Question about Radio Communications
Can I turn off hyper scan? If so how? - Radio Communications
    Top Expert:
  • 10,875 Answers
Why?? thats the best,then all you do is delay or hold important channels
Posted on Apr 24, 2015
I have a magnum omega s 45 hp that goes into hyper scan what can i do
Hi don,
Hyperscan is usually, but not the only domain of scanning receivers.
Does it affect your Tx or Rx, if not, then there is nothing wrong, but if you want it to stop scanning for an active channel, then press the scan button once to stop it.
I hope that answers your query.
Cheers,
Peter
Feb 19, 2013 | Magnum OmegaForce S45 CB Radio
What is the hyper symbol on the display
Click here for your manual.
HYPER appears when scanning; while Hypersearch is active during a direct or limit search.
Hypersearch
- lets you set the scanner to search at
up to 300 steps per second in frequency bands with 5
kHz steps, compared to the normal search speed of
100 steps per second.
Hyperscan - the scanner automatically scans up to
50 channels per second to help you quickly find interesting broadcasts.
Jan 26, 2013 | Radio Shack Pro-94 Scanner
In the past, turning off and on would result in "blinking power light" situation. I would unplug for 10 minutes, and all would be well. But suddenlt, powering on just show a mess of RGB colors...
The tv board that call the HYPER board nown as the tv convergence board was dying and have problems,but the tv was still used able that why u able to unplug it awhile,replug it back and get it up and running.Now the tv HYPER board known as tv convergence board are totally dead,colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures for a minute when the HYPER board was still functional for a little bit.Now the tv HYPER board getting no voltages at all,that why ur tv getting only a power LED indication light flashing only.The tv must get it tv HYPER board fixed also known as a tv convergence board.The tv HYPER boad must have it parts replace like 2 STK convergence ICS and some or all of it resistors too.To get the tv up and running again.The tvs shops will cost u like $300-350 for parts and labors.
Aug 10, 2011 | Toshiba 55H70 55" Rear Projection...
How to turn off hyper scan
The PRO-94 SCAN speed is fixed at 50 channels per second and cannot be changed/switched. Hyper SEARCH can be switched ON or OFF by pressing the PRIORITY (H/S) key while the scanner is operating in SEARCH mode. The scanner operates at 100 steps per second in normal search mode. In HYPER search mode it displays HYPER and operates at 300 steps per second.
Need the manual for your scanner? You can download and print it, at no cost, here:
http://support.radioshack.com/support_electronics/doc61/61172.pdf
Bill B.
Listening in since the 60's
Feb 07, 2011 | Radio Shack Pro-94 Scanner
Turn off hyper scan on pro 84
Answered under PRO-94.
Bill B.
Hyper Threading - How to?
right when the computer starts to boot up when you turn it on press F2 for the BIOS menu. a menu should pop up go to the correct category for what your looking for. there should be an option in the BIOS somewhere to disable/enable hyper threading.
Mar 05, 2010 | HP Compaq d530 SFF PC Desktop
I still get error message with Hyper R4i
Go to http://www.hyper4i.com/
Download there the wright kernel and the newest firmware for your hyper R4i.
Delete on the memory card, downlisted folders and files.
Folders:
_system_
moonshl2
SSTATE
Files:
_DS_MENU.dat
_DS_MSHL.nds
HOW TO USE.txt
Put the new kernel files from the archive to the memory card and from the other archive de nds rom that contains the new firmware.
Boot using the new kernel and run first the new firmware rom, turn off the ds when it tells you to do so, this makes the Hyper R4i working on DSi's with firmware version v1.4.
Delete the firmware rom from your memory card because you won't need it anymore.
The Hyper R4i should now work as it should.
Note that the SAVE folder contains your safed games, if there are still problems, try to delete this folder to.
Succes.
Aug 28, 2009 | Nintendo DSi Black Console
Toshiba model 57H81
hyper board is nat made anymoore just replaced 10 10uf caps inside.
Apr 02, 2007 | Toshiba 57H81 57" Rear Projection...
Radio Communications Logo
250 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
