Question about Maytag Washing Machines
Maytag 3000 serieses washer has F21 error message, what does it mean?
  • Maytag Master
  • 5,323 Answers
F21 implies that there is a drain pump problem, u may have abd pump or clogged pump or hoses?
Maytag 3000 serieses washer has F21 error message, - maytag-3000-serieses-washer-f21-error-3gtroy05deocb4x2c1cgsv5x-3-0.jpg
maytag-3000-serieses-washer-f21-error-3gtroy05deocb4x2c1cgsv5x-3-5Maytag 3000 serieses washer has F21 error message, - maytag-3000-serieses-washer-f21-error-3gtroy05deocb4x2c1cgsv5x-3-9.jpgoads/images/maytag-3000-serieses-washer-f21-error-3gtroy05deocb4x2c1cgsv5x-3-9.jpg
Posted on May 15, 2015
kel1guy2002
  • 3740 Answers
SOURCE: getting f21 error on my front loading 3000 series
F21 is too long to drain:: (more than 4 mins) Check your drain hose outflow into a couple of 5 gal buckets it should flow pretty fast. If not, there is both a suds sensor and the water level pressure switch that can be causing the problem. Since you do not have SUDS showing on your control panel I am assuming the suds sensor is fine. The water pressure switch itself can cause the problem even if you hear audible clicks when testing with an external hose. A clogged drain pump strainer can do the same thing. Lastly... the obvious... is the drain hose kinked???? Good luck and hope this helps.
Posted on Jan 11, 2010
ginko
  • 19396 Answers
SOURCE: What does an f22 error
F22 is door lock error. This is usually fixed replacing the door lock. Connection from door lock to CCU (control panel) may also be responsible.
Posted on Nov 01, 2010
TheMobilian
  • 8220 Answers
SOURCE: What does a f21 message mean on maytag 3000
F-21
Posted on Jul 09, 2011
KevinWhite
  • 1902 Answers
SOURCE: f21 error on model mhwe300vw13 maytag 3000 it
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Posted on Aug 05, 2011
Daniel S
  • 4323 Answers
SOURCE: What does an F21 error
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it. Hope this helps... Please post back if you need more information.
Daniel
Posted on Aug 16, 2011
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
Error message SUD and F21 even after unclogging the filter
Push the pause/cancel button twice to clear your message. Then run through a rinse/spin cycle. Next try a normal load without any detergent. SUDS is usually from too much detergent. If this fails, checked the hose for kinks. Check connections and if all that fails, you will probably have to replace the pump. Good Luck!
Feb 04, 2014 | Maytag MAH6700AWW Neptune Front-Load...
Maytag 3000 series washer F21
Just cleaned out the drain inside the Maytag 3000 and boy if that don't fix it nothing will. I think something was growing in there. Seems to be working fine now. Thanks for the help
Feb 03, 2013 | Maytag EPIC MFW9700S Front Load Washer
My maytag washer is showing F21. Won't empty of
Hello, welcome to fixya.
Based on your post I understand you have a "F21" error problem with a Maytag washer, the error on these units built by Whirlpool (such as yours) means an excessive drain time or excessive suds was detected as you may or may not already know.
If you follow the link to my solution to this error designed specifically for "do-it-yourselfers" you should be fixed up in no time. (It's much quicker for me than pasting or retyping the complete solution several hundred times, that's how common this is)
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for visiting fixya for your washer inquiry. Please take a moment to rate my assistance both here and on my tip link and leave a brief testimony.
Regards,
Macmarkus :)
Sep 01, 2011 | Maytag Washing Machines
What does an F21 error message mean in a Maytag 5000 series front load washer>
Hi
Daniel
Aug 15, 2011 | Maytag Washing Machines
F21 error on model mhwe300vw13 maytag 3000 it
Kevin
Aug 05, 2011 | Maytag Washing Machines
Maytag 3000 serues washer error code F21
That means its not draining properly. check that the drain hose isn't kinked or clogged.
Sep 14, 2010 | Kitchen Ranges
Washing Machines Logo
148 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
