Question about Mitsubishi XL8U Multimedia Projector
My projector has a new lamp but the image shows white no color
It has a new lamp and there's no menu showing or other any words just the lamp lights up white please help
  • 38 Answers
Do you have a DMD chip installed? This is what makes the image. You also need a colour wheel.
If you have just replaced the bulb, and it working before, then make sure that you open the projector in a clean environment, and then check you can see the DMD chip and the colour wheel.
My projector has a new lamp but the image shows wh - 25662706-4bebqcy5hyqgttlipldbqgoj-1-2.jpg
Posted on Apr 24, 2015
NEC WT610 Projector powers up and acts like normal, but will not project an image or the usual blue screen with menu functions. Bulb is fine and lights up, no error lights showing. It's as if it's stuck on...
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Feb 05, 2015 | NEC Office Equipment & Supplies
My Infocus 4805 is just showing the INFOCUS logo and not showing the picture from the TV. all connections are correct but no signal....help
Powering On
  • If your InFocus 4805 projector is having a hard time powering on or doesn't power on at all, it could be one of two things. Due to the extreme temperature of the lamp that causes the temperature of the projector to rise, every InFocus 4805 projector has a cooling system. Check your projector's cooling solution, as it may need to be replaced. Also check the projector's fan---if the fan doesn't spin, the unit will not turn on. If the problem is the fan, you'll have to get it replaced. You can do this at the same place you bought your projector.
  • The Lamp
  • If your InFocus 4805 Projector powers on but does not project any light, the lamp will need to be replaced. All projector lamps must be replaced at some point---how often usually depends on how much use the device gets. Simply order a replacement lamp, unscrew the old one and screw the new one in. The projector will then work like new.
  • Color Wheel
  • If your InFocus 4805 projector powers on and is displaying images but the colors on the images appear warped or are not in the proper places, your "color wheel" will need to be replaced. The color wheel is a small device that essentially acts like a prism. Light is projected through it and it displays the appropriate colors on screen the way they appear in the original video source. Order a replacement color wheel that fits your model and use your instruction manual as a guide as you swap the old one out and put the new one in.
  • Aug 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
    My InFocus 4805 SP projector is showing just black and white
    If you have any video at all and it's only Black and white there is a 99.99% chance that your Color Wheel has lost all of it's glass color filters.
    You can confirm this by removing the lamp. then look straight into the projector where the lamp was and you should see the color wheel of colored glass segments (Red, Green and blue) I believe you won't see them because they came off of the wheel.
    Also if you lift up the projector and turn it around in various angles and you will hear the small pieces of broken glass from the color wheel.
    Unfortunately you will need to take it to an authorized service center for repair. Be prepared to spend upwards of $300 for the repair.
    Cheers
    Aug 23, 2009 | InFocus In Focus SP-LAMP-021 Replacement...
    Showing to of the same thing and colors
    ghosting or convergance issue is what u have. if the image is in diff colors then deff a convergence issue. however, if the image isthe same color or shaded from the original then this is ghosting. this may be corrected through the menu settings(sinc settings).
    Jan 15, 2009 | Toshiba TLP-380, TLP-780, TLP-781UF...
    Sharp xr-11xc only displays black & white
    Sounds like your connection is bad, check ur connections on ur cables
    Oct 25, 2008 | Sharp XR-11XC Multimedia Projector
    PB6100:No picture display
    The projector needs to be turned on first, then connect it to the laptop. If the picture still does not show at that point, press the FN and the LCD keys on your laptop at the same time. This should work.
    Feb 10, 2008 | BenQ PB6100 Multimedia Projector
    Poor image being displayed
    Hi guys
    You will be looking at either repairing or replacing the Mainboard where all the colour processing is done.
    Sep 27, 2007 | Dell 2300MP Multimedia Projector
    Mitsubishi XL8U Multimedia Projector Logo
    80 people viewed this question
    Top Mitsubishi Office Equipment & Supplies Experts
    Martin Murray
    Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
