A/C error code F0 Westinghouse
A/C error code F0 I have change the capacitor that was damage, change the sensors of outside and still with the problem. The Console starts fine for 25 min, then the compresor shut down but the blower keeps running, after a while the compresor turns back on but it shuts down after a while again and it keeps repeating the process. the Psig is in 150 turn on and off goes to 250 more or less.
    Master:
    Sergeant:
  • 388 Answers
Here is the information i found on error codes i found on your brand. Westinghouse Air Conditioner Error Codes
If you need any more help i would suggest you call your local ac repair company.
AC Repair Fort Lauderdale
Posted on Apr 27, 2015
What does F1 mean
The Fault Code/s will show up in the appliance Display
F0 - No Alarm Signal
Replace Main Electronic Control
F1 - Door will not Lock
Check door lock. Is Door Lock Getting Power
F2 - Door will not Un-Lock
Check door lock. Is Door Lock Getting Power Supply? Check Control Thermostat
F3 - Self Test Error
Disconnect Appliance from Mains Supply, Wait 5 Minutes and then Reconnect to Mains Supply
F4 - Shorted or Open Circuit Oven Temperature Sensor
Replace Oven Temperature Sensor, Check Sensor Harness Connection between Sensor and Control Unit
F5 - Relay Contacts Failed - Sticking
F6 - Power Board Temperature Too High
Check Correctly Installed, Check Cooling Fan Assembly, Ducting and Airways
F7 - Incorrect Polarity - Mains Supply
Check Mains Connection - Live & Neutral round the wrong way
F8 - Power Supply to Interface Problem
Check Wiring Harness, Replace Main Electronic Control
F9 - Procesor is Auto Resetting
Apr 05, 2015 | Electrolux White Westinghouse Stove Range...
Double wall oven F0 error code
The F0 error code means that the control board has detected a defect within the control board itself, the F0 code can be cleared by pushing the CANCEL/OFF button and if it goes away and returns all is well,however if a short time later the F0 returns the control board would need to be replaced.
GENE
Oct 04, 2011 | GE Profile 30" Built-In Double Electric...
Hi, We have an error code that will not allow our oven to work. F3 keeps displaying on the oven panel. F0 pops up as well.
F0 - Shorted push pad / Replace
F3 - Shorted or open oven temperature sensor / Replace oven temperature sensor
Good luck.
Apr 28, 2011 | Microwave Ovens
Westinghouse LT819S 1F error and beep.
hello there
This is a verry common issue with these ovens
Here is the meaning and a few things to determine what is at fault i have it listed below
this error code can actually show up as any 1 of these and they all mean the same thing
F0 -
F1 - F7 Stuck keypad
may mean relay is turned on.or has
failed
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jan 21, 2011 | Kitchen Ranges
My kitchenaide convection oven is displaying the E1 F4 error.
KitchenAid ovens are popular for their classic design and simple user interface. When a problem occurs in the function of a KitchenAid oven, an error code will display on the clock as soon as the malfunction registers in the oven's memory. Each code corresponds to a particular type of malfunction. Most can be corrected by disconnecting the power supply for one minute and then restarting. If the code persists, either replace the indicated part or contact a service center. F0/F1
  • The F0 and F1 codes refer to electrical issues. If the code appears as only two digits, the problem is a transistor failure, so you must replace the electronic range control (ERC). If the code displays four digits, it will read F0-E0, which indicates a failure switching from analog to digital, or F1-E1, which refers to a safety flip-flop. Both problems require the replacement of the ERC.
  • F2/F3/F4
  • The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
  • Nov 22, 2010 | Microwave Ovens
    What does an error message "F0" mean for kenmore model 911.41185991?
    for a maytag the F0 code means a function key is stuck, and recommends changing out the touch pad, or touch pad and oven control assembly if one unit. google your model number for error codes.
    Jun 21, 2010 | Ovens
    The oven isn't working and it says FO in red letters
    GE / Hotpoint / RCA
    Oven Fault Codes
    Display Condition Remedy
    F0 & F1 Failed Thermistor Control Replace ERC
    F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
    F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
    F4 Shorted wire or Sensor locate short and correct it
    F7-A Function pad button stuck Clean and unstick
    F7-B Bad Clock Replace Clock
    F8 Electrical component failure Replace ERC
    F9 Program with door circuit Check wiring
    Frigidaire / Westinghouse / Tappan / Gibson
    Oven Fault Codes
    F0 & F1 EOC failure Replace EOC
    F2 Oven over heat Defective Sensor or EOC
    F3 Oven Sensor Open Replace Sensor
    F5 EOC failure Replace EOC
    F6 EOC failure Replace EOC
    F7 EOC failure Replace EOC
    Maytag / MAYCOR / Magic Chef / Jennair / Admiral
    Oven Fault Codes
    F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
    F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
    F2 Oven over heat defective Relay Board or (if present) or defective Sensor
    F4 Shorted wire or Sensor locate short and correct it or replace Sensor
    F5 Hardware, safety circuits disagree Replace Clock
    F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
    F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
    F8 A/D Warning Replace Clock
    F9 Door Lock Warning Check door lock circuit or Replace Clock
    Amana / Caloric
    Oven Fault Codes
    Type with display - glass link ERC
    F0 No Safety Signal Replace adapter board
    F1 No Safety Signal Replace ERC
    F2 Oven over heat Replace defective Sensor
    F7 Shorted Touch Panel Replace Glass Panel
    F9 Door Latch Error Check latch
    FF Lock Error Check switch and motor
    ERC III - Relay board with separate board/push buttons
    F0 Shorted Push Pad Replace Push Pad
    F1 Defective ERC Replace ERC
    F3 Oven Sensor Open Check/Replace Sensor
    F5 Defective ERC Replace ERC
    F6 Defective ERC Replace ERC
    F7 Shorted or sticking button Clean button or replace touch pad
    F8 Defective ERC Replace ERC
    The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
    Whirlpool / KitchenAid / Roper
    Oven Fault Codes
    Ovens with 4 digit displays
    F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
    F1-E1 Defective ERC Replace ERC
    F2-E0 Shorted Keypad Replace Keypad
    F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
    F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
    F3-E2 Oven over heat Replace Sensor
    F3-E3 Cleaning Temp over heat Replace Sensor
    F5-E0 Door Error Check Door
    F5-E1 Door Latch Check Latch
    F5-E2 Door Switch Check Switch
    Ovens with 2 Digit Displays
    F0 Defective ERC Replace ERC
    F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
    F7 Shorted or sticking button Clean button or replace ERC
    F9 Door Latch Error Check latch and latch circuit
    Dec 18, 2009 | Ovens
    Controlpanel flashes f 3
    You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
    Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    F7 error code- what does this mean?
    Oven Fault Codes
    May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
    Se error on westinghouse mastermind 711 any ideas?
    SE error is a sensor problem.This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
    Dec 11, 2008 | Washing Machines
    Heating & Cooling Logo
    166 people viewed this question
    Top Heating & Cooling Experts
    paulcarew
    Dan Webster
    Dan Webster
    Donni Steen
