Question about Home
What could it be if no water comes out of shower when its turned to hot water?
  • 374 Answers
SOURCE: Not enough hot water
Some higher end models do have an adjustment that is behind the face plate. You would have to remove the handle and the screws in the faceplate to expose them. If you have adjustments they will be located on the brass valve body facing you. You will need a flashlight and a flathead screwdriver to make the adjustment. If your model is not equipped with adjustments you could have a faulty valve stem. The stem is comprised of a rubber band like gasket that separates port holes into which the waters flow. There could be some piece of trash blocking the port not allowing adequate water from the hot side into the valve.Some valves stems are also able to be installed upside down causing the same issue as the ports do not rotate fully to allow adequate supply. However you say that you have adequate pressure on the hot side but not warm enough. There is another possibility also based on the way the shower supply was plumbed but there is no need to go into this unless this does not resolve your issue. I hope this is of assistance and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Posted on Oct 21, 2008
hessmar
  • 5 Answers
SOURCE: hot water dribbles thru shower head when turned to hot
Replacing the cartridge should solve the problem, the balancing spool is stuck, replacing it will solve the problem. The valve should look like this http://www.moen.ca/shared/pdf/3170pt.pdf . I have unstuck the spools in the past, soaking it in white vinegar will help to remove build up.
Posted on Dec 04, 2008
  • 68 Answers
SOURCE: no water coming out of my Kohler Forte R10275-4-BN shower valve
This is a pressure balancing valve that needs both cold and hot water pressure to operated. It is an anti-scald safety operation.
Good Luck, Phil
Posted on Dec 26, 2008
frcs68
  • 1605 Answers
SOURCE: hot and cold water in shower comes out in a triclkle
shut off the water from the main pipe.
use a allen screw driver take the handle off the shower control.
pull of the wall cover.
pull out the pin that stablized the cartridge in the control body. (remember how it is, before you take it out. or take a digital pic of it). pull out the cartridge. and bring it to any home center or plumbing store.
install in reverse.
Posted on Jan 07, 2009
meBNme
  • 334 Answers
SOURCE: I can't get hot water from the pegasus shower valve
The antiscald device needs to be adjusted. It's behind the escucheon and determines the amount of hot water flow.
Posted on Jan 13, 2009
I installed oakbrook tub and shower faucet 48011 and no hot water is coming out either side just water. What could be wrong?
If you have just water coming out you have not urned on the hot water valve that was turned off during install. check other faucet for hot . If you have hot there its not the hot water tank its the hot side valve.
Sep 30, 2015 | Home
How to adjust hot water on shower
Turn on the hot water first. Wait for it to warm up, then turn on the cold water until the mix is the temperature you want. I recommend doing it before you engage the shower diverter to divert the water to come out the shower head.
Sep 19, 2014 | Home
I have to turn my shower to full temperature to get any heat out of it but when its on full the pressure is just trickle. I used to have it on number 5 but now number 5 just gives freezing cold water - any...
You have a blockage of the hot water coming to your shower head, or a blockage in the supply line coming to the shower head.
Be careful of the hot water in this procedure below.
Remove the head and try to clear the blockage from the head, as you have the shower head removed try to turn on the hot water to make sure you are getting a full stream of hot water to the shower head, if you do have a full stream coming to the shower head then the blockage is in the supply line coming to the shower head.
Please rate me
Dec 10, 2010 | Home
No hot water comes out of shower just cold comes out even when turned to hot, sink 2 feet away has hot water
The problem more tha likely lies within the shower valve body. Possibly the shower head has an accumulation of deposits clogging up the holes but that would not affect the hot water supply only. You might try removing the shower head and turning on the hot water. If you get hot, immerse the head in Limeaway for a hour or two and replace it, or install a new head. If you still do not get hot water, the shower valve needs attention. The cartridge inside the valve body will likely need replacing or at the least cleaning (Limeaway), replacing rubber seals and use plenty of silicone grease before re-assembly.
Oct 26, 2010 | Ldr Industries 520 1300C ADJUSTABLE SHOWER...
Water is not very hot.
First try adjusting the pressure balancing gear located right behind the handle. If you still do not have hot water I suggest to replace the cartridge.
Jan 13, 2010 | Delta & Single Handle Shower Faucet
Shower problem
This must be a joke because there is no way the shower is connected to your faucet. the faucet on you vanity is connected directly to your hot and cold water supply. And only by opening the hot water side of the faucet can you get any hot water.out of the faucet.
Aug 01, 2009 | Home
No cold water, Only hot water in showers.
The plumbers screwed up when they installed your showers. There are two connections on each shower. one for hot and one for cold. they connected the two hot water lines together with a T fitting and then ran a line to the main hot water line and tied it in. Then they connected the two cold water fittings with a T and ran that line to the main hot water line and tied it in there instead of into a cold water line like they were suppose to. This is the only possible logical solution to this problem. They tied your cold water connections to both showers into a hot water line instead of a cold water line.
Jun 01, 2009 | Danze & Single Handle Tub And Shower...
Water not hot on my eletric shower
replace electric heating elements, probably the bottom one
Jan 14, 2009 | Home
Home Logo
166 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
