try cleaning it with alcohol first off.
If that fails you need to rotate the rubber a bit so a new bit is picking up the paper.
To do this there is a white clip that holds the spindle on the axle on the right side looking up the paper path in teh direction teh paper will travel. If you gently lever this up you can slide the white plastic cam shaped end bit in about 1/4 inch that lets you rotate the roller (I cant remember if you rotate it towards you or away) it is really difficult to do and you need to fiddle with teh cam to keep it disengaged. Once you rotate it enough you will see there are two clips - one on each side of teh roller holding teh rubber in place. If you unclip these you will find that the rubber is actually not around the roller but is a giant elastic band looped over the roller in a U shape and held by the plastic clip you just unclipped. You need to find the most unworn bit of the rubber so it meets the paper in the tray and reposition the band and teh clip to suit.
Reassembly is the reverse process - with lots of swearing.
It is actually reasonably easy to do.
If that fails to fix it you need a new rubber (not sure if you can still get these) or you could try packing the roller with a bit of paper to make it grip better. Also to make the rollers life easier you can wedge up the front of the printer with a book about 3 inches thick.
Feb 07, 2011 | Xerox Phaser 6110 Laser Printer
2070 printer shows red, flashing 'paper' lcd when there is paper in the tray. I have done the usual, checking tray, removing and restoring toner cartridge etc etc. I have tried a manual feed as this...
  1. Remove left cover (where the USB connection is located);
  2. Remove big black gear with a spring on it (you may need to unscrew the PCB that partially covers it);
  3. There is a clutch that sticks to the rubber pad behind this gear. You may put a piece of scotch tape towards to a rubber pad, so the plastic from clutch mechanism would'n stick anymore. http://www.phillycopiers.com/fix/hl-2040-2070-fix.jpg
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Dec 01, 2009 | Brother HL-2070N Laser Printer
How do i take my fuel pump out in my bmw 325, i got the rear seat put and the cover on the passenger seat off, i just cant get the pump out
The fuel pump in your 325 is under the rear seat, passenger side. Take the seat out, then pull up the rubber grommet with the wire going through it. Leave the wire alone for now. Peel up the thin rubber insulating mat. It is pre cut by the factory and not glued down. Remove the four nuts (10mm socket) and lift the round plate. Now remove the wire by sliding the plastic plug type housing back and lift the entire plug type housing up. Now, remove the hose clamp and slide the hose back off the plastic tube. If you damage the clamp, buy a new 1/4" clamp at the auto store for .30cents. Now unscrew the steel ring holding the pump in place. Unscrew this ring by tapping the ring with a screw driver and hammer. Remember counterclockwise (off). Now put your finger in the plastic ring molded into the top of the pump and pull up with some force. It is in place with a rubber gasket. Tight, but it will come loose. Be careful not to drop any thing into the tank. On the other side (drivers side) is a float/sensor. When reinstalling, seat the rubber gasket into the hole then drop the new pump/sensor into place. Your tank is like a saddle bag so it has two float/sensors. Time: 25 minutes
Oct 19, 2009 | 2005 BMW 3 Series
Worn seat wheels on Tunturi 202 need replacing
Jul 01, 2009 | Tunturi Exercise & Fitness
R205 Tunturi Rowing Machine, needs new bearing wheels under seat
Mar 31, 2009 | Exercise & Fitness
Cosco Buckle Broken
Bought a new car seat
Sep 26, 2008 | Cosco 02-442
Changing the paper feeding roller in a cr 110 cash register
hi. You buy the feed assembly (the whole black plastic part that holds the roller) from a dealer, then it clips into the back.
Mark
Apr 11, 2008 | Casio Parts Cash Register PC Desktop
jasbo
jasbo
