Question about Garmin Approach S3 Touchscreen Golf Watch
It died and won't charge or turn on - Garmin Approach S3 Touchscreen Golf Watch
    Master:
  • 456 Answers
Could be the battery .. try taking the back off,take battery out and leave the battery out for 10 minuets ..then put it back in . this could help restart the charging cycle . if not then you'll need a new battery
Posted on Apr 24, 2015
Battery charging
Hi Patrick,
A rechargeable battery will eventually fail to accept a charge - just like your car battery.
The number of recharges a battery will be able to accept is dependent on a number of things, such as: temperature, if it is run to almost nothing before recharging (or if it is recharged after only being discharged slightly), how much of a load is on the battery and how fast (high amperage) or slow (low amperage) the battery is recharged.
Generally, cooler temperatures are better for batteries, as is using the battery almost completely before recharging rather than topping off after minimal usage, small loads are better (you don't have a choice in your GPS watch tho) and a slow or "trickle" charge is better than a fast, high current charge (you may not have a choice on this either). A few hundred discharge / recharge cycles is not uncommon - significantly less if the battery isn't cycled properly or used in harsh conditions.
I hope this helps!
Jul 01, 2013 | Bushnell Neo Plus GPS Watch
It appears that the battery died and when I replaced it, the screen still won't turn on.
after replacing the battery you had to reset it. short the pads inside your watch or push all the buttons of your watch at the same time
Jul 08, 2011 | Watches
Bought jr3090-58L in nov 05. won't charge. watch is dead. what do I do next. It has spent more time in the window than on my wrist.
It sounds like you have had trouble with this from day one, the problem is the solar cells are not charging the battery, or the rechargeable battery is defective. I recommend returning the watch if warranty is still in place.
Jun 06, 2011 | Citizen EcoDrive Blue Angels Skyhawk...
Mtg 900 comes up charge and says recover. What do i need to do? I tried charging it under a lamp for several hours but that does not last long.
I have a watch which is solar type and the instructions say that several hours of sunlight will charge the battery but lamps need much longer (1 -2 days!), my watch now is left in a drawer.
If you haven't got instructions for your watch, to check what Casio recommend, you can get them on the net.
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Apr 05, 2011 | Casio Atomic-Solar MTG900 Watch
MY CHARGE DIED ON MY GSHOCK FROGMAN HOW DO I CHARGE IT
Select "support" and the "manuals", watches;
Accept terms
Mar 18, 2010 | Watches
Beep and chime will not work
I think there would have been a minute spring coming from the back of the watch module to the backplate of the watch - this spring carried a vibration / beep which echoed off the backplate. Chances are you have damaged this spring during battery change - as i did with my gShock. Basically it's nackered!
May 31, 2009 | Timex Watches
Casio Pathfinder PAG-50 battery replacement
ensure all three of the springs are present
the 2 at the top confirm that the case is closed the on at the bottom sends the sound signal.
ensure the metal casing on the back of the movement is not touching the back. and check the movement is correctly seated
Mar 28, 2009 | Casio Watches
How to Change battery Diesel DZ7040
dont do it yourself it will invalidate the warranty bring it back to the shop the should replace the battery free of charge. it might be more than the battery. if this helps please rate. joe
Oct 04, 2008 | Diesel Audio Diesel Watch
Garmin Approach S3 Touchscreen Golf Watch Logo
742 people viewed this question
Top Garmin Watches Experts
Rick Ostrowski
Are you a Garmin Watch Expert? Answer questions, earn points and help others
