Question about Cell Phones
Have a note 3 the headphone feature is stuck on cant get it to turn off replaced the jack and done a factory reset can u help me
    Master:
  • Cell Phones Master
  • 456 Answers
Found online hope this helps...
Switch off the headset and then press the call button continuously.A green and blue lite will glow for sometime.After continuously blue lite will lit.At that point pair ur head set with the mobile.It will get detected and will work...
Posted on Apr 24, 2015
3 Suggested Answers
SOURCE: It trhinks that there is
IT IS THE COMPLAINT OF AUDIO JACK.THERE MAY BE SHORT CIRCUIT.SO CHANGE YOUR JACK.PLS VOTE ME
Posted on Sep 25, 2010
SOURCE: i have the wired headphone symbol on the top of my
Hi I have the same problem on my HTC desire hd and my Mrs desire has just started having the same problem but i can't find anything to surgest how to fix
Posted on Sep 29, 2011
Receiver says headphone mode no sound
Check to see if the end of a headphone has been left in the headphone jack. If so, remove it. (Sometimes the break off and are left there).
If the jack is empty (the easiest way to tell is to insert headphones and see if they go in all the way), then open the receiver and see if you can disconnect the headphone jack. There is a sensor in the jack itself that senses when something is inserted. If it's stuck in the "closed" position it may think that headphones are inserted.
Other than that you may need to update the firmware or reset the thing back to factory defaults. There is usually a button on the back for this. Hold it in for a minute after you have unplugged it. Then plug it back in and test.
Feb 21, 2017 | Audio Players & Recorders
Denon avr 1700 hp/only. how do I turn headphones off only?? I reset but did no work. can I clear the memory by unplug power, fuses ect??
try plugging in headphones and unplugging them. the headphone jacks have a tendency to have a shorted contact in them that cause the unit to think there are headphone plugged in all the time. Only true fix is to replace the headphone jack, but pluggin and unplugging can temporarily clean the fault usually.
Sep 27, 2014 | Denon AVR-1706 Receiver
My i717 is stuck in headset mode
most likely you have the microswitch in the jack itself that is stuck or broken. Try pushing the headphone plug all the way in, and remiove it quickly a couple of times. If this does not work, you may need to bring it in for repair.
May 05, 2014 | Samsung SGH-i717 Galaxy Note HD LTE 16GB...
How do I set up music (radio from my pc) using headphones on my Nortel Networks phone, model #NTDU91? Is there a feature for that? Thank you
You should call in your local vendor and have this done.
They will need to install a jack that matches your headphone jack and punch it down to a certain pair on the phone system, they will also need to go into configuration programming and set the feature.
Config password and knowledge of wiring and programming required. Note you need to purchase a license to "re-broadcast" music on phone systems, paging equipment etc.
Canada license - http://www.socan.ca/licensees/faq-licensing
USA license - http://www.ascap.com/licensing/
Penalties:
The Penalties
Under U.S.C. TITLE 17, the law allows copyright owners to receive as damages for infringement between $500 and $100,000 for each work infringed
Nov 06, 2012 | Nortel Lands Phones
Fixed broken headphones but sound quality has plummeted
 it sounds as if the wires are wired wrong . yes it is best to solder the wires.all jacks are the same,yours will be stereo i believe. is the braid attached to the earth point, the two other wires attach to the centre of the plug and the other terminal point. these are right and left.
Mar 10, 2009 | Bose Around-Ear Headphones - Silver
My pioneer djm 600 mixer has a fault where the headphones are not playing properly though each ear and doesnt sound quite right it is not the earphones
do some cleaning in headphone socket by apply spray contact cleaner in it----then insert headphone jack in---out many times after applying  the spray.
Sep 18, 2008 | Pioneer DJM-600 Silver Professional DJ...
Amilo Pro V2035 - Broken Headphone Jack Stuck inside Headphone socket
Also remove the battery and any other removeable plates below the notebook to check for additional screws. Check if there are any rubberized "feet" or plugs covering access to still more screws. Keep screws and their locations organized in case they are different length.
Aug 12, 2008 | Fujitsu AMILO Pro V1000 Notebook
Stylus tip stuck in headphone jack(no sound!)
Yes, here is a guide to dismantle an original Nintendo DS:
How to dismantle a Nintendo DS.
If yours is the NDS Lite, just find this video in youtube:
"Disassembling Nintendo DS Lite"
And after opening it you may need to replace or try to repair the audio plug. In case you cant, then you must take it out (desoldering it with the stuck stylus tip and the mute switch, which is embeded in the headphone jack) and you can have your audio back.
As the audio switch and the jack only work to mute the speakers audio usually when you plug a headphone then you can lack of it almost all times.
Nov 15, 2007 | Nintendo DS Console
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
