Which problem will appear when EHT HV very low
    Top Expert:
  • Televison & ... Master
  • 74,198 Answers
The picture will have blooming effect, and focus too will be out.
Posted on Apr 24, 2015
I have jvc av-27020 volume and channels display appears normal on the screen but the picture is dark, help to solve it
Volunteers and Chan display ate digital inputs. On a CRT TV the picture is an analog input. A dark picture generally means that the EHT supply is low or the picture tube is getting old ending it's useful life, solution is not easy
Jun 03, 2014 | Televison & Video
Why is my sumsung tv model CS21B501HL take too long to show pictures when switch on?
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then 1 of the indication is that it takes few seconds time for picture to appear ( after few days it takes few hrs & then stops completely).............. .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV --- this adjustment is very important ) ----------iam from bangalore ........since it is very risky job i suggest to contact TV service engineer ------- because they are highly experienced & can fix this component very easily. ------------ [[ sometimes along with EHT another component called transistor ( big in size - situated close to EHT - it will have 3pins - its size will be 1inch X 1/2 inch X 1/2 cm --approximately ---- black in colour ----- fixed to aluminium metal ) --- will also gets deffective --- so this component also should be checked ]] ---- in your case this transistor is good ... because when this component gets deffective then TV won't get '' ON '' .............so in your case only EHT should be replaced.........100% it works normally .....GUARANTEE....... vishnuswamy_4.jpg
Aug 02, 2011 | Samsung Televison & Video
How to stop EHT leak from eht cap
Clean the CRT EHT contact surface properly with alcohol.let it dry for few minutes.paste some silicon grease into HV contact hole .Clean the HV Contact hook at the FBT End.paste some Silicon glue to EHT Cap and fix it to CRT HV contact hole.HT leak problem will be stoped
Jun 13, 2011 | Televison & Video
Hi I have a Samsung 56V monitor . The letters have been appearing blurred for quite some time .
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - MONITOR TUBE ) becomes weak - then 1 of the indication is ....picture becomes dull...blurr... (less brightness & less contrast , no clarity ) ........so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching monitor --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as sevice charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact monitor service engineer ------- because they are highly experienced & can fix this component very easily..
May 14, 2011 | SAMTRON 55V 15" CRT Monitor
I'm having problems with the picture. It takes a long time for the picture to come up. Sometimes it will come on, go off, etc.
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then 1 of the indication is ....it takes few mins for picture to appear...& in some TVs it will come on & goes off (your case)........so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around US $ 10 & for my customers (in bangalore) i will take another US $ 12 as sevice charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact TV service engineer or sony service centre ------- because they are highly experienced & can fix this component very easily.....
Apr 21, 2011 | Sony KV-36FS12 36" TV
I have a sony model KV30HS420. The hv comes up for a second the the set shuts down with 6 blinks. Any ideas? thanks.
The Horizontal stage has stopped. It could be caused by excessive EHT and the set will shut down, the power supply is faulty or something more sinnister like an electrical leak on the output side of the EHT unit.
Feb 22, 2011 | Sony Televison & Video
My crt tv have big oversize picture. what component should I replace is that bad capacitor??
That could be caused by a number of things. The first that comes to mind is low EHT. That could be either power supply or EHT Trippler unit.
It will be a guess.
Check the HT supply first and make sure it is correct then the EHT should be around 25KV.
Jan 29, 2011 | Televison & Video
Disply very slow please help me
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - MONITOR TUBE ) becomes weak - then 1 of the indication is ....it takes few mins for picture to appear...........so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching MONITOR ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around US $ 10 & for my customers (in bangalore) i will take another US $ 12 as sevice charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact MONITOR service engineer ------- because they are highly experienced & can fix this component very easily.....
Jan 17, 2011 | LG Flatron 775FT 17" CRT Monitor
Help for TCL Brand of tv
I WANT THE SERVICE MODE CODE FOR MODEL NO: DP21E101 TCL TV 21"
Jun 15, 2008 | LG 30FS1D TV
Shorts
Could it be in the HV circuit? first you isolate h/output section from power supply. make power supply output ok. check h/output section for short circuit 1 print short near eht 2 diodes or cap.near eht 3 yoke H winding just by removing connector 4 EHT transformer regards
Sep 12, 2007 | GE 25GT270 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
