Question about Eclipse 180g2 4gb mp3 music/vid
I try to sync my music and all my eclipse says is USB connected. what am I doing wrong/
  • Eclipse Master
  • 5,631 Answers
Check if your files appear in computer as Removable Disk. Copy/pate or move your music to MUSIC folder of Eclipse
Posted on May 06, 2015
2 Suggested Answers
SOURCE: I tried to sync music
I called Mach Speed technical support at (580) 272-0035 and they told me that model CLD2PL cannot handle music being in folders. So I removed the folders from the mp3 player and copied over the music again (as single files) and now it works. Hope this helps.
Posted on Dec 28, 2010
My eclipse fit clip shows music in the folder but wont play any
seems like the names were copied but not the music files try syncing with Windows Media player form a playlist
Dec 05, 2015 | Eclipse Audio Players & Recorders
For some reason, can't sync music to my Eclipse from my computer.
You don't need to sync with Eclipse. When you have it connected to your computer as Removable Disk, you can copy your music files from your computer to the Music folder (I believe so it is called)
Jul 01, 2015 | Eclipse Audio Players & Recorders
How do I download songs on my eclipse mp3 player
Things You'll Need
Microsoft Windows 7 computer with an open USB port and iMesh installed
USB cable compatible with Eclipse MP3 players
Instructions
  • 1 Plug a USB cable into the Eclipse MP3 player. Plug the other end of the USB cable into an open port on the Windows 7 computericon1.png.
  • 2 Click the "Start" button on the Windows 7 desktop taskbar and click "Computer" in the menu that appears. Click the "Music" item located in the left pane of the "Computer" window that appears. Double-click on the "iMesh" folder. For Windows 7, XP and Vista. Recommended. Download Now.
  • 3 Click the "Start" button on the Windows 7 taskbar and click "Computer" and then double-click on the "Removable disk" icon that represents the Eclipse MP3 player device. A window will appear displaying the contents of the Eclipse MP3 player storageicon1.png area.
  • 4 Right-click on a music file in the "iMesh" directory that has the "mp3" suffix, and click "Copy" in the menu that appears.
  • 5 Right-click on empty space in the "Removable disk" window and click "Paste" to copy the music file to the Eclipse MP3 player device. Repeat for each file you wish to download to the Eclipse MP3 player.
    To copy multiple music files at one time to the Eclipse MP3 player, press and hold the "Shift" key on the keyboard. Click once on each file you wish to copy. Right-click on one of the highlighted MP3 music files and click "Copy" in the menu that appears. Right-click on empty space in the Eclipse "Removable disk" window and click "Paste."
Oct 21, 2014 | Audio Players & Recorders
Eclipse V180 Series 8GB USB Help
Does it came with any driver/software cd ?
Dec 26, 2013 | Eclipse Audio Players & Recorders
My eclipse cld (2 gb) hooked up to my old computer just fine but now i got a new computer it only hooks up to charge but wont open up so i can put more music on it how do i fix this
I am not familiar with your model, but most can sync with Windows media player. (Connect it first) then If you open media player and click the sync tab on the right side, you can add tracks to your device and then click sync when you are ready.
Dec 18, 2011 | Eclipse CLD2 MP3 Player
My Philips Gogear is not recognised by my PC so I cannot download or upload music
Use the USB port at the back of your computer.
Set to MSC mode of your player. Select Settings -> PC connection preference.
Try to avoid using a USB hub. Try to avoid using a USB extension cable.
Oct 23, 2011 | Audio Players & Recorders
I cannot find the drivers for my son's new Eclipse 180 series 4 gig mp3 player and I need help. Thank you!
Hi Mommychrista,
Thanks for the question ,
To connect this media player you don't require any additional drivers but you can use the inbuilt windows media player if you are using windows XP, VISTA or Windows 7.
However please note that you need windows media player version 7 or more to get this player connected to it.
What you need to do , is open windows media player and then connect this music player to a working USB port via the USB cable which comes along with this music player.
Then Windows Media player will prompt you with a setup screen asking you to name the MP3 player.
Once you have named your MP3 player, select Finish, and your Windows Media Player will open to the Sync tab.
Drag your music to the sync list (on the right of the screen) from the list on the left.
Once you have selected the music you wish to add to the player, press Sync.
Windows Media player will load the songs on to your MP3 player.
Once all the songs you have added are synced to the unit, and Windows Media Player says that is safe to disconnect your MP3 player, disconnect the device.
If your son has all his music files that he needs in one folder , then he can follow another method of simple copy and paste.
This works as follows :-
Connect the music player to the computer via the USB cable, connect this cable in a working USB slot and the player on the other end.
Then you will find a removable device being detected in your my computer, that removable drive is the memory of your music player in which you need to copy files.
Just right click on that icon of removable drive and select open and then you can copy the folder that you want to copy by right clicking on the folder and selecting copy and then come back to the removable drive , which you have opened and then select paste.
This will copy the complete folder to your music player's memory.
Then you can safely disconnect the music player via the USB cable and then you will find that the files are being shown in the music player , ready to play for you ...:)
Hope that helps ..:) In case you have any queries, feel free to let me know , your feedback would be appreciated.
Sep 12, 2011 | Mach Speed Eclipse 180 MP3 Player
I moved my pics to my card but when i connect my data cable it syill just wants to sync music. what am i doing wrong
When you open the menu and the 4 tabs come up on the side hit the one all the way at the bottom, once in there hit the "MORE" button then on that screen go into "connections" and then "USB Connection Mode" and change to mass storgage but remember if you want to sync music to put it back on Music Sync....Hope this helps...
Mar 16, 2010 | LG Vu CU920 Cellular Phone
I can not download music from my PC to my Katana Eclipse X.
Hi, Welcome to FixYa
There are three ways to transfer files to your mobile. USB,Bluetooth,3G Upload
Using a USB connection:
The Sanyo Katana Eclipse is compatible with the "USB Mass Storage" norm.While linking your Sanyo Katana Eclipse to your computer should make it appear as a memory key. Open it and just drag MP3 or other sound or music files straight to your phone, as if it was one of your computer's folder. For the remaining steps, please refer to your Sanyo Katana Eclipse manual. The ringtone section should explain how to select an uploaded file as a ringtone. You can download user guide here
By Bluetooth:
The Sanyo Katana Eclipse is Bluetooth-enabled. Bluetooth is a wireless system which lets you connect your cell phone to computers, headsets, car kits, etc. If your computer is also Bluetooth-enabled, simply establish a connection between both devices and transfer your music files from your computer to your Sanyo Katana Eclipse.
Via a 3G Uploader:
If none of the above tricks do not work with your Sanyo Katana Eclipse or if you prefer not to buy new accessories, you can still use one of the numerous free "3G Uploader" services available online. 3G uploaders work as follows: Save your own music on their web site and they will provide a temporary URL. Navigating to that URL with your Sanyo Katana Eclipse's browser should download the free ringtone.
Thanks
Jul 16, 2009 | Sanyo Katana Eclipse X Cell Phone
Can't sync music!
you will need the software with media manager to sync music
Jan 11, 2009 | O2 Samsung SGH-E250 Cellular Phone
Eclipse 180g2 4gb mp3 music/vid Logo
185 people viewed this question
Top Eclipse Audio Players & Recorders Experts
Oloyede Monsuru
juanmireles1
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
