Question about Bosch Washing Machines
I have a Bosch 300 DLX washing machine. There is power to the machine, but it will not power up. No lights come on or nothing. Is there some kind of reset button?
    Genius:
  • Bosch Master
  • 1,585 Answers
Door inter lock or lid lock
Posted on May 03, 2015
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
Posted on Jan 07, 2010
SOURCE: Electrolux EWF 1087 - Power on, light goes orange, nothing works.
Hold reset and start buttons down, while turning on. Hold down for about 10 seconds.
If you're getting an E90 error code, which means communications error, it means you have a dodgy connection between the main board and the control panel.
Disconnect the power completely, open up the top of the machine and reseat the plugs on both ends on the blue ribbon cable connecting the front panel display to the main board. (The main board is the big white plastic thing with all the wires running into it).
Do the reset steps when turning on again, should be good to go, otherwise it's a bit more serious and you'll need the tech back.
Posted on Jun 30, 2010
emissionwiz
  • 78267 Answers
SOURCE: Where is the reset button
there is no reset button, the reset for the system is to unplug it for at least 3 minutes from the wall socket, if it doesn't reset then there is a electrical failure of the central control circuit board.
Posted on Sep 20, 2010
richroth
  • 9472 Answers
SOURCE: Have a BOSCH 300/500 series washing machine.
The door locking mechanism has malfunctioned and/or is overheating. It is recommended that remove power from the appliance (unplug it) for 30 minutes and try again. If the problem persist, you will need to replace the door lock assembly.
Posted on Nov 26, 2010
Macmarkus
  • 2605 Answers
SOURCE: THE bOSCH 300 SERIES WASHING
Hello, welcome to FixYa.
The E13 error code on most series Bosch including the "Nexxt" series washer`s refer to a drainage problem, as you may or may not already know. ( or in Bosch terms "pump time exceeded" )
Anyway, here`s the most likely way to remedy a E13 code.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs, and a pair of mechanics gloves are recommended due to extremely sharp edges...safety first**
Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water that is typically the reason for a locked door, that sucks...hopefully you won't get too wet. ( maybe you`re lucky enough to be close to a floor drain )
  1. Locate the round door on the front of the machine (about 6" in diameter, lower right corner) macmarkus_26.jpg
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a green ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan )
There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out
5. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.macmarkus_28.jpg
6. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
7. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
Posted on Sep 01, 2011
My Bosch vision 300/500 DLX series washing machine continually dispenses hot water no matter what cycle I have dialed in. What can I do?
if it's hot and cold fill machine , have you got the hoses connected correctly hot to hot supply , cold hose to cold mains supply
if its cold supply only to machine , make sure it's not connected to hot water supply, this could be worth checking.
Oct 28, 2016 | Bosch Washing Machines
Washer won't drain, E:13 code flashing
From user manual:
Indicator light "rinse" is lit and display is flashing "E:13" with no water remaining in the drum.
For some reason drain pump is blocked.
Clean the water drainage pipe and/or drain hose.
Dado
Oct 12, 2015 | Bosch Vision 300 Series DLX WFVC4400UC 27"...
My Bosch Vision 300/500 DLX series washer machine washer stopped in mid cycle, with error code 13. What to do
The code means that the water is taking to long to pump out
unsrew the pump filter at the bottom front right
have some towel ready to soak up the water
clean and replace filter
most times this fixes the fault
if it doesn't then check for a blocked drain hose or faulty pressure switch
Jul 22, 2015 | Bosch Washing Machines
My Bosch Nexxt DLX Dryer is not getting hot
you need to reset the high temp sensor. its in the back next to the vent. you might be able to use a long screw driver and push it in. Mine is just about an inch above vent and on the right side. Use a flashlight to look in and you should be able to see it.
Mar 23, 2013 | Bosch Nexxt DLX WFMC4301UC
Front load washer Bosch Vision 300/500/DLX will not drain getting a code of E27 can you help. Can't find the code # in the booklet that came with it.
A code E27 means a problem with the door lock. Try unpluging the machine for an hour and see if it resets the lock.
If not remove the cover on the lower right corner you will see a white plastic pull cord. Pull the cord and pull open the door. If that doesn't reset the door lock you will need to replace the lock.
Nov 22, 2012 | Bosch WFK 2401
Bosch vision 300/500 dlx series washing machine: how do you remove the front kick plate to access the pump?
Bosch vision 300/500 dlx series This video will show you how to change the pump washing machine Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 08, 2012 | Bosch Washing Machines
Replacement part
Bosch Nexxt DLX WFMC4301UC door seal replacement
parts
This video will show you how to change a door seal on this Bosch front loader washing machine and the best
places to buy parts.
we have all
bosch repairs in our channel
Feb 11, 2010 | Bosch Nexxt DLX WFMC4301UC
Open Questions:
Bosch Logixx 8 washing machine Powers OFF itself when filling water in the softening stage I have a 7 years old Bosch WAS32742AU/08 washer, it will wash, rinse then will power itself OFF with nothing on the display when it reaches the softening cycle where it begins to fill water, there is about 10mins left in the cycle. I can turn the dial OFF then back to the same program to resume the cycle, it will start filling with water again in the softening stage and power off again. I've checked the water level pressure switch hose and cleaned the chamber, I dont't think there is a problem with that because it works during the cycle until the softening stage. I can run and complete the Drain only cycle, Rinse only cycle, Spin only cycle and 15min Quick cycle without interruptions. It's only programs that has the Softening part of the cycle it powers off when filling water in the middle dispenser compartment during the softening stage where Valve 1 and Value 2 are open. I don't even use softener and the compartment is clean. The current work around is when it Powers OFF during softening, I turn the dial to OFF then select the rinse only cycle to complete the washing. I got into the Valve test mode and found that Value 1 and Valve 2 tests are OK individually but when it V1 and V2 are both ON to fill the middle softener dispenser compartment it wont stop filling and eventually the machine powers off. I posted a video of the test here: https:/ / streamable dot com/n1gw6 https:/ /player dot vimeo dot com/video/264199360 Do you know what the problem could be?
Apr 11, 2018 | Bosch Washing Machines
Washing Machines Logo
83 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
