Question about Franke Coffee Makers & Espresso Machines
I have a franke h automatic coffee machine but no milk is filtering through the nozzle I have tried pressing the cleaning cycle of the milk frother but that does not seem to help? Only had it 4 weeks
  • Anonymous Apr 24, 2015
    I don't have a problem with steam that's working perfectly
dutchman05
  • 487 Answers
SOURCE: mr coffee ecmp40 how do you get milk frother to work?
press this link and order free
Posted on Apr 24, 2008
SOURCE: No milk,or steam coming from cappucinno nozzle
If you pull the cappacino component off. The black plastic thing at the end of the metal tube (where the cappacino component's attached to) can be unscrewed by rotating it with your hand. You can clean it with a brush and a thick needle to clean the hole the make sure that it's not blocked. After that just screw it back on and reattach the cappacino component.
Posted on Jan 09, 2009
  • 39 Answers
SOURCE: frother doesn't froth
Does not seem normal! You should get plenty of steam for the frothing. Since the unit is new you should take it back and get a replacement. The unit needs to increase the temperature for steam, route the steam away from the espresso group to the steam unit and the pump needs to activate to create the high pressure. Any failure in this areas will create your condition. It also possible that your steamer is blocked but this is a new machine so this is unlikely but you should make sure that it is not blocked.
Posted on Dec 31, 2009
SOURCE: Flashing red light. Nespresso Citiz & milk coffee machine.
problem is overheating at a single point in the bottom of the milk container. Try cleaning the milk residue after each time you use it and the flashing red light disappears. This is a design fault. Nespresso are happy to keep marketing the Citiz but there is no fix - so the Nespresso "mess free" coffee machine is a bunch of flannel - good coffee all the same!
Posted on Sep 05, 2010
wentlanv
  • 710 Answers
SOURCE: I have a De Longhi EN 265BAE Citiz & Milk machine.
Hi rspence423,
You aren't by any chance writing from Australia?
Parts are pretty hard to come by online except there.
You will have to contact DeLonghi customer care to order the part. Here is their contact page: >>>> http://www.delonghiusa.com/index.php?texts&pid=3
DeLonghi is structurally identical to Krups. If you can't get anything from DeLonghi, you could try doing a google search for Krups parts and contact a customer service person at one of their parts suppliers.
Good luck.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 26, 2011
How do I check the milk brother valve on my coffee machine
saphira? check the air nozzle on top of the cappu-outlet . if the machine indicates that you should descale, the cleaning cyclus wont work. to descale you have to turn off the machine by pressing the on-off button on the front side (behind the tea-and steam button). if the machine is turned off, press the descale button for 3 seconds. after the descaling cyclus you will be able to clean the machine.
Nov 05, 2014 | Franke Saphira Espresso & Coffee Maker
Tip
Nespresso Aeroccino Automatic Milk Frother Instructional Video
Click on the link below for the user guide for the Nespresso Aeroccino Automatic Milk Frother - http://www1.nespresso.com/precom/accessories/demo/aeroccino/index.php?lang=en
on Apr 27, 2011 | Nespresso Aeroccino Automatic Milk Frother
Delonghi problems
Try filling both water and the milk container with the correct decalcifying solution - just slit the 500 ml that results from the 1:1 mixture and - without the coffee capsule - press the cappucino button. Instead of cappucino you will get the decalcifying solution running through the entire system including the connector for the milk container (unlike the recommended decalcification method where you use the extra nozzle). Good luck - worked for my machine which only produced steam but no milkfoam...
Aug 02, 2014 | De'Longhi En520.W Nespresso Lattissima...
The milk frother just boils the milk and does not froth it up any more
Hold the frother arm and pull the lower section off (It is in two pieces ) With the lower part off use a chopstick or something similar to push the small plastic nozzle out from the lower section,push from the narrow end .It will come out with a click,you will probably find it is blocked with dried ?congealed milk. Leave it to soak inhot water/wash up liquid and then use a nail brush to clean it also clean inside nozzle . Press nozzle back into sleeve untill it clicks into place and replace
Jan 21, 2011 | Gaggia Classic Espresso Machine
Our PrimaDonna coffee machine doesnt appear to be takeing in any milk from the jug to make latte's or cappuciono's, is there any way of sorting this out ?
Most common cause of this problem is a blockage in the milk jug. First thing you should try is soaking the complete jug top in a quality milk line cleaner (available from specialist coffee machine retailers) for at least an hour and then rinse thoroughly. Then try running a fresh cleaning solution through the jug instaed of milk. Good luck and post again if this doesnt work.
Nov 25, 2010 | DeLonghi Prima Donna Avante ESAM6700...
Milk does not foam
Look at the milk frother.
Ensure there is the end of the inner nozzle poking out.
If not remove the frother insert a pen and push the inner towards the end until a click is heard.
Job done.
Jan 23, 2010 | Gaggia Classic Espresso Machine
My nespresso aeroccino machine seems either quirky or moody: sometimes it froths the milk, and other times it just kind of heats it up and stirs it, even though I'm pouring the right amount of milk in and...
THEY SAY MILK MATTERS. SKIM OR LOW FAT BEST. ALSO MAKE SURE IT IS CLEAN, WHEN YOU ARE CLEANING IT, REMOVE THE FROTHER, TO BE SURE MILK DOES NOT STUCK IM COIL, WHICH CAN MAKE THE FROTHER, NOT MOVE AS QUICKLY AROUND.
Jan 19, 2010 | Nespresso Aeroccino Automatic Milk Frother
Coffee Makers & Espresso Machines Logo
100 people viewed this question
Top Franke Coffee Makers & Espresso Machines Experts
frankecoffee
Level 1 Expert
Jay Finke
Jay Finke
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
