Question about Dometic Heating & Cooling
My new rooftop dometic ac is unbelievably loud. Mind u, I've been using fans with windows open,prier. It's hot now. we installed , doesn't vibrate ,just loud!
    Genius:
  • Dometic Master
  • 1,363 Answers
Might have to remove cover on roof to isolate noise.
Posted on Aug 19, 2015
  • 127 Answers
SOURCE: Compressor doesnt come on in a dometic duotherm
If this is a wall thermostat controlled unit, then check to make sure that you have power coming from the yellow wire on the thermostat when it is placed in the Cool/Auto High mode. If you do not have power at the yellow wire, then you have a bad thermostat. If you do have power, then remove the control unit from the inside of the AC and see if you have power at the Y terminal there. If so, when you turn the thermostat to cool, can you hear a relay clicking in the box? If not, then you have a bad control box. If the relay is clicking, you need to check the power at the compressor relay on the board. It has a black wire to one side and a purple (or blue) wire on the outgoing side. Check to see if you have 120V on the blue wire when the tstat is set to High/Cool. If not, then you need to bypass the freeze switch to make sure that is not the problem. If you do, then you need to go upstairs and check the start capacitor for OK. It is located in the side compartment of the upper unit, it has a small black relay on the top called a PTCR. These often burn out and will cause the compressor not to work. If that is fine, then you go to the top of the compressor to the thermal overload switch. See if you have power at both sides, if so, then you have a bad compressor. If not, then the overload switch is open and not allowing power to the compressor.
Posted on Jul 04, 2009
SOURCE: I have my dometic Rooftop AC unit. The
Let it cool off.Install a hard start kit on the run capicator.Its only 2 wires & easy to put on.It should kick over.
Posted on Mar 16, 2010
  • 59 Answers
SOURCE: How to identify the btu of rooftop AC unit
ANY # DIVISABLE BY 12. MODEL HAS  12-24-30-36-40-48-54-60 12 1 TON 24 2 TON 30 2 1/2 36  3 TON 36.00 BTU 40 3 1/2 48 4 TON 48.00 BTU 54  4 1/2 60 5 TON   60.000 BTU
Posted on Apr 21, 2010
motor1258
  • 6674 Answers
The compressor coming on does make a slight "humming" sound which is normal. Is the unit cooling properly? Do you think it is louder than before?
Posted on May 09, 2010
MOTORWIZJ
  • 1340 Answers
SOURCE: 2007 dometic Rooftop AC "high-lo" switch. What does it do?
YES WITH OUT A DOUBT .. DO NOT TRY TO RUN IT ON HIGH IT MAY DAMAGE YOUR GEN SET ... HELP ? PLEASE VOT
Posted on May 28, 2010
Dometic caravan rooftop airconditioner fan is making a loud ticking noise
remove the cover off a/c on roof. should be able to see if fan blade or squirrel cage are hitting anywhere while running.
Jan 04, 2014 | Dometic Heating & Cooling
Dometic ac model # 57915.741 Ac is vibrating bad when on.
Hopefully there is just something in the blower wheel. Unless you can get to it from the ceiling of the RV you will have to take the cover off the unit to get to the blower assembly. The blower is the front fan that blows the air in to the trailer. If you can get the grilles off of the ceiling, turn the unit off and use a flash light to see if there is something stuff up in the actual blower or the assembly.
Jun 26, 2011 | Dometic Rooftop RV Air Conditioner
I have a 1999 camper with a Dometic rooftop AC . The fan motor will not turn,Where in Oklahoma can I find a new motor.
I wouldn't run out and buy a fan just yet. Have the fan start capacitor checked and/or changed. It is the most likely culprit.
Jul 26, 2010 | Dometic Rooftop RV Air Conditioner
I have my dometic Rooftop ac unit. The heatstrip/fan run perfectly but when I turn on the ac...the fan runs good but when the compressor kicks on it just hums.
May 09, 2010 | Dometic Rooftop RV Air Conditioner
I have a dometic roof mounted air conditioner 3300 series and it developes this vibration like a real loud hum
sounds as if the fan motor bearing have worn out lettin the fan cage wobble upon reaching full speed hence the vibration. There also could be build up of debris in the fan assembly. Good luck on your repairs
Dave
Oct 16, 2009 | Dometic Rooftop RV Air Conditioner
RV ac is vibrating
Take a good look at fan blade for a crack in one or more, as well as turn unit on & watch for vibration , then take a look at mount bushings on all items. Also with fan off (obviously) check shaft for movement, side to side, up & down, in & out. Your gasket between roof should only be compressed approx half it's original thickness. Some manufacturers tighten them down too much and can be a source of vibration as well. Not expensive or hard to change. Don't forget blower wheel as well.
Jul 21, 2009 | Dometic Rooftop RV Air Conditioner
Relay (?) sticking Dometic RV rooftop AC
Go up on the roof of the unit and remove the AC Shroud. With the unit running, see if you can pinpoint where the sound is coming from. The only thing on the entire AC that would make that much of a vibration would be the fan motor. Not sure what would cause the fan motor to do this. The compressor may do that but only if the windings are bad and then it would not be cooling.
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
AC unit on Viking popup is loud and vibrating
take the cover off the front of unit and look down inside at the blower wheel see if there is something in it
Jan 22, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
