Question about Ford 555 backhoe
All my hydraulic stick very hard to break free
Once i get hydraulic broke loose they will work fairly well let set over nite they stick again what could cause this
How do I turn off the nightlight on the bottom of my microwave?
TheAuto Nite Light feature can be set to turn on and off at any time desired.Follow the directions below for set-up:
  1. Press the AUTO NITE LIGHT pad.
  2. Enter the time the light is to turn on. ...
  3. Press the AUTO NITE LIGHT pad again and enter the time the light is to turn off. ...
  4. Press the AUTO NITE LIGHT pad once again.
Sep 16, 2017 | Microwave Ovens
No hydraulics working yet everything was fine the night before
My thought also. Does the engine run but hydraulics not work? If engine has a starter, check the battery and battery connections.
Need more information in detail.
Nov 27, 2014 | Garden
Is there a place to check the hydraulic fluid on a 2005 toro Z420
sounds like your hydraulic motor maybe acting up. you need to check your hydraulic oil flow rate. if you don't have the tools you would have to take it in it is a fairly big job
Oct 07, 2014 | Toro Power Lawn Mower
Error e2 comes up and wont drain the washing machine
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging
May 04, 2011 | Washing Machines
The transmission will not engage. the fluid and filter have been replaced, and the system was flushed. it worked for a couple of days, then it started again.
It sounds like your valve body may be sticking. If it is, this is usually caused by debris getting into the valve body and causing the pistons to stick in their bores. This can cause an internal hydraulic leak and the symptoms you are describing. Unfortunately, this usually results in a transmission overhaul because the debris that makes the valve body stick usually originates from clutches and other parts that are damaged or badly worn.
Apr 15, 2011 | 2001 Oldsmobile Aurora
Problems with gears
if the truck won't go into gear go to a transmission shop or a dealership if possible, and ask them to check the "shift linkage". it may be loose or even broken
Mar 18, 2010 | 2002 Land Rover Freelander
THE TIMING BELT HYDRAULIC TENSIONER IS LEAKING DOWN INTERMITTANTY CAUSING TOP HALF OF BELT LOOP TO BE LOOSE. THIS IS THE THIRD NEW OEM PART WEVE TRIED, NORMAL? OR PART ISSUES.
is the belt a fairly new one? if streched it can have the tensioner over extending causing it to leak or check oil preasure if to high will cause seals to leak, if all that is ok, then you may have a part problem
Oct 07, 2009 | 2003 Audi S8
I can't change gears and my clutch pedal is too loose,pedal goes to floor???
Hi there i have had quite a few of these, just check the clutch master cylinder fluid you might find it is very dirty and may be causing the hydraulics to stick. Either the master cylinder or the slave cylinder may be sticking.
Jul 25, 2008 | 1994 Hyundai Excel
Loose stitching underneath. HOW CAN I FIX!!!!
Sounds as though you may have a burr or rough spot on the hook where the bobbin inserts. Run your finger along the edge of the hook to see if there are any rough spots.I'm sure you're going to find at least one from the time you broke the needle.Once you locate it, remove it with an emery stick or small sharpening stone. Polish it so that it is smooth. Should work okay.
sewman7
Jun 27, 2008 | Juki TL-98Q
Garden Logo
Top Ford Garden Experts
Dennis Key
Dennis Key
fordexpert
donald boissonneault
Are you a Ford Garden Expert? Answer questions, earn points and help others
