Question about Hunter Small HEPA Air Purifier Tower with UVC
Where can I find filters for a Hunter Air Purifier model #30447
Filters for Hunter Air Purifier model #30447
SOURCE: air purifier HUNTER 30200
I hope this is not to late. This is an old post. But I have this same air cleaner. It does prove difficult at first to open and it feels like you are going to break it.
On the sides about two to three inches down is a large indentation. Slide your fingers in there and gently but firmly pull the face plate of the air cleaner off. The air cleaner is as big as the front of the air cleaner. It will slide right out. I hope this helps.
Posted on Mar 02, 2008
SOURCE: lights still flashing after i replaced filter
You have to press the reset button on some models. The unit does not have any way of knowing you reset the filter -- you have to tell it.
Posted on Mar 23, 2009
SOURCE: Cannot find manuel, need to reset after replacing filters.
How to reset Hunter quietflo air filter, won't start up.
Posted on Feb 25, 2010
shafykp750
  • 1070 Answers
SOURCE: I purchased a Hunter Purifier,
Hello Sir,
It Seems To be Damaged...So try to Do following.....
  • Locate the air purifier's filter. Many times this is located underneath and toward the back of the air purifier. Note where it came from and what direction it was placed in the air purifier.
  • Carefully pull out the filter. Place disposable filters in a plastic bag and take them to a store for comparison and find the exact replacement filter. If it's a reusable filter, clean gently with warm water and mild soap. Rinse thoroughly until all suds are out of the filter. Shake out the filter to remove any excess water. Set the air purifier's filter aside when finished.
  • Disassemble the air purifier as much as possible. Make sure you keep track of what you are doing so that putting it back together is easier. You may want to take notes for easier assembly later.
  • Use a damp cloth wet with warm water to wipe down the entire purifier and all its parts. Wipe out all the grooves really well.
  • Leave all the air purifier's parts on a clean surface to dry completely. This may take several hours, depending on the consistency of the filter.
  • Reassemble your air purifier once it is dry. It is now clean and should be working properly.
Hope this Make you Better...Thanks For Contacting FixYa...
Posted on Apr 21, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I need a manual for
Hi and welcome to FixYa, I am Kelly.
This should be your 8 page users manual:
http://www.appliancefactoryparts.com/content/pdfs/116668.pdf
If this answers your question would you at least say the problem is solved? Otherwise you will keep getting email notifications of where to find the manual.
Thanks for choosing FixYa,
Kelly
Posted on Jan 16, 2011
Hunter hepatech 40882 uvc air purifier won't turn after cleaned filters
Hello, this is Ava with Think Crucial.
Filter life counters should be reset each time the filter has change. If your air purifier has a reset button, press and hold the reset button until the lights go out. You may also unplug your unit from the power for 30 seconds before plugging it back on if your unit doesn't have a reset button.
You can purchase a wide variety of high quality Hunter replacement parts for your Hunter Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=hunter
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Oct 24, 2016 | Hunter Air Purifiers
Hunter air filter when you turn it on it keeps cycling- on/off,on/off and wont stay on. also hepa filter button not working any more, does not light up blue when pressed. TY for any help : )
If your unit has a reset button, try resetting your unit. Also, replacing the filters and resetting it after putting on the replacement filters usually works. If this fix doesn't work, I suggest you contact Hunter support for assistance and their number is 888-830-1326.
Ava B.
Oct 01, 2016 | Hunter Air Purifiers
I have a hunter air purifier model number 36316 and need to know how to change the filter
To change the wick filters of your humidifier:
1. Turn off the unit and unplug it from the wall outlet
2. Remove the tank for the housing.
3. Locate the 3 lock tabs in the base of the unit. Turn them clockwise until the base of the tab lines up with the indentions in the base and lift off the housing.
4. Locate and turn the lock tab clockwise on the base holding the wick fram. Remove the wick frame and set it aside.
5. Remove the old wick by pulling the bottom of the wick out of the frame first and discard.
6. Insert the new wick top first. Ensure wick is in between the tabs at the top of the wick frame then slide the bottom part of the wick into the fram, making sure not to crush the bottom corners of the wick.
7. Reassemble the unit and refill the water tank if necessary.
8. Turn the unit back on and resume operation.
http://www.thinkcrucial.com/search?page=1&q=hunter&type=product
Ava B.
Dec 16, 2013 | Holmes Products HAP422-UC Air Purifier
Owner manual for hunter 30747 Air Purifier
You may refer to this online manual for your model number to help you put back the filters in your unit.
Hunter 30747 Instruction Manual
https://www.thinkcrucial.com/search?type=product&q=hunter
Ava B.
May 19, 2012 | Hunter Air Purifiers
Can I get an owners manual for Hunter 30525 air purifier?
Yes, manuals are available from Hunter Air Technical Support. Call: 888-830-1326
Be sure to have the correct Model Number handy, when calling. As some models have been discontinued, but are still supported by Hunter Air.
Hope this helped you.
Apr 21, 2011 | Hunter HEPAtech Air Purifier and Ionizer -...
Model 30375 replace filter light
There is a "RESET" icon next to the warning light. See the tiny hole? Get a small toothpick or something similar and simply insert, push, and watch the annoying light go out!
Jun 21, 2010 | Hunter 19' X 21' Room Air Purifier Air...
Jul 10, 2009 | Hunter QuietFlo 225 Air Purifier
Lights still flashing after i replaced filter
Mar 22, 2009 | Hunter (30067) Air Purifier
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • WHOLE HOUSE HEPA
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Nov 26, 2007 | Hunter 30216 3-SPEED FLOOR MODEL Air...
    Hunter Small HEPA Air Purifier Tower with UVC Logo
    99 people viewed this question
    Top Hunter Air Purifiers Experts
    Steve
    Gerry Harvey
    Gerry Harvey
    Are you a Hunter Air Purifier Expert? Answer questions, earn points and help others
