Question about Vehicle Parts & Accessories
Signal lights will blink but I have to hold the button to keep them on
  • rgholdings1 Apr 26, 2015
    You have to remove steering wheel and adjust or replace the switch.lots of time adjusting and some electeic gease cures the issue.
    Sergeant:
  • 220 Answers
The switch is damaged and needs to be replaced.
Posted on May 04, 2015
    Problem Solver:
  • 18 Answers
Hi,that shows the button is not making connection ,check wires to button and to make sure,,get a brown live to switch and to battery, and negative blue too and negative and live to switch and earth to body of car,,basically its a black wire to switch,along with red wire to switch or blue.then attach to battery of car... but put an earth wire to body of car , or change switch could be loose connection in side ....hp that helps,-)
Posted on Apr 27, 2015
Blinking lights???
With the unit plugged in and on, push the reset button for 30 seconds, and while holding the reset button down, pull the power supply plug out of the unit and keep the reset button down another 30 seconds, and THEN (still holding the reset button down) plug the power supply plug back into it and keep the button down for another 30 seconds.
That's a "30/30/30 Reset", and it should boot up fully reset.
Jul 20, 2014 | Linksys E2000UK) Wireless Router
Tv cable and dvd lights keep flashing and tv doesn't get signal
The remote is in safe mode, remove batteries and reinsert batteries while keeping the button 2 pressed.
Aug 04, 2012 | Logitech Harmony 200 Universal Remote -...
Logitech m205 won't work, the light keeps blinking
If your unit is a wireless keyboard only, then there is a button on the bottom of the keyboard and another on the receiver that is plugged into the usb port of the computer. In order to calibrate the system when it looses its signal, you have to press and hold both buttons down at the same time for 30 to 45 seconds. That means press the button the receiver and the button on the bottom of the keyboard at the same time and hold them down for 30 to 45 seconds. This will revive the signal and bring it back to working condition.
If your unit is a wireless mouse and wireless keyboard then there are probably 3 buttons involved that need to be pressed and held for 30 to 45 seconds at the same time. One button on the mouse, one on the keyboard and the last on the receiver.
If you press and hold the buttons down as explained above, it will correct the problem.
Jul 17, 2011 | Logitech Computers & Internet
Keeps blinking. I've shut it off, and cancelled all print jobs - even unplugged it. Keeps blinking. Says there is an operator error
Try this:
1. Turn off printer (use button, don't unplug)
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
If this not help may the print head is defective.
Oct 07, 2009 | Canon BubbleJet i560 InkJet Printer
My printer is blinking orange lite
Hi there ok try
1. Turn off printer
8. Your printer should respond as normal
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 18, 2009 | Canon S400 InkJet Printer
Blinking maintence light 02 accord
turn the key off, then hold the odometer reset button in, turn key on and keep holding, the light will flash off then on once, keep holding until light stays out, start car and all should be ok
Nov 16, 2008 | 2002 Honda Accord
Lights on the Asko D1996 keep blinking
This depends on the blinking pattern. Of the eight lights on the panel, if the four on the left blink on and then the right four lights blink on as the left ones go off, and keep blinking back and forth, that just means the mode has been set and the Start button pressed. After closing the door it should just continue on wherever it is in the cycle. (This is normal operation).
If you hold down the Start button, this resets the dishwasher. If you then close the door, nothing will happen because it thinks it's done.
If the lights are blinking in a different pattern, such as they all blink on and off in unison, that indicates an error condition and needs to be diagnosed. If the pump is not running constantly, then at least it's not because water is leaking out somewhere.
Sep 23, 2008 | Asko D1996SS Built-in Dishwasher
Turn signals, Hazard lights
I would replace the bar switch assembly.
May 18, 2017 | 1998 Jeep Wrangler
The washer mode light keeps blinking
the machine is locked out on the control, go to the signal button on the far right side and hold the button in for four seconds and it will unlock the control and yu can select the cycle that you want
Apr 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Vehicle Parts & Accessories Logo
78 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
