Question about One For All Televison & Video
How to program a one for all remote model 3050b00 to work tv converter.
    Top Expert:
  • One For All Master
  • 74,630 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Posted on Apr 24, 2015
SOURCE: Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Posted on Jan 17, 2009
SOURCE: programing rca digital tv converter remote to work
I found an owners manual online. It took some hunting, though.
Posted on Jun 07, 2009
  • 403 Answers
SOURCE: i need the code for a zenith sr1641y tv
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Posted on Sep 25, 2009
  • 1218 Answers
SOURCE: NEED CODES FOR RCA CONVERTER BOX TO PROGRAM TV TO REMOTE
Good day,
I might be missing something here, but if YourTV has the basic controls on the TV itself, such as on/off volume, and channel select, then just turn on tv, and set it to channel 3.
Use your converter box remote to scan for channels, and other options it has as needed.
Posted on Jan 23, 2010
  • 23 Answers
SOURCE: Cant get program codes to work on AKIA tv with rca converter box
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
Posted on Feb 18, 2010
Need codes numbers one for all remote 3050b00
You can use the code search feature of your remote to try to find a code that will control your Sylvania TV. If a search through all codes stored in the remote fails, you may have to try another universal remote.
Mar 08, 2015 | Sylvania Televison & Video
Need code remote 3050b00 tv/dvd combo
What manufacturer is the combo tv/dvd? as codes are based on the set rather than the remote. 3050b00 is a universal remote that workes with any set as long as you enter the manufacturers code.
e.g Toshiba = code No 1133 or 1134 You should find a full list here:
http://www.hifi-remote.com/manuals/manual.shtml?URC-3050-codes
Hope this is of help to you.
May 06, 2014 | Sylvania Televison & Video
I have a Magnavox SDTV converter box. It did not come with a remote because it was a display model at Walmart. It is plugged in, but will not come on. I have a Philips Universal remote, model #...
Start by turning on your Magnavox converter box. The switch is on the right side. Turn on your TV. If the box has been connected correctly to your TV, you may see something ...BUT you cannot perform setup or any other important functions without the Magnavox remote. A universal remote, unless it specifically includes Magnavox converter control capability, will not work
Dec 02, 2012 | Philips Televison & Video
I need to program my remote to work on my tv ,dvd,vcr player.
Universal remotes will only work with the devices they came pre-programed with. You'll need to check the documentation to see if they work with your particular model of tv combo device. If your remote does not support the digital converter, you'll need to get a new remote that does. If you don't have your documentation, you may find information at http://www.remotecodelist.com
Nov 22, 2011 | Televison & Video
Will my tv remote work on my converter box?
If the tv remote is the original TV remote, it won't control the converter box (if this is an digital-to-analog converter). If it is another remote, then maybe. It depends on the remote and when it was programmed.
Most remotes are limited to codes for devices released at least 6 months before the remote was programmed. Thus is your TV remote was programmed in late 2006, then it may have the right code. Some universal remotes support the converter boxes; others don't. If you provide additional information on the remote, I may be able to give you more specific details for your situation.
I hope this helps.
(any tv that requires a d-t-a converter box was built before any plans were finalized for the converter box.)
Sep 17, 2011 | Televison & Video
I need the code for a zenith sr1641y tv remote. i have a 3050b00 universal
Note:
Sep 24, 2009 | One For All URC4220 Remote Control
Remote Control
From GUEST: I found this solution in the manual and will perform this task again to see if I can get the tv will be re-recognized again. Give this a try, too.
Remote will not turn on or shut off the TV.
• You must program the converter box remote in order to control your TV power button.
• To program the remote control:
    1. Determine if the TV is a model that can be controlled by the remote control. See "Controllable TV brands" on page 17 in the manual.
    2. Turn on the TV.
    3. While you press and hold TV POWER on the remote control, press CH ^ or CH v one or more times until the TV turns off. Each time you press one of these buttons, the remote control sends a manufacturer code (between 1 and 45) to the TV.
Sep 01, 2008 | Insignia Digital-to-Analog Converter for...
Analog Pass-Through DTV Converter Box with Remote Control (3 digit code for the Remote Control
i can not get my tv to pick up a signal.I know my antena works i have tried it on other tvs.Has anyone else had this problem or know how to fix it?
Aug 04, 2008 | Philips Magnavox 20MT133S 20" TV
The short version: Will a 14-year-old TV work with digital-to-analog TV converter? Specifically, I have RCA Model G25342AT, built in Sept., 1994. In case yes, converter should work... Trying to connect...
The converter box should work. Getting the remote to work with the TV might be a challenge. You might have to stick with two remotes. It used to be in the old days you could plug your tv power into the remote that way you would turn the tv on with the tuner remote but I be they stop doing that.
There is website that will let you check the digital televison signals for your area. This site should help you:
http://www.tvfool.com/?option=com_wrapper&Itemid=29
Jun 29, 2008 | Televison & Video
Televison & Video Logo
57 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
