Question about Kenmore Refrigerators
I have a kenmore elite 795.77549600 and it's not cooling like it used to the compressor is very hot to the touch and one of the lines is frosted over what could it be? Cleaned fan and coils too help!!
    Prodigy:
    An expert who has answered 500 questions.
  • Kenmore Expert
  • 650 Answers
This can happen if the freezer fan is not running or you have excessive ice build up from the unit not defrosting. Check to see if the freezer fan runs by pushing the light switch in the freezer and look for frost build up on the freezer back panel.
Posted on Apr 25, 2015
kevin000
  • 1847 Answers
SOURCE: KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
it should not be the compressor as the bottom is only not cooling.
Posted on Jun 23, 2008
Techsim
  • 59 Answers
SOURCE: Amana SxS fridge not cooling or freezing
You have a sealed system problem. There is either a small leak or a restriction somewhere in the tubing. This isn't something you could've caused so don't worry about that. Unfortunately this isn't something you can fix yourself either. You require a certified refrigeration technician to fix this problem.
Posted on Nov 03, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Freezer works Refrigerator will not cool down
The compressor should be OK this time because you caught it in time. But if the condenser fan stops you need to consider replacing the fan. I have had refrigerators do fine until the fan motor warms up and you are away, it stops. Don't think you should use the refrigerator until the fan is fixed. Sea Breeze
Posted on Apr 22, 2009
zr800o1le
  • 19 Answers
SOURCE: Cleaned coils,lower fan, drain lines. Checked door seals, temperature reset, both fans are runnign but
Need a New Compressor. That is the only way of Cooling. If it was working and not cooling it could be the Condensor or low on Freon.
Posted on May 12, 2009
kdrake84
  • 262 Answers
SOURCE: refrigerator not cooling. fans working. compressor
I will need you full model number please.
Watch the video for the information on how to locate it. Reply back to me with the number and we can get you back up and running.
Click on the link http://www.youtube.com/watch?v=oJI_8_Tjplw
Posted on Feb 12, 2011
What is wrong with the Kenmore Elite refrigerators they have now? I bought one and it is very noisey. I hear the compressor running from rooms away and it's not a rattling just the noise of it running
If you are wanting to check and see if the compressor is operating and actually working, find the small refrigerant line coming off the compressor and follow it several inches and check its temperature. The normal temperature is over a 100 degrees and should feel very hot. Be careful the normal range is over 140 degrees on most model and may cause burns. If it is hot to the touch, that means the compressor is working. If it is not hot it means you have some problems with the compressor and probably need a new one.
If it is hot, the most common problem with a real hot compressor is a dirty condenser. If your models compressor hot line dissapears into the casing (walls of the refrigerator) then you cannot clean the condensor, but if it goes into a finned condensor with a fan, you need to check if it is dirty and just needs cleaning. This is a very common problem and periodic cleaning needs to be performed. Your refrigerator loses heat removed from the interior by rejecting the heat to the air passing over the condensor. If it can not breath due to dirt buildup, the refrigerator will over heat and lead to prematur breakdown. If the systems has operated long enough at a high temperature, the refrigeration oil in the refrigerant system can decompose and form sludge and block the capillary tubing. Once sludge start forming it is very difficult to flush the sludge out and a compressor change out typically can not fix the system because remaining sludge. In this case it is cheaper to buy a new refrigerator and remember to clean the condenser every year at least, more ofter if you have cats and dogs. They have a tendency to shed and the hair gets into the condenser. I had a customer once that used the air flow to the condenser as a vacuum cleaner because the dirt dissapeared near the air suction, until the condensor clogged up and the refrigerator stopped cooling, go figure.
Hope this helps
Aug 01, 2014 | Kenmore Refrigerators
Installed new compressor
Hi
Your suction line has to have no frost at all.it should be cool/warmer. You fridge is overcharged with refrigerant.
Feb 09, 2014 | Kenmore Freezers
Have a 2000 kenmore elite side by side compressor is working but neither side is cooling
If compressor is working then you have a leak in the sealed system/ you need special equitment to find a leak best to leave that to the pro's//one question is there major frost buildup in the freezer at the back of unit?
Feb 07, 2011 | Kenmore 53642 / 53644 Side by Side...
Refrigerator running but not cooling
Check list:
fan motors all functioning
Cooling coils free and clean
Compressor cool to the touch
(compressor blazing hot bad relay)
Backside of freezer section frosting up
(bad defrost heater,thermostat,or timer)
Small line from compress is HOT
(cool high pressure line means low charge)
Suction line frosting up (overcharged)
Generic ice box Training manual
May 17, 2010 | Kenmore Refrigerators
Ice/frost buildup & loud noise
this is classic compressor failure. the core is freezing due to unregulated pressure in the lines. repairing the compressor will correct this issue.
Mar 11, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Feb 23, 2009 | Kenmore Refrigerators
Refigerator not working properly
the compressor is out of coolant/freon.u should not run it if the compressor is too hot to touch
Aug 02, 2008 | Kenmore Elite 21086
Compressor is extremely hot
Compressor will be hot to the touch. You stated the fan was replaced and then said the fan is not cooling. If you replaced the fan and it is now operating, reinstall the panel you removed to install the fan motor. That panel determines proper air circulation to cool the system.
Jun 14, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator/Freezer not cooling
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, by compressor Make sure compressor is running and not shutting off on overload.. u said comp. hot.. should be warm... Not hot check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
64 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
