How do I fix the lcd panel on my aquasmart washing machine?
Sorry I don't know the model number. The lcd panel lights up when turned on and I can set it for the standard normal load by hitting start. But there are no images on the screen, I don't want to buy a new machine that just needs one little thing fixed. I could just run it blindly from memory with the manual for diff. cycles. But it would be much easier if I could just kick it and make the screen work again :) Anyone else have this problem/solution? Thanks
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check lid lock
Posted on May 03, 2015
Buffalo12980
  • 625 Answers
SOURCE: HotPoint Top Loader model # WLW1500B
if you hear clicks then I'd have to say it was a mechanical timer. the timer has a small motor on it. a complete timer including its motor will run you about $120 but a replacement timer motor will be about $35.00
Posted on Sep 22, 2007
JULIANFIX
  • 975 Answers
SOURCE: Washing machine won't drain
i think you can fix it , does it stops when it reaches RINSE cycle ?? if yes , your gonna open the front panel or back panel so you can see inside machine . follow the DRAIN HOSE thats attached to SMALL DRAIN PUMP MOTOR , YOU NEED TO TAKE OUT and check for anything thats blocking the impellers and causing it to stop ( pins , buttons , etc ) let me know by your smile . . . . . .
Posted on Apr 22, 2008
  • 101 Answers
SOURCE: How can I fix my Hoover Washing Machine, model H130E?
which light?
Posted on Apr 23, 2008
SOURCE: indesit W1A111 starts cycle when selector set to "off"
hi i need a user manual for this machine. Where could i get one please. x
Posted on Jun 17, 2008
  • 3 Answers
SOURCE: Maytag front loading washing machine
This worked for me for the E3 error code: Turn the machine off and then on. Enter the Service Mode by pressing the Chime and Exrta Rinse keys for 3 sec. Display the Diagnostic Codes by pressing the Rinse and Spin key. Clear the codes by pressing the Delay and Chime keys for 3 sec. Turn the machine off, unplug and plug in the power cord. This dumps the memory. Evidently, if it gets full, it causes problems with the programming and messes up the cycles.
Posted on Jun 20, 2008
How to know what power cord to buy
Just specify the model number to this set to its authorized dealer. They can provide it to you.
Jun 22, 2013 | Broksonic TV
I try to change my computer monitor settings but they won't change. why?
You should be able to click Start/Control Panel and then look for Display or Display and Personalization.When it opens up select the Settings tab and click on 1 to select your lcd display. There should be two numbers 1 for lcd and 2 for external monitor.
You might be able to do it by keystrokes on your keyboard. Normally you can Press and Hold the FN function key at the lower left portion of the keyboard, then hit the key that toggles the display. The key that toggles the display will normally have LCD/CRT on it or it might have the icon of a display. It toggles between 3 modes (LCD Only, CRT Only or Both LCD and external CRT).
You could try reinstalling your Video Drivers but you would need to be in Safe Mode With Networking to give you internet connectivity. When it boots up open your internet browser and download and install the Video Drivers.
Get online and got to www.google.com In the google search box type: "Dell Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Video drivers.
If all fails you could do a System Restore to a Restore Point (date and time) before you started having the problem. Don't worry, System Restore does not delete any of your data, documents, music, pictures, videos or programs (unless the program was installed after the Restore Point you selected).
Click Start/Programs/Accessories/System Tools/System Restore then select a date and time (Restore Point) that was before you started having problems.
May 09, 2012 | Dell Dimension C521 PC Desktop
My 32-inch lcd tv from sharp has no picture but audio works fine. No picture ever comes up, not even the "please wait" message. Whats going on?
My 3 year old Sharp LC-40C32U would start up fine but within a minute would go dark (audio continued fine). For a while I could turn the set off and on again and it would be fine, but over time this became less effective. My solution, which has worked for a week now, was to a) unplug the set's power cord; b) after 3 minutes plug it back in and turn the set on; c) on the remote hit MENU and slide over to SETUP (3 clicks to the right if the screen is dark) and one up to RESET; d) hit ENTER and follow the prompts. This puts the set in it's factory configuration so you will have to rescan for channels. Worked for me.
Dec 05, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Dishwasher does not start. Selected Normal; the
Did the control panel lock feature get turned on by accident,one of the control buttons should have a symbol that looks like a little pad lock on or above it,locate that button then press it for 4 seconds or longer to unlock the control panel.Good luck !
Nov 26, 2009 | Televison & Video
Does anyone have the schematic for LCD control
Tom,
I don’t believe you will find a schematic for the control board. I have a FAV6800AW all I have be able to find is the wiring schematic found in the FAV6800AW/FAV9800AW Service Manual.
Is your machine out of the 5yr warranty period for the Control Board? I got Maytag to send me one.
Saw this on e-bay
NEW - Maytag Washer LCD Control # 25001189
Good luck … Rich
Oct 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Sony KDL-46V3000 Bravia LCD Black screen
It's not to complicated, in the newer TVs as well as other things, when you first turn them on the diagnostic circuits kick in [that the first relay you hear click] it sends a signal (low voltage) to all the circuits to check them and make sure there are no problems. If it gets the proper returns from each circuit it kicks out and the full power relay kicks in and powers your set up. This is done to protect others circuits that might be effected by a flaw in a different circuit. What started as a small flaw in a component has gotten worse with use which is normal. Your set is kicking the diagnostic circuits and they are detecting the problem and shutting it down. You have problems with your power board, if the diagnostics circuits were not in place and full power hit the set the power board could possibly put triple or more voltage to some section of another board, thus burning it out also. That's why they started using the diagnostic circuits on TVs, Computers have had them for years. Late model car - etc. I would take the power board out of it and go to shop Jimmy's and enter the part # which will be on the board and order me another one and pop it in and kick back and watch TV again. I don't know what a power board would cost for it but "shopjimmy's" carries high quality boards at a reasonable price. I do caution you on buying a refurbished board, they are tempting but I have never and I mean never seen one hold up very long. As a matter of fact I will not put one into a TV or anything else for that matter. So there is light at the end of the tunnel and it's not the train this time! I only work on the kind of TV that plug into the wall or run on batteries, therefore, I've seen a bunch of them in14 years. Don't worry about getting the wires mixed up because one thing about TVs is a harness or plug will only fit one place and that is where it belogs you can't cross them up.
Gillight
May 17, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
The picture tube of the television was loosen
If this is an lcd tv, the toy has broken the LCD panel and would need to be replaced. The cost of the panel would exceed the value of the set. If you have homeowners insurance, you may want to contact them to see if it's covered. Sorry for the bad news.
Jan 02, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Inoperative LCD TV
Welcome to Fixya! My Name is Travis! I have heard this Problem Before on Another Model. Turns out it was the Power Switch in that case. Yours has the Exact same Symptoms. Get that Checked and let me Know so we can go Further or if that is it.
Jan 02, 2009 | Televison & Video
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
