Question about Canon Office Equipment & Supplies
What causes paperjam in canon ir1133? because whenever i start to photo copy before the paper gets out the paperjams, what cause that? i tried five times it does so!
SOURCE: Flashes paperjame sign but there is no paper jame!
the problem is same sensor no work in the good way or ther is problem in the fusing unit or ther is problem in the feed unit
Posted on Jul 25, 2006
SOURCE: PaperJam
I found that the little plastic hinge guide that supports/aligns the scanning area with the printer (stage 4 on the internal paper jam problem) was misaligned. I just removed it and the printer now works OK
Posted on Nov 17, 2008
  • 165 Answers
SOURCE: pagepro 1350 will not feed paper
I have the same printer and had the same problem.
Cleaned takeup roller wit isopropyl and it has worked now for 18 months. If you dont use it often, remove top sheet from stack and blow the dust off it before printing.
Posted on Jan 27, 2009
SOURCE: x215 continously displays paperjam 1, there is no paper jam,
I didn't have this exact problem, mine was a paper jam 0 error. The problem was caused by a spring that got old ended using one out of a retractable ink pen. Once you take the four screws out that hold the back plate on and remove it. When facing the front of the printer the left side where the handle is will push back and top can be pulled down to remove. Be careful this is where the speaker is located. The speaker is connected by a six inch wire that can be easily unplugged. Facing the side of printer that was just removed is a plate with 5 or 6 numbered screws only remove the ones that are numbered. This is the drive system for the paper tray and out feed. My problem was the cam gear located to the right of the plate that was just removed. It is like two gears made as one with a spring in the middle and two coils used as a brake for the in feed. I did notice on the left side of the drive system was a light that is used for paper detection pointing towards a photo eye. Most likely that light has burned out for you. There is a side diagram located at http://support.lexmark.com:80/perl/support/support.cgi?relevance=&ccs=229:1:0:393:0:0&mode=DOCS&doctype=topdoc&term=&docid=ENUS20058
Posted on Apr 02, 2009
  • 125 Answers
SOURCE: ImageClass MF6530 paper jams all the time
clean rollers with an eraser.seriously.
Posted on Aug 25, 2009
Hi there...we have an error saying paperjam - code=007. I have checked for paperjams and there doesnt visually appear to be any. What can you suggest?
When you removed paper from the machine, did it rip at all? If it did, a small scrap could have been left behind, causing the jam code. Depending on where the machine is located and who uses it, there might also be a foreign object lodged in it (like a staple or paper clip). If you think there is nothing in there causing the jam, try turning the machine off and turning it back on, and see if it still shows the jam.
May 27, 2010 | Panasonic Panafax UF-585 Plain Paper Laser...
Lexmark T642 Printer giving me a paperjam error#241.10. There is no paperjam
Normally this is caused by either a small piece of paper stuck in a sensor or a bad sensor. Lots of times printers use optical detectors and it may just have paper dust causing a sensor to think there is a stuck piece of paper. Give the printer a through cleaning and let me know what happens.
Mar 20, 2010 | Lexmark T640 Laser Printer
Paper jam that I can't see in MP610--how do I free it?
If you cant free the paper by just pulling it out try reading the manual for a paperjam question
Dec 17, 2009 | Canon MP610 Photo All-In-One Printer
Paperjam - CANON IP1800
Debris in the printer can cause the wheels to become stuck and prevent the rest of the paper from rolling out. Check for debris.
Sep 22, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon irc3380i paperjam
This problem fault manual presenting the track. Follows to consider several reasons. Check the condition rubber roller seizure of the paper. Check and clean lower brake platform. Check and value the possible ragged sheet of paper. Check presence a stranger subject in giving device. Try to give the paper along on format by narrow side. Thank you, good luck!
Sep 16, 2009 | Canon C2058 Color Copier
My NP6012 stops and paperjam light comes on. Paper not being fed.
Pick up wheels can be full of dust due the time storage.Keep on trying to make copies,the paper will clean the rollers every time it try to feed.
Jan 28, 2009 | Office Equipment & Supplies
Printer
Sometimes just a teensy bit of paper stuck inside will make it say paperjam. I would check very well.
Dec 11, 2006 | Canon I900D InkJet Photo Printer
99 people viewed this question
old marine
old marine
