Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
I assume that the password you are looking for is for logging at the motorola's settings page (and not for computer's log in screen) In this case the usual pairs (username-password) for Motorola's routers are cablecom-router or admin-motorol. In case you don't come to a solution, reset the router using the proper button and try to log in again using the credentials given. In case the password is for connecting with the provider you have to ask the provider.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer. If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards Please kindly rate this solution Stelios direct FixYa link: http://www.fixya.com/users/technical114
You posted your password and username. Anybody can take the details and use your account. Ask Fixya to remove it for your own good. http://www.fixya.com/contact
To answer you, try putting in browser 10.1.1.1 see if you can get to the modem's menu.
Press RESET button for 10 seconds it is in back side of router then all settings defaults.Then you can configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
For that you need to reconfigure router.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless ->wireless security then enable WEP then enter new password save settings and restart router.
Then you can connect wifi with that new password.
http://192.168.15.1
or
http://192.168.2.1
Then you can see configuration page of router. Then click on wireless settings then wireless security then enable WEP and enter WEP code it is your password to connect wifi.
Then save settings and restart router.
For that you need to access your router. For that Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.0.1 or http://192.168.1.1 For belkin router http://192.168.15.1 or http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then WAN settings configure your router as pppoe connection then add user name and password then Enable DHCP then save and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Usually on modems, the default password is password, and the default username is admin. If this doesnt get you on then the only way is to reset the entire modem.
