Question about Shimano Cycling
Can I replace a Shimano RD-TY15 with a Shimano Tourney TX?
My bike is a 15 speed Hybrid& the derailleur the bike mechanic put on tonight doesn't seem to change gears well when I am on the big gear in the front & want to shift upwards on the back
    Problem Solver:
  • 19 Answers
It looks like you have had a 6/7 speed rear mech fitted.
Unfortunately this number of gears is only replaceable by another 5 speed rear derailleur, and Shimano only has two, the RD-TY15SS, and RD-TY15GS.
(See Shimano's Compatibility info PDF here:
http://si.shimano.com/php/download.php?file=pdf/dm/DM-RD0001-02-ENG.pdf
There is also the compatible Sunrace Brand Alternative, RDM15, viewable here:
Sunrace
If you don't use these, you are bound to have shifting problems due to the more narrow space difference between cogs on a six speed freewheel/sprocket.
Posted on Aug 24, 2015
    New Friend:
  • 34 Answers
This may be to do with the replacement having a shorter cage, so it can't go on the big sprocket and big chain ring at the same time.
Try to not use the big rear sproket and the the big front chaining at at the same time,
Posted on Apr 30, 2015
Why cant I find any information on my Shimano Tourney RD-TY10 rear derailleur?
Because it's been out of production for some time. There's no useful info to be had anyway. It is adjusted the same as most any rear friction derailleur. It is not useable with indexed levers (click to shift). If you really think you need info do the following Google search: "RD-TY10 site:shimano.com" and scroll through the results.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
May 05, 2017 | Shimano Cycling
Can I replace a Shimano RD-TY15 with Shimano Tourney TX?
Main thing with gears is that they have the same number of gears, and that the cage is the same length. Also the RD TY15 has a built in hanger.
The Tourney pictured has a built in hanger (below link) just make sure the replacement does.
SHIMANO TOURNEY TX 55 Rear Derailleur with Hanger Virtue Bike
Apr 24, 2015 | Shimano Cycling
Parts assembly diagram
Shimano Tourney parts are one of their lower end component groups and as such are not really designed to be serviceable. Shimano uses a system of "controlled obsolescence" so that their components cannot be repaired. they are inexpensive enough to just replace them, and with all of the plastic that they use these days it's not worth the effort when a new derailleur can be had for $30.
Apr 08, 2015 | Shimano Tourney ST-EF40 EZ-F 2-Finger...
How do i connect cable to front derailer on shimano comfort 050 gears ?
I'm confused, You show a rear derailleur and ask a question about a front one? Cable for front usually goes from bottom up, through an eyelet then into the holding bolt. Make sure your cable is in the low gear setting and your chain is on the smallest gear. Pull cable tight, and secure. If you have problems, take your bike to the nearest bike shop, they can help you
Sep 01, 2014 | Shimano Rd TX50 Tourney Mega Range Rear...
Shimano Tourney rear derailleur is stuck on smallest gear and will not shift. How do I adjust the tension correctly?
There are several things that could be wrong. You could have thrown your chain (you couldn't ride at all if so). The bike could have been crashed and the derailleur bent. The cable might have slipped where it bolts to the derailleur. Or the cable or shifter could need maintenance, too. It is most likely one of the above. If it is only the adjustment, there are two stop screws on the derailleur that can be adjusted.
My best advice for you is to either find a bicycle repair manual at a local bookstore or your library that can show you some of the detail. Or just let your local bike shop do the repair.
Aug 30, 2009 | Mountain Shimano Tourney 6/7 Rear...
Cycling Logo
848 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
john h
Paul Bade
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
