Question about Utilitech 0.33-HP Thermoplastic Submersible Utility Pump PPSU25
Only one yearold;turn on,or plug in kicks breaker
Cord in good shapelook in side where senser is;theres white wire with meyal eye not atched
    Problem Solver:
  • 11 Answers
Roger, DO NOT USE. Return to place of purchase, or cut cord and discard.
Posted on Apr 27, 2015
I have a 5 hp compressor. It will turn on and run maybe 5 seconds and then kicks my breaker out.
you could have a weak breaker or the breaker is not rated for the draw of the compressor have a pro check it out
Mar 02, 2015 | Campbell Hausfeld WL6502 5-Hp 20-gallon...
Dryer doesnt heat L1 to N is 120/ L2 to N is 3?/ L1 to L2 is 30???
Electric dryers are 240 volt. You must have a 30 amp 240v receptacle to plug it into. The cord on the dryer must have a compatible plug.
The circuit should not be shared with anything else, and should be protected with a 2-pole 30 amp circuit breaker.
It is possible for only one side of a 2-pole breaker to pop. When that happens one of the "hot" terminals would be dead and would account for the weird voltage readings you're getting which are just stray voltages from the one good side bleeding back. So Check your breaker first. You should get 120v on each terminal of the breaker and 240v between them. The cable leading from it should be 3-wire (red, black, white). It may, or may not, also have a seperate (bare) ground wire.
Then check voltages at the receptacle. You should get 120v between each hot side and the neutral, and 240v between the two hot terminals. If not, then check the wiring connections at the breaker and at the receptacle. Switch off the main breaker (or pull the disconnect) before doing that.
If voltages OK at the receptacle, but not at the control board then replace the power cord.
The ground wire should be fastened to a cold water pipe with a clamp designed for that purpose unless your power cord and receptacle have a separate (4th) terminal for the ground.
Apr 15, 2014 | Whirlpool Dryers
Kicks out breaker
Have you replaced the unit...I bet the cord inside the socket is shorted...If you are capable ....unplug the light unit and disassemble the plastic or ceramic or metal socket. Unscrew the wires from the terminals and remember which terminal goes to which wire ...the power / hot side is usually indicated by a GOLD / Brass terminal. The common side is silver. Cheaper sockets make no distinction. So mark 1 side with a marker...simple. Another good thing to know is the receptacle that you plug it into...the larger grounded side is the "common" side of the receptacle. and the Hot / POWER side is the smaller prong.
Apr 02, 2014 | Flukers 5.5" Repta Clamp Lamp with
Wall light switch timer inline with Extension cord GE 15313
Black to black (hot), Green to green (ground) and the only one left is of course white to blue. The (neutral) white wire can be many different flavors (blue, red, orange, brown, etc.).
If the outlet your plugging into (or controlled by the service panel breaker) is 15 Amps use a minimum of 14 gage wire (or 12 gage is even better), if its a 20 Amp outlet use 12 gage wires (or 10 gage). Don't use a 16 or 18 gage wire because it may get hot and start a fire because its undersize for the Amps.
Nov 13, 2012 | Hardware & Accessories
I have the same problem listed above. I bought a touch and glow photocell at Lowes to go along with a yard lamp with lights on three arms. It is wired exactly as directed. Black to black, power source...
You have 120volt photocell.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#photo-eye
Wiring sounds correct.
Lights are on all the time, even in daylight.
How is the power by-passing the photocell shut-off?
Disconnect ground wire to make sure there is not a ground fault causing circuit to complete on ground wire.
Otherwise the photocell might be bad.
Aug 22, 2011 | Electrical Supplies
Lutron Grafik Eye Wall Stations Stopped Responding
You can try to reset the grafik eye by turning off the circuit breaker to it for about 15 seconds and then turning it back on. Sometimes, they will get a surge and it freaks out the computer inside it a little bit. If that doesn't solve it, you may have a loose connection on the back of the grafik eye unit or one of the bedside keypads. There should be a 4 conductor wire (black, red, white, green) from the master unit to the bedside unit and then from bedside unit to bedside unit. The black wire is the common (ground), the red wire is the positive, and white and green are transmit and receive. It sounds like your transmit and receive loops are not complete (white and green). This would allow the led's on the front of the keypad to light up but not communicate to the grafik eye. Be sure to turn off the circuit breaker to the grafik eye before removing either the keypads and the grafik eye from the wall.
Good Luck
Dec 20, 2009 | Lutron GRX-PCBL-346S-500 Grafik Eye...
I have a four wire on a 20 Amp service. I need 110 outlet.
4 wire recepticals are used for 220 Volt appliances, there should be 2 hot (117V to ground) and one each Grounding and grounded (read neutral) conductors) Breaker or disconnect should be 2 pole for 220 Volt circuit. A 20 Amp 110/117 Volt circuit would have a single pole breaker or disconnect, one "hot" conductor(should be black or colored , not green or white), one neutral conductor (should be white or neutral with white stripe) and an equipment grounding conductor (should be green or bare copper). It sounds to me like your receptical was wired for 220 V using whatever colored wires were handy. Back up to breaker or fuse (disconnect), and shut off circuit. New 117 Volt outlet will be wired with Black to Brass colored screw (short slot on face), One White wire will be used for Neutral conductor (make sure you know which one it is at the breaker panel) and one of the other white wires may (but shouldent be) used for ground (use green marker to identify it at each end),The third white wire should be removed if you can, otherwise cap with wire nut at each end and coil up in back of boxes. At the breaker/ fuse panel, the Black wire is connected to the breaker (It will be your "hot" lead), The white being used for the Neutral is connected to the neutral buss bar with the other Neutrals, and the green goes to the grounding buss bar (should have other green or bare copper wires. Once all is properly connected and secured but without the disposal plugged in, turn on the power and check for leaking smoke (smoke here is a bad thing) The fuse or breaker should protect your wires and help keep that smoke inside the boxes. Check voltages at the new plug, 117 V accross Short and longer slot, 117 from short to ground (round) and 0 or close to it from long (Neutral) to ground. If voltages check, plug in the new appliance and test.
If in doubt about what you have, dont hesitate to contact an electrician, they get paid for their knowledge and experiance and their ability to keep that nasty smoke inside the boxes.
Good Luck.,
Aug 14, 2009 | Jenn-Air JED8230 Electric Cooktop
HAVE A 8 YEAR DRYER( Kitchen Aid)
I would be checking the service panel. I'm assuming the dryer has been working in that outlet. If the breaker is over 50 amps that is why it didn't trip. But the breaker may be bad itself. Make sure it is wired properly. Red wire should go on one side of the breaker and the black on the other. The white should go over to the neutral bar. Then make sure the outlet you plug into is wired the same way. (MAKE CERTAIN THAT BREAKER IS OFF) The top two prongs should have a red on one side and a black on the other, with the white at the bottom. If these are correctly wired, the problem is either in the breaker or inside the dryer. Depending upon the model you have, a 50 amp double breaker isn't prohibitively priced. If you buy the breaker, wire it the same, turn it on, plug in the dryer and it happens again, the dryer is at fault. Coils burn out inside them, lugs burn through, but I'd feel more comfortable at that point calling a service man, tell him what you've done with wiring, breaker, and outlets. It may be time for a new dryer.
Sirwriter
May 16, 2009 | Whirlpool LER5636P Electric Dryer
Black and Decker MM525 hard wiring diagram
the connection the are not right. top left side is for white wire.buttom left side is for red wire. top right side is connected to black wire from motor. buttom right side is for is going to the
extension terminal. good luck
Jun 02, 2008 | Black & Decker 19" Electric Lawnhog...
When I turn on dishwasher it kicks breaker at wall outlet.
if it is tripping the breaker you have a dead short to ground check the water inlet valve on the left side front unplug the 2 wire connector to it and plug it in see if it stays on if you you found your short if not let me know.. but i will need the model # off the unit to get the wiring diagram
Jan 21, 2008 | Kenmore 17439 Built-in Dishwasher
Utilitech 0.33-HP Thermoplastic Submersible Utility Pump PPSU25 Logo
207 people viewed this question
Top Utilitech Plumbing Experts
Paul Carew
jhnolson
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
