Um, it could be no power to your machine, I would suspect it is the power cord, plug or possibly an internal electrical issue. If the foot control failed, the machine's light should still work.
Not sure. It could be something to do with the foot control, power cord, or the motor. Does the light come on? If so, it's probably not the power cord. If you have access to another foot control and power cord, that is an easy way to test. Otherwise, might be best to take it to a Bernina technician.
www.singerco.com/uploads/download/445_4830_4832.pdf around the sewing machine needle. ... ings of the machine and foot controller ... The spool does not turn. 7. ... Note: Do not operate machine without fabric.
Turn the machine on, press the foot control down and turn the handwheel backwards. If it sputters, the motor carbon brushes are worn to the springs and need replacing.
Next, while pressing on the foot control, try wiggling the wires around where it enters to machine and where it enters the foot control. There may be a short in the cord. If the short is at the machine, you need a new cord. If it is at the foot control, the cord can be pulled into the foot control, the shorted part cut off and the connection reattached.
If it still doesn't work, try removing the cord from the machine and placing an alligator clip test lead to two of the inlet prongs on plugging it into power. Which two prongs you ask? Try several combinations, (one will light up the lamp) CAREFUL: THE MACHINE MAY SUDDENLY TAKE OFF AT FULL SPEED, SO REMOVE THE BOBBIN, THE THREAD AND NEEDLE FIRST. if it runs, it is your foot control. If it doesn't run, it's likely the motor brushes or motor.
You only need to replace the cord if it has been damaged. It will cost less if you just take the machine , cord and control to a local technician and have him just replace the foot control. Let him test it first. A generic foot control should cost less than $30. sewman7
