Question about Kenmore 20.6 cu. ft. Upright Freezer 24092
How do I replace the digital display? - Kenmore 20.6 cu. ft. Upright Freezer 24092
My kenmore upright freezer has a digital display that shows alarms. it is showing a ff and a ce code. can you tell me what they mean?
You have a bad freezer fan and need to replace it. The fan is located behind the back wall INSIDE the freezer. The unit will warm up a little because the air wont circulate the way it is supposed to. You can try unplugging fridge for 30 seconds to reset the control board u can do it yourself although I don't recommend it because u need actual diagnosis but this seems it hope it helps try buying part from sears or amazon
Dec 10, 2013 | Kenmore Freezers
My new frigidaire freezer the digital display on outside of door flashes off what to do?
Hello - Typically "OF" indicates that the freezer is turn off. To activate freezer, press UP three times until display shows "1" then press UP to desired setting. If it will not allow you to change setting and freezer continues to be off, try resetting the freezer by unplugging it or flipping the breaker off. Wait approximately ten minutes and turn it on. If "OF" continues to display, the unit could possibly have a communication problem with the electronic control assembly. Contact a professional to move forward accurately.
Nov 04, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a 2007 model 253.264 upright Kenmore self-defrosting freezer. The control panel on the front door stopped working. No temperature reading and no way to adjust controls. The freezer is still
I have one out in the yard that is doing the very same thing. Works good but the door display is out. I looked underneath and all of the wires seem to be connected. The main control board is on the bottom as well. The battery is also new. You must have a broken wire between that control and the main board below. I imagine it has something to do the the connector that goes through the door.
Sep 21, 2012 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Nup right freezer model # 2532240210 I defrosted then turned back on and all the lights on outside of door is flashing is there a problem?
Does the unit have a digital control on the door? If so try unplugging the freezer for about ten seconds to reset the control. If they still flash replace the digital control. If you do not have the digital display, and its just an orange light at the bottom, then no worries they sometime flicker
Mar 20, 2011 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Has power but does not freeze
About the only things that can be replaced on a chest style freezer are the thermostat, and the starting device for the compressor. if you know where the control is then thump it fairly hard to see if the unit comes on. If unit comes on then you need to replace the thermostat. (control and thermostat are same thing). now if it has the digital display on the door of the freezer do not thump it. Only the newer freezers have those though. Hope this helps
Mar 02, 2011 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Fridge freezer stopped making ice digital display has gone off at the front of appliance, when you open door lights flicker and it makes a noise.
I have seen this a few times on whirlpool refrigerators. There is likely a high voltage board mounted inside a grey or white box mounted next to the compressor. The noise is usually eminating from this box, and replacing the board will solve all of your problems most likely.
Sep 23, 2010 | Whirlpool Freezers
Samsung RSA1WTMH i just blew my fusebox and my fridge freezer just flashing 1 led light
hope the following helps you, I had a similar problem with my RSH1 and it took me a few hours searching online before I found the following.
"Hi, I have it on good authority that this is the system check for Samsungs (RS21, SRS20, etc) during normal operation, is to hold the top two buttons down, just until display flashes - this will reset the electronics.
Secondly, if the top two buttons are held down for longer (8 seconds) the display goes blank and will show any error messages in the form of DASHES
I have experimented with unplugging air or frost probes - and the error code you get -on a blank screen is different parts of the last digit lighting up.
Example: when i disconnect the fridge air-probe, shut both doors, hold down top buttons around display - The SIDE of the last "8" digit lights up ! ...strange but true.
But, I need to know what it means when the BOTTOM of the "8" digit lights up"
I am still trying to find a list of the error codes the lines refer to but so far my unit is working fine.
Angus
Sep 21, 2010 | Freezers
My Chestfreezer is displaying FF
I believe the FF would mean a thermistor has an open circuit . If so then the sensor would need to be replaced .You can ohm the sensor and at room temp it should be around 1100 ohms.
Always disconnect power before attempting to repair any electrical appliance
Oct 21, 2017 | Freezers
No digital readout
Hello derek143
You Said,
I have a Whirlpool upright freezer AFG 371/H there is a digital display and lights and buttons, on/off temp alarm etc running across the top of the freezer. None of this works but the freezer is still freezing. i have no idea what the temp is.
I think you should try unplugging it for 5 minutes and then try restarting it and see if it reset.
Sep 11, 2008 | Freezers
Kenmore 20.6 cu. ft. Upright Freezer 24092 Logo
89 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
