Question about Sewing Machines
I can't get the decorative stitches to work. - Sewing Machines
  • Sewing Machines Master
  • 1,860 Answers
If you have the settings correct for the decorative stitches, the there could be something wrong with the gears or cams that make sure decorative stitches and the machine would need to be checked
Posted on Jun 03, 2015
SOURCE: kenmore 19365 decorative stitch will not stitch
You have to key in the number for the stitch on the stitch panel
Posted on Aug 23, 2008
kent581
  • 87 Answers
SOURCE: Husqvarna Prisma 980 decorative stitch cassettes don't work
On that machine, the cassettes aren't actually computer chips. Each cassette has a little spot of white on a certain little area you must find (top right I'm pretty sure). Look in the machine at that point. There is a sensor that looks for that white spot, and as it identifies it, it changes stitches according to that cassette. Either the sensor is blocked, gone bad, or you can put a fresh coat of white paint on with white out. I hope this helps.
Kent
Posted on Mar 23, 2009
Tally Girl
  • 1128 Answers
SOURCE: The 6 built-in stitches (such
I have the same model, have you turned the first knob on left, the stitch selector, to the stitch you want? Then turn the middle knob, the stitch width to "4". Use the colour guide marks shown in the little picture on left of the knobs so you are dialing up the right settings. So for the zig zag, elastic blind hem, scallop, overcasting and multi-stretch stiches, 1-6 on the diagram you'll be setting the left knob to 1, 2, 3, 4, 5 and 6 respectively and the stitch width and length knobs to "green", you can vary the length and width to suit what you want.
Then for the cams, you need to set everything zero, turn stitch selector to 7, the cam setting. then turn the width to orange again (3-4) and the stitch lenth selector to the orange setting, right around the knob. This engages the "Elnagraph" the device under the flap on top of the machine to read the discs. Basically the green stitches the needle is swinging from side to side while the feed dogs move the fabric forward, making your zig zags, blind hems etc.
But when you engage the Elna graph, the machine matches stiches by moving the fabric "forward and backwards at certain times, while the needle does its thing from side to side. This is what makes elastic or stretchy type stitches because you are putting "stretch" into the seam by sewing forwards and backwards.
Please note: always turn your stitch width and length back to Zero BEFORE you make any changes to the left knob and select a new stitch as this saves on wear and tear to the moving parts in these wonderful machines.
I do hope this assists you and I haven't just told you stuff you already knew!
Posted on Mar 02, 2011
Tally Girl
  • 1128 Answers
SOURCE: I can't get the decorative
Will it stitch any of the swing needle stitches like a regular zig zag too? Try the zig zag and blind hem zig zag and see if it is stitching them out okay.
If not, sometimes the needle swing mechanisim gets gummed up from lack of use/dirt/lint/grotty oil and may just need a good clean inside.
Other possibility is the spring on the needle bar has broken. To test this, set machine stitch width to zero, and with your hand move the needle bar as far right as you can, then release it. It should move back to central position itself if the spring is okay. If not, good chance that's the problem.
If you feel mechanically inclined you could try to take off the cover to your machine and see what the gears around the needle bar look like and try cleaning/lubing them. You could try cleaning up anything that looks really gunky with q-tips and denatured alcohol and see if you can free up the movement of the gears inside. Triflow is a great lubricant to use along with a bit of warmth from a hair driver may also help to shift the gunk (keep off plastic though).
Other option is to take your lovely Bernina for a service; they are great machines so well worth it. All machines benefit from a professional clean/lube/adjustment at least every two years and your 830 may be just a simple fix.
Posted on Sep 21, 2011
  • 166 Answers
SOURCE: Why does my machine now only stitches backward, and no decorative stitches
You dont state what model of machine this is, however I have come across this problem mainly on Elna computerized machines and it has been exclusively due to failure of the driver chips on the processor board that control the stitch length stepper motor. You can confirm this by checking whether you can vary the stitch length as well as just the forward/reverse. Same applies to Bernina models, but I dont know about others. Either way, you need to have it checked by your tech.
Posted on Aug 28, 2012
I have a Singer S18, stitches perfect. Attempted to use Zig Zag stich and decorative stitches, These are not working, It will make a few stitches then keeps stitching in place. Any Suggestions? Thanks
You probably need to widen the stitch width before it will let you sew. Or change the pressed foot to accommodate the movement of the needle when making decorative stitches.
Nov 20, 2016 | Singer Sewing Machines
I am having troubles with the decorative stitches bought used
Difficult to diagnose. Try a brand new needle that is compatible with the thread and fabric.
All About Needles
If the machine is mechanical, it may need cleaning and oiling if the decorative stitch mechanism is sticking.
Feb 23, 2016 | Sewing Machines
My decorative stitches are not sewing. The machine sews straight okay but the thread does not catch with the decorative stitches.
there could be a problem with the gear for the decorative stitches, the machine may need to be checked to see if there is a gear or gears damaged or broken
Apr 06, 2015 | Elna Quilter's Dream 6003Q
How to fix decorative stitches for sewing machine.
Make & Model??? Sounds like the stitch selector mechanism is stuck. If it's a mechanical machine, you can try oiling the mechanics of the stitch selector with Tri-Flow Synthetic Oil and then heat with hand-held hair dryer.
Mar 23, 2015 | Sewing Machines
I have a Janome Newhome 672. Cleaned and oiled it, works great. But, the decorative stitches will not form correctly. The reverse is not engaging. How can I fix this. Also, the button hole knob h
In most cases Laurie, with decorative stitches selected some machines can't sew in reverse. Your stitch length is too long or too short to make the decorative stitches sew correctly. So many things could be wrong. I'd need more info to get you going again.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Oct 22, 2014 | Janome Sewing Machines
Singer curvy
there could be something wrong with the cam that does the decorative stitches, you may want to have the machine checked..
May 27, 2013 | Sewing Machines
All my decorative stitches are comming out straight
it sounds like something has happened to the cam gears that
do the decorative stitches, which means the sewing machine needs
to be checked..
but before you have the machine checked,, make sure all the
dial that are used for decorative stitches are at the right setting
one missed setting can cause a lot of problems
Nov 02, 2012 | Singer Sewing Machines
Kent
Mar 23, 2009 | Husqvarna Viking 1
Kenmore 19365 decorative stitch will not stitch
Jan 22, 2008 | Kenmore 19365 Computerized Sewing Machine
Sewing Machines Logo
60 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
