Cycling Logo
R
Rock Hayeur Posted on Apr 24, 2015
Can I replace a Shimano RD-TY15 with Shimano Tourney TX?
Help
kermit green
Level 1:
New Friend:
  • Contributor 34 Answers
  • Posted on Apr 30, 2015
kermit green
Contributor
Level 1:
New Friend:
Answers
34
Questions
0
Helped
12611
Points
78
Main thing with gears is that they have the same number of gears, and that the cage is the same length. Also the RD TY15 has a built in hanger.
The Tourney pictured has a built in hanger (below link) just make sure the replacement does.
SHIMANO TOURNEY TX 55 Rear Derailleur with Hanger Virtue Bike
Why cant I find any information on my Shimano Tourney RD-TY10 rear derailleur?
Because it's been out of production for some time. There's no useful info to be had anyway. It is adjusted the same as most any rear friction derailleur. It is not useable with indexed levers (click to shift). If you really think you need info do the following Google search: "RD-TY10 site:shimano.com" and scroll through the results.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
2answers
Can I replace a Shimano RD-TY15 with a Shimano Tourney TX?
This may be to do with the replacement having a shorter cage, so it can't go on the big sprocket and big chain ring at the same time.
Try to not use the big rear sproket and the the big front chaining at at the same time,
Exploded view of parts diagram for shimano tourney st-ef40 shifters for re-assembly?
If you can't find with a search for st-ef40 diagram or on the Shimano site then it does not exist. Although not identical carefully disassembling the other shifter may give you enough insight.
Parts assembly diagram
Shimano Tourney parts are one of their lower end component groups and as such are not really designed to be serviceable. Shimano uses a system of "controlled obsolescence" so that their components cannot be repaired. they are inexpensive enough to just replace them, and with all of the plastic that they use these days it's not worth the effort when a new derailleur can be had for $30.
How do i connect cable to front derailer on shimano comfort 050 gears ?
I'm confused, You show a rear derailleur and ask a question about a front one? Cable for front usually goes from bottom up, through an eyelet then into the holding bolt. Make sure your cable is in the low gear setting and your chain is on the smallest gear. Pull cable tight, and secure. If you have problems, take your bike to the nearest bike shop, they can help you
1helpful
Shimano tourney TX sis 1. Noise while shifting gear and in motion 2. Chain stucked up at sprockets.
This problem is best taken into a bicycle shop to have them look at it. Could be as simple as adjusting the cable tension, or as complicated as parts not in the correct location or functioning properly. The shop will be able to make a quick diagnosis once they can actually put hands to it.
Jan 02, 2011 • Cycling
1helpful
How to fit cable to shimano tourney FD-C050
Go to shimano.com and download instructions.
Top Shimano Cycling Experts
Paul Bade
john h
ADMIN Andrew
ADMIN Andrew
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
