Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Dd603 will run longer then it set to run
Set timer to a certain time and the dishwasher will run over the set time and not turn off
3 Suggested Answers
  • 784 Answers
SOURCE: my dishwasher is model DD603 and it turns on by
There is a water leak in the bottom housing and a leak sensor detects to give a F1. Pull out the tube and put your hand in the front from the left ( only on this side has enough room to access) with the small towel to dry out the water on the bottom housing. After dry out, unplug the power for at least 24 hours so the sensor can be dried out and reset. However, make sure to fix the leak from the top seal, otherwise, it keep happening.
Posted on Nov 01, 2009
jyackle5
  • 8197 Answers
SOURCE: Fisher and Paykel dishwasher DD603 manual
You can get the manual below for free..
http://www.fisherpaykel.com/admin/pdfs/pdf_usecares/527971B_DD_user_guide_USw.pdf
Good Luck and please rate 4 thumbs for the free answer
Posted on May 15, 2010
Is the timer button for lengh of usage or to set to come on at a certain time
Timer is normally for Length of use. Generally a run down clock.
and Alarm is when it comes on at a certain time using the present clock.
Try it out with a small number for example 1 or 2 minutes
Sep 22, 2016 | Hardware & Accessories
U3
The dishwasher is filling up too quickly compared to what the controller expects. Try to turn down the water inlet tap under kitchen sink and check. Also see if the water pressure setting in the dishwasher is HP for normal mains water pressure. See
DD603 U3 fault code
Feb 10, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Why does my tv turn off automaticly
Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. Malena!!
May 10, 2012 | Vizio Televison & Video
I have digital programmable timers (Model DT121 and Model DT11) that will accept programs, but won't turn the attached lamps on and off at the programed times. The batterys are new and I've had them...
DT121 Manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt121c%20-%20english.ashx
All Intermatic manuals
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Intermatic does not show DT11
Intermatic shows the DT121 is no longer available
If the display shows and you can set programs, then the battery is good.
Does the manual override work? This indicates whether the timer on-off switch operates.
If manual override does not work, then I discovered that timers are no longer any good
Programming:
Set present time
Then set ON time for program 1
Set OFF time for program 1
Then set ON time for program 2
Set OFF time for program 2
Most timers will not function if there is a conflict in programming > for example Program 1 says ON at 6 and OFF at 7 and Program 2 says opposite or has overlapping times
When events are set, press SET once > this will put timer in RUN mode
If manual override works, and you set programming correctly, but timer does not carry out instructions, I guess the timer is no good.
Intermatic has 24 hour timers with 2 on-off per day
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/lamp%20%20appliance%20timers.aspx
Intermatic has 7-day digital timers (all digital timers today are 7 day where you select the day that each program works)
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers.aspx
Oct 12, 2010 | Intermatic Hardware & Accessories
..not able to set timer to come on and go off a certain time
the pin for the timer and be any color.
if you have the pin in the right place, and turn the timer dial to the time you plug into the wall and turn on the black switch on the side. it shoud work.
check the timer after couple of hours. and make sure the timer is running correctly.
chances are there is a flat spot on the timer. it stops at a certain spot.
hope that helps
Apr 09, 2009 | Intermatic & Lighted Dial Timer
Running time of dishwasher
he cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Cycle not completing See "The cycle doesn't complete" section.
The cycle doesn't complete If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Mar 14, 2009 | Bosch Dishwashers
Cycle runs for 2-3 or more hours
If your dishwasher's cycle times are too long, check these: Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
Cycle not completing f the cycle doesn't complete, check these:
Oct 23, 2008 | GE Nautilus 24" Built-in Dishwasher
None use for 7 days
I have a fisher paykel dd603 dishwasher. If I select the normal wash setting on the top drawer, it posts the time in the lcd screen as 56 mins. The unit will wash as usual until it reaches the 28 min mark. At this point it will stay on 28 mins and continue to run, but it won't rinse or empty the drawer of water. Also it never counts down below the 28 min mark. It has flashed a F4 and F1 code. I've cleared them both, and checked to make sure that no water is standing on the bottom of the unit, and that the heating element is working. I should mention that the top drawer did overflow about two weeks ago, and that I did clean up the water. I don't know where to look from here. Any suggestions?
Sep 10, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher keeps running
I have seen this several times, and all of the times it has a bad control board. usually if you take the control board out, you can see a visibly burnt spot on the back of it wher a connection has melted. Another possible slowrun time problem could be that the water coming into the dishwasher when it fills is not hot. If it isnt hot, it takes the dishwasher longer to heat the water to temp, and therfore it runs longer. Is the water coming out of your tap reasonably hot? if not you may need to turn up your water heater settings. But if nobody has messed with the water heater, or the tap where the dishwasher is attached and the problem just started then thats probably not it. Good Luck!
Aug 04, 2006 | Bosch 24 in. SHU43 Built-in Dishwasher
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
