Question about Frigidaire FFRA0811Q1 8,000 BTU Window Room Air Conditioner with 9.8 EER, R-410A Refrigerant, 1.7 Pt
The cord for this unit got wet, and im fairly sure the fuse inside the cord tripped. It refuses to turn on.
I have a few other units in my garage that have functional cords, but they are a different brand. Would it be feasible for me to use one of these cords as a replacement as long as voltage matched?
  • Official Brand Answer
  • 2,267 Answers
Hello friend, thank you for your post!
I understand that the power cord to your Frigidaire air conditioner got wet and you would like to know if you can change the cord with a different brand. Even though the cords may be the same voltage it would not be recommend to interchange the cords. I would suggest contacting your manufacturer for proper replacement parts. I hope this information is helpful. -Matt
Posted on Apr 30, 2015
SOURCE: current device on cord trips
Sound to me like its pulling too much amps due to back dirty coils, check this coils where the fan blades throw the water on the coils ,this could be getting clogged! or low on freon, not enough cool gas to keep the compressor from getting hot!I
Posted on Aug 27, 2008
  • 420 Answers
SOURCE: AC Power cord pulled out of window AC unit
The main power connection is typically behind the panel with the power, speed and thermostat switches.
Posted on May 26, 2009
cj2176
  • 520 Answers
SOURCE: My window unit fell out of the window and hung by
Its most likely is not the switch. It is most likely the cord though. Due to the excess strain on the cord it has probably cut through the rubber coating on the wire and connected to the frame and grounded the hot lead. Fix the cord and you may have it handled.
Posted on Jun 15, 2009
SOURCE: GFCI cord not long enough
Hi! Connie, You can use a heavy7 duty appliance cord for this. It has to be for air conditioners or appliance cord to be as short in length for use needed. I believe not to be longer than 8 ft or so. I had to buy one for my air cond. and needed only 2 ft and got a 4 ft one and no heating up of cord at all, and thats on a 110v and the larger too 12,500 btu and works great!! Can be found at most hardware stores best buy store or any appliance place that sells air cond should have it. The manufacturer is trying to avoid the buyer using a long extension cord like a 15footer and not heavy enought o handle the load either. Hope this helps it works great for us!!! Debbie
Posted on Jul 20, 2009
  • 1033 Answers
SOURCE: I have a model #
Hello, i have replaced cords on many window units so yes you can replace the cord. I believe if you go to a online appiliance website they will have the cord you need. I have found this website online with frigidaire parts http://www.repairclinic.com/Shop-For-Parts?s=t-faa065P7a-==
Posted on Apr 25, 2011
After power outage, we had to pull the release cord to disengage the opener. Now that the power is back on, how do you re-engage the door with the unit so it will function?
These usually attach to each other with a slide lock. What you can do is command the door to stop within a few inches of the cord release. Then lift the door without pulling the cord until the door engages to the lift. It may take a little pressure and repeated cycles to get it to engage. Be sure that the cord release is not stuck. Cycle it a few times by pulling on the cord and watch the lock mechanism to make sure it is operating correctly. Your door is adjusted so that the opener senses a little pressure on the door to make sure it is completely closed. So if you just try to open and close the traveler may not quite make it to the disconnect. That is why you need to engage them manually. I hope this helps you. This is a real common problem with garage door openers.
Nov 01, 2017 | Building Materials
Optical cords
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window " to get gathered related posts.
Apr 07, 2016 | Element Televison & Video
I did not say CORD, I SAID CODE for neonIQ lcf 3218 remote control
Whatever you said; isn't matter. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
Jan 27, 2016 | Televison & Video
Garage opener only opens with remote underneath the unit.
Here are some things to check. Some of this pertains to your problem and some doesn't.
Limited range of your remote controlscould be related to radio frequency interference that comes fromsomething in your home or in the surrounding environment. Certainelectrical devices can radiate interference; this could be almostanything that is plugged into an electrical outlet.
Please keep in mind that the device canbe brand new, or can be an item that has been in use for quite awhile. Also, the item may continue to function properly as far asyou are able to tell. The only problem with the item may be that ithas started to broadcast the interference, with no other symptomsnoted.
Some devices are more likely togenerate interference than others. This includes TV cable, cableamplifiers, surge protectors, fluorescent lights, battery chargingdevices (power tools, golf carts, etc.), anything that utilizes atimer (sprinkler systems, lights, alarm systems, etc.), and a myriadof others. If the problem seems sporadic, we can safely assume thatthe device responsible for the interference is only being operatedduring these times. Again, please keep in mind that the age of thedevice does not determine if it is capable of broadcasting unwantedinterference. Any electrical device can be the source of the problem.
The first step is replacing the batteryin your remote. If the range on your remote does not improve, removethe wall control wires from the overhead unit. If the range does notimprove you will likely need to replace the remote control. Afterreplacing the remote, or if you have other remotes programmed in tothe opener, and the range problem still exists, please proceed to thePower Down test.
Multiple garage doors:
If you have two garage door units andone is working just fine, you will need to start by unplugging thegood unit. This will help determine if the unit with no range startsto function properly. If the range comes back to the bad unit thenyou will need to replace the logic board on the unit that wasunplugged as it is emitting an RF signal that is over powering theother garage door opener. If the range does not improve after the“good” unit has been unplugged, replace the batteries and tryprogramming some additional remotes to determine if the existingremotes are the issue. If the extra remotes do not have any rangethen you would need to replace the receiver logic board in the “bad”unit.
Power Down test:
To isolate potential sources ofinterference, turn the circuit breaker off to the garage and plug thegarage door opener into an extension cord from another room. If therange improves, then the interference is coming from a device in thegarage. If no improvement is seen follow the same procedure, thistime turning off the circuit breakers to your home, with theexception of the garage and test the remote controls. If improvementis noted, turn the circuit breakers back on, one by one, until therange problem resurfaces. This will allow you to narrow down whatroom the problem device is in. You will have to go from there toisolate it further, by unplugging and re-plugging the items in thatroom.
If you are unable to determine anysource of interference, then the receiver logic board in the overheadunit will need to be replaced.
Jun 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Unit will not stay powered up. When plugged into DC power adapter, unit will power up but turns off after a few seconds. Unit indicates low battery. Unit had been successfully used during the previous 24...
Check the fuse on your power cord if it has one. Also try using a different power cord, perhaps one for use inside or use a USB cable if one was provided. Borrowing one or using one at an electronics store as a test may also help.
It sounds like the power cord you are using has stopped functioning and your battery is depleted and requiring a charge.
Feb 16, 2010 | Garmin StreetPilot C330 GPS Receiver
? can i program remot control for the garage dor
Make sure you have a fresh battery in the garage remote. Drive away about a block and park. Press the two outer buttons on the IS for about 20 seconds , they will flash 10-15 seconds and then go out,erasing any old codes in the car.
Then select a button position, 1-2-or3 on the car for your garage function. Hold your garage remote to the car's button pad and depress the garage remote button and the cars button (1-2 or3)continually. The LED in the cars touch pad will flash slow, then fast then go out. Once these steps are completed the car and your hand held are syncronized...thh car has recieved the remote function. That is step 1 for all vehicles.
Now you need to return to the garage and "introduce" your car to the garage door opener's receiver. Depending on the brand there will be a "learn" button on the garage door opener. You will climb a ladder and push the learn button as per instructions in the opener manual or on the stickers on the opener motor itself, if it is a Chamberlain, Liftmaster or Craftsman....
These buttons will be pressed to erase old opener codes or program to add new devices...which is what your car is.
Each opener has its own series of functions but generally after initial set up of the ceiling unit, you will depress the learn button and hold for several seconds. Then within 30 seconds , you will depress the cars button for about 2 seconds and release, the lights will flash on the ceiling unit in the garage indicating success and the next time you press the cars button the system works.
For complete detailed instructions go to the HOMELINK web site. It covers most cars by model and openers by brand with VERY detailed instructions.
Nice car! Enjoy and post back with results
Jan 30, 2010 | 2004 Lexus IS 300
The remotes including the keypad only work a few inches from the unit
Here is some info to check. Some will pertain and some will not.
Limited range of your remote controls could be related to radio frequency interference that comes from something in your home or in the surrounding environment. Certain electrical devices can radiate interference; this could be almost anything that is plugged into an electrical outlet.
Please keep in mind that the device can be brand new, or can be an item that has been in use for quite a while. Also, the item may continue to function properly as far as you are able to tell. The only problem with the item may be that it has started to broadcast the interference, with no other symptoms noted.
Some devices are more likely to generate interference than others. This includes TV cable, cable amplifiers, surge protectors, fluorescent lights, battery charging devices (power tools, golf carts, etc.), anything that utilizes a timer (sprinkler systems, lights, alarm systems, etc.), and a myriad of others. If the problem seems sporadic, we can safely assume that the device responsible for the interference is only being operated during these times. Again, please keep in mind that the age of the device does not determine if it is capable of broadcasting unwanted interference. Any electrical device can be the source of the problem.
The first step is replacing the battery in your remote. If the range on your remote does not improve, remove the wall control wires from the overhead unit. If the range does not improve you will likely need to replace the remote control. After replacing the remote, or if you have other remotes programmed in to the opener, and the range problem still exists, please proceed to the Power Down test.
If you have two garage door units and one is working just fine, you will need to start by unplugging the good unit. This will help determine if the unit with no range starts to function properly. If the range comes back to the bad unit then you will need to replace the logic board on the unit that was unplugged as it is emitting an RF signal that is over powering the other garage door opener. If the range doesn not improve after the “good” unit has been unplugged, replace the batteries and try programming some additional remotes to determine if the existing remotes are the issue. If the extra remotes do not have any range then you would need to replace the receiver logic board in the “bad” unit.
Power Down test:
To isolate potential sources of interference, turn the circuit breaker off to the garage and plug the garage door opener into an extension cord from another room. If the range improves, then the interference is coming from a device in the garage. If no improvement is seen follow the same procedure, this time turning off the circuit breakers to your home, with the exception of the garage and test the remote controls. If improvement is noted, turn the circuit breakers back on, one by one, until the range problem resurfaces. This will allow you to narrow down what room the problem device is in. You will have to go from there to isolate it further, by unplugging and re-plugging the items in that room.
If you are unable to determine any source of interference, then the receiver logic board in the overhead unit will need to be replaced.
Jan 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
What are the different functions of the remote
CAN BE USED TO CONTROLL ANOTHER VEHICLE IF EQUIPPED WITH SAME UNIT. CAN BE ALSO USED FOR WINDOW ROLL UP OR DOWN. GARAGE DOOR OPENER, ECT.
EXTRA PARTS AND WIRING IS REQUIRED FOR THESE FUNCTIONS TO WORK.
Aug 31, 2009 | Audiovox Prestige Code Alarm Remote Alarm...
Frigidaire FFRA0811Q1 8,000 BTU Window Room Air Conditioner with 9.8 EER, R-410A Refrigerant, 1.7 Pt Logo
93 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
