Question about Boost Mobile Kyocera Hydro Smartphone
What i forgot to tell Harrie was the router is Xfinity tc8350c.signal is strong for all my guests.its been reset many times.read briefly while surfing the security cert.may need upgrading or reinstall
As i was surfing i briefly saw one error code that read error code1101 or close to that #. another briefly seen was something to do with a security certificate install or reinstall
My phone will not connect to internet
What do you mean by "fully connect"? How far are you from the router? Xfinity has a weaker WiFi signal than most companies. I had them and could not get a good signal when I went to my bedroom from my office (a distance of about 50' with four walls between them).
You could ask them for a stronger router, though I doubt they have one or else they will charge you more on your monthly bill for it. You can also check online for WiFi boosters. They seem to have problems too. Look to YouTube or Instructibles for building your own, inexpensive, booster (usually free if you don't mind it LOOKING homemade).
Hope this helped.
Jul 23, 2016 | Computers & Internet
Tip
XFINITY Users - How To DISABLE Public Access
Are you currently a Comcast / XFINITY subscriber? Read On!
If you're currently subscribed to the Cable company, Comcast - You may be running the risk of allowing the public to access your Home Network! This was their method on how to add millions of Hot Spots throughout the U.S.
You can find out if you are sharing a Public Network by taking your smartphone and checking for local Wi-Fi signals. Stand next to your Router/Modem during this time and if you have solid bars then most likely you've got Public Access.
While this may initially appear to be a good thing - it can lead to serious issues and possible Federal Prosecution. If you do not secure your Network YOU are liable for the traffic which flows through - do not be another statistic when it comes to a wrongful arrest!
XFinity allows ANYONE with a smart device to connect to YOUR Network for one complimentary hour, or permanently if they have a Comcast login. Not fun, right? So let's get that fixed!
Initially you were able to go into the Router/Modem itself and manually disable the Public Access / Xfinity Hot Spot. Now things are a bit more complicated:
First Go To: https://customer.xfinity.com/#/settings/security/hotspot.
Second: Sign into your XFINITY Account with your User/Pass
Third: Navigate to your Public Hotspot tab - click Turn Off.
This will disable the public access, but you'll still retain connectivity to your PRIVATE Network. No more worrying about Pirates on your Network :)
Notes:
If you found this tip helpful please show the love and I will happily provide more Networking / Security / General IT Tips. I will respond to all inquiries / requests / questions!
on Jun 17, 2017 | Computers & Internet
How do I recover from lost guest password?
If you can log into the router you should be able to simply reset the guest PSK to whatever you like. If you have a computer that can successfully connect to the guest network you can open an elevated command prompt on it and type netsh wlan export profile name="ProfileName" folder="C:\" key=clear Replace ProfileName with the SSID for the network.
Dec 09, 2015 | Belkin Wireless Dual-Band N450 Router
I am trying to get wif on my samsung galaxy it tells me get guest password can you help
You would need to refer to your Belkin's instruction manual for how to set up WiFi on it. The password for any WiFi hot spot is unique to that hot spot so there is no general 'guest' password per se - it depends on how you setup the WiFi router.
WiFi routers also have a web-based interface where you can open a browser from a connected PC and manage the device. Again, the device's instruction manual will tell you how to do this.
If the router was supplied by your internet service provider you should be able to call them for help.
Jan 27, 2015 | Belkin Surf N300 Wireless N Router
Forgot my password for guest
You may need to reset your router usually by holding a reset button somewhere on the router.
Oct 20, 2013 | Linksys Computers & Internet
The Box claims there is a Guest Access. I find no reference or settings within the Router Set up for this activity. How do I set up Guest Access?
Hi Norman,
For guest access:
You can allow guests to use your Internet connection without joining your personal network.
The network name and password for the guest network is located on the network information card found under the foot of your Router
A person using your guest network will be able to join without a password, but will be shown a login page when they attempt to surf the Web..
They will need to enter the guest password into this page to continue.
Hope this helps!
Please Rate if it did!
Thanks,
Gary
Jul 16, 2013 | Belkin Surf N300 Wireless N Router
We are having issue with guest getting a strong signal strength but unable to acquire an IP Address.... any suggestions?
Check that the guest's computer has DHCP enabled.
(also check that the router is using DHCP)
Nov 05, 2010 | Dell Dimension 2400 PC Desktop
Wireless connection keeps falling
It may be just a problem of the signal bouncing around and your laptop is struggling at times to find the signal. Some earlier laptops don't have a wireless booster built in the screen. Go to your laptops' web site and see if there are any updated drivers for your wireless card. If still unhappy with results purchase a USB wireless dongle and dissable wireless card, it may have a better reception area, or purchase a signal booster that works in conjunction with your wireless router.
Dec 18, 2006 | Edimax BR-6114Wg Router (BR6114WG)
Open Questions:
See all Boost Mobile Kyocera Hydro Smartphone Questions
Boost Mobile Kyocera Hydro Smartphone Logo
Top Boost Mobile Cell Phones Experts
John mullen
Lawrence Oravetz
Are you a Boost Mobile Cell Phone Expert? Answer questions, earn points and help others
