Question about Cell Phones
How do i activate speed dial as its not working
I have added people to the speed dial list but it doesnt work still
    New Friend:
  • 4 Answers
Go to settings select phone then the option speed dial should pop up hit it then your contacts shiuld come up and choose witch. Number u want for each contact
Posted on Apr 24, 2015
How do I set up speed dialing on my HP Officejet 5740
While "Speed Dialing" or "Speed Dial" is listed in its fax specifications on some sites, it appears to be a mislabeled categorization of its group fax feature as HP's manual makes no other mention of it--save to say, the "fax to multiple numbers" (or multiple recipients) feature. There does not appear to be a speed dial list, but there is a phone book feature for adding contacts (individual numbers) & groups. (The following is detailed in a more explanatory way on pages 65-66 of the user's manual (http://support.hp.com/us-en/product/HP-Officejet-5740-e-All-in-One-Printer-series/6617253/model/6617254/manuals?cc=us&lang=en).
1. From the printer control display, touch Fax.
2. Touch Send Now.
3. Touch the telephone symbol to access its phone book feature.
4. Touch the person symbol for a phone book contact; or touch the multiple person symbol for a group of phone book contacts.
(Note: Contacts should be established before any of these could be added to any group.)
5. Touch + (plus sign) to add a contact/group; or touch the gear symbol (edit) to edit/delete a contact/group.
6. Touch Name.
7. Changes to contacts/groups:
•Adding a contact/group: type the name, & then touch Done.
••Adding a fax number to a contact: Touch Fax Number, enter this contact's fax number, & touch "Create".
••Adding a contact to a group: Touch Number of Members, select all of the contacts to add to this group from this printer's phone book, & touch Select followed by touching "Create".
•Editing: Select the contact/group name, & then touch Done. Then...
••Editing a Contact: touch Fax Number, enter the fax number, & touch Done.
••Editing a Group: touch Number of Members & deselect the contacts to remove from this group or touch + (plus sign) to add contacts to this group. Then touch Done.
•Deleting a contact/group: Select the name, & then touch Delete followed by touching Yes.
Feb 25, 2015 | HP Office Equipment & Supplies
Speed dial does not work
Look at the number that is in there for the person you are trying to speed dial,your voice mail is always #1.To use speed dial you just use the number the person you are trying to speed dial lets say they are in your phone as #2,hold down the # 2 on your keypad for around 3 seconds and it should start dialing.
Jan 01, 2013 | Net10 Motorola W409G Prepaid Camera Phone
How do I programm the Speed Dial on my 4406D+?
To program your Personal Speed Dial numbers, make a list of
your telephone numbers/extensions numbered 1 to 24, then:
Press an Intercom button + lift handset + dial #00 + dial # + list number (01 to 24) + dial *21 + the number you want to store + #*00.
To use Personal Speed Dial:
1: Press an Intercon button.
2: Press Feature (if you have programmed a "Feature" button) or #.
3: Dial the two-digit code (01 to 24).
Apr 27, 2010 | Avaya Merlin Magix 4406D+ Corded Phone
How can i get a fax from memory.
Solution: Printing reports and lists MX310
Printing reports and lists The table below shows the reports and lists that can be printed from your machine.
Report or List Description ACTIVITY REPORT Shows recent facsimile transactions performed by your machine. You can enable or disable automatic printing of this report after every 20 transactions. You can also manually set the machine to print it. CODED SPEED DIAL
LIST
Lists the destination numbers and names registered for coded dial speed dialing. USER'S DATA LIST Lists the current settings of your machine and the registered sender information. MEMORY LIST Lists the documents currently stored in the machine's memory. TX (Transmission)
REPORT
Prints after transmission of a document.
You can enable or disable this feature, or set the machine to print a report only when an error occurs.
You can also set the machine to print the first page of the document under the transmission report to remind you of the contents of the document.
RX (Reception)
REPORT
Prints after reception of a document.
To print the Activity Report, Coded Speed Dial List, User's Data List or Memory List: 1 . Press <FAX>, then press <Menu>.
2 . Use leftright.gif to select [PRNT REPORT/LIST], then press <OK>.
3. Use leftright.gif to select the desired report, then press <OK>. The report or list is printed.
Mar 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Nokia 6085 how to speed dial
To assign a number to a speed dialing key, select Menu > Address Book > Speed
dial list, and scroll to the speed-dialing number that you want.
Select Assign or, if a number has already been assigned to the key, select Options >
Change. Select Find and the contact you want to assign. If the Speed dialing function
is off, the phone asks whether you want to activate it
FOR MAKING CALL
Assign a phone number to one of the speed dialing keys, 2 to 9. Call the number
in either of the following ways:
• Press a speed dialing key, then the call key.
• If Speed dialing is set to On, press and hold a speed-dialing key until the cal
Dec 22, 2008 | Nokia 6085 Cellular Phone
Motokrzr k1m adding voice commands for voice dialing
You should be able to add a voice tag while editing the contact. You may also be able to simply activate voice dialing and press the voice dial button and say the name of the person and it will automatically dial for you. Try doing that.
Dec 18, 2008 | Motorola Mobility KRZR K1m Cellular Phone
Modem pro
Get High speed for the love of god.
No just kidding, i know, some of us cant afford it at home.
Most likely the phone number that the modem dials into may need to be updated for your service provider. If i remember correctly, you usualy have a list of numbers in the modem settings pick a different one.
You can also call the provider and they will help you.
I would recomend just paying the $40 a month for a cable modem and high speed and hooking straight to your network ( NIC ). Dial up is slow and you spend more time messing with dropped connections and slow speeds.
If your in an area that doesnt provide it, then i feel bad for you.
Good luck
Oct 22, 2008 | Dell OptiPlex GX280 PC Desktop
Speed dialing
which model ?
generally in all cell phones v will be have speed dialing option in range costing handset also... v can set the 9 speed dialing numbers .... in which 1 speed dialing number is common that is sos(112) in samsung and motorola handsets ... common thing is may be in sony ericson also i m not sure ... in nokia handsets if we make the speed dialing option on then if we just press one number means we can call to the person ...
for ex: you may be having some person whom u will call frequently instead of selecting the number by going to phonebook if you put that number to speed dialing list means you can call them by pressing only one button...( while adding to the speed dialing list it will ask to assign the keys like 1,2,3... 9)
as every handset keypad will be having 0-9 number keys this is very useful ...
in some handsets the speed dialing option is found in phonebook & while in other it will be found in call options...
Feb 07, 2008 | Cell Phones
Speed Dial quit working
why for restart my V3 mobail?
Sep 07, 2007 | Motorola Mobility RAZR V3
Speed dial not working
I have done it. I have found a way to chance the speed dial settings on my Samsung D900i.
The following instructions work for my phone but I cannot guarantee they will work for everyone else.
YOU WILL NEED A PEN AND PAPER.
Press Menu > select Phonebook > Speed dial (4) >Select
You should see names assigned to the numbers.
Decide which speed dial number you want to change e.g. 2 Mum Mobile (remember the name)
Press Back > Contact list (1) Select
Type in/go down to that name e.g. Mum Mobile (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > choose Yes > Back > Speed dial (4)
You should now see that Mum Mobile has been replaced with a big number 2. This means that speed dial number 2 is un-assigned.
Press Back > Contact list (1) > Select
Decide who you want to be assigned to speed dial 2 (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > Yes (HERE IS THE WEIRD THING)
Press Back > Create contact (2) > SIM (2) >Select
Type back in the name and number of person you have just deleted > Save > Back > Speed dial (4)
You should see that Speed dial 2 is now the person of your choice.
HOW COOL IS THAT!!!!!!!!!!
Press Back > Create Contact (2) > Select > SIM (2) > Select
Type in Mum Mobile and Number (THE FIRST NUMBER YOU WROTE DOWN) > Save.
That is it, repeat the instructions until you have all the speed dials of your choice.
Hope this helps the many frustrated D900i users out there.
Aug 31, 2007 | Samsung SGH-D900 Cellular Phone
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
