Question about Kenmore Sewing Machines
My kenmore 385.15516000 sewing machine push-clutch will not engage. It has popped out before but I was always able to push back in. Help!
4 Suggested Answers
SOURCE: Kenmore sewing machine manual for model # 148 12080. (older)
i have a older kenmore sewing machine model #148.19370
Posted on Sep 17, 2008
Michaelle
  • 65 Answers
SOURCE: need help to thread our sewing machine.
you really must get a manual for this machine.
You can find manuals online for a small price.
At one time some sites had them for free, but I haven't been able to find many recently. sewusa.com has some older ones for free. but not many. you could try the kenmore site as well, if not I'd try to search on dogpile.com (sewing machine manuals)
Just so you know, your manual is the MOST important tool for any sewing machine, and its worth a couple of bucks to get it.
Posted on Jan 24, 2009
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
Kenmore 158-12112 sewing machine, the clutch is not engaging, sometimes it does and sometimes it stops engaging
Have you tried a thorough oiling with good quality sewing machine oil--every place where metal rubs on metal? NO belts, plastic, or other than metal parts. Old oil tends to stick parts together preventing them from moving.
Jun 03, 2016 | Kenmore Sewing Machines
Kenmore sewing machine Model 1602: I was filling a bobbin and when I went back to sewing - the needle won't go up and down. Motor runs when I press on the footpad. It is as if the clutch is stuck as well...
Sound like you need to take it out of bobbin winder mode. Suggest looking for a way to engage the clutch. Turn the center knob on hand wheel and or move the bobbin winding post back to postion.
The center hand wheel should move about 1/3 turn towards you to look it back into place.
Feb 09, 2011 | Kenmore 15516 Mechanical Sewing Machine
The clutch is not engaging (it seems).. The wheel doesn't turn which in turn means it is not stitching. Haven''t used it in 6 months, but it was fine the last time I used it.
This may seem like a stupid answer but did you push in the knob. If you were winding bobbins last time you used it you may have forgotten to re-engage the clutch.
Jan 12, 2011 | Kenmore 11101 Mechanical Sewing Machine
I have a kenmore sewing machine model #385.1249180. I cannot disengage the clutch knob from the hand wheel when I spin my bobbins, therefore the needle moves up and down as the bobbins spins thread. Do You...
Usually when you pull the clutch knob out it disengages the sewing machine needle shaft. At least, that is how my 2 Kenmore's work. You can always take your machine into Sears sewing department and ask the sewing machine salespeople for help, they are really helpful in my area and more than happy to help you for free. Good luck
Dec 23, 2010 | Sewing Machines
On my Kenmore 15250 sewing machine to wind the bobbin I need to release the clutch by turning clutch knob towards me, so says the instructions booklet. But the clutch knob does not move apart from the...
On my Kenmore I had to pull the knob out to release the clutch, then push it bak in. I don't know if that is the same for you. You can try it, if it doesn;t move, it was worth a try. You could just take to Sears, sewing machine department and ask the salesperson what to do, they should help you for free, our Sears is pretty good about such matters.
Sep 13, 2010 | Kenmore 15208 Mechanical Sewing Machine
Can't tighten clutch on Kenmore zig zag sewing machine.
sewman7
Feb 14, 2009 | Kenmore 15516 Mechanical Sewing Machine
Old kenmore sewing machine model # 1237 ( not found in search) - prob. purch.'d in 198o's
Check the handwheel. If it is pulled out, the clutch is not engaged. Try pushing it in! (It would be really nice if the solution is this easy!)
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
Bobbin won't wind
I also have the 15358. You probably forgot to "lock" the bobbin winder. After you put the bobbin case on it's peg, push the peg to the right until you hear a click. Then after you disengage the clutch, the bobbin will wind.
Sep 01, 2008 | Sewing Machines
Kenmore model 158-12392
It is a clutch issue.
If you can turn the handwheel manually and the motor belt is running OK but the needle will not move, you will need to check the clutch mechanism for the bobbin winder.
There are three ways for the clutch to engage, and as I do not know your machine, I offer all three for you to see which applies to yours.
Flick winder to the left to engage needle arm motion.......it may activate automatically when the winder is set to wind a new bobbin and de-activate the needle arm
or
there may be a small wheel inside the larger handwheel....tighten the inner wheel to engage needle arm...
or
the handwheel may have a push/pull action ....push in to activate the clutch, pull out for bobbin winding.
If there is any more you need to ask or update your info to refine the question, just post back here, or drop a line through the "Contact Us" page at www.bargainbox.com.au
Mar 10, 2008 | Sewing Machines
Kenmore Sewing Machine model # c877.15
I have a Kenmore as well ,I hope that this will work for you ,too bad that I don't live close to you otherwise I would give a hand. This is the way I fill the bobbin on mine. Mine is located on the top right ,I put the thread into the bobbin hole leaving a small piece of thread hanging for me to hold when I begin the winding, I pull the wheele out to stop the needle from moving while winding, when I am done just push it back in .I run the thread from the spool into the top left it looks like a U turn with a screw go around that without winding just pull it into the bobbin hole. press the foot control and it will begin winding .
Jul 17, 2007 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
47 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
